zeyoner
  1. I was able to console in with the HAT attached. U-Boot TPL 2022.07_armbian-2022.07-Se092-P621f-H28b4-V23b0-Bbf55-R448a (Dec 04 2025 - 04:39:41) NOTICE: BL31: v1.3(release):845ee93 NOTICE: BL31: Built : 15:51:11, Jul 22 2020 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: If lpddr4 need support multi frequency, INFO: please update loader! INFO: Current ctl index[0] freq=400MHz INFO: Current ctl index[1] freq=800MHz INFO: plat_rockchip_pmu_init(1196): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 Guess the question now is. Is there a newer bootloader. Trying to understand all this.
  2. Actually, hope is not all lost. The image downloaded for the 4c from Armbian. Has the sources set to beta. So, I changed them and was able to install armbian-config. Although it isn't officially supported on the version I'm using. It does the job. Disabled kernel and firmware updating. Also, add Radxa's Bookworm repo. Ran a upgrade and all is well. Should last me a few years. Until the day I decide I want to throw a bunch of my time at an other SBC.
  3. Is this an Armbian issue or a Radxa issue?
  4. Well said.. I noticed that if I use Armbian_community_24.5.0-trunk.93_Rockpi-4c_bookworm_current_6.6.18_minimal.img it boots. However, once I upgrade it's all over. linux-dtb-current-rockchip64/bookworm 26.2.0-trunk.70 arm64 [upgradable from: 24.5.0-trunk.93] linux-image-current-rockchip64/bookworm 26.2.0-trunk.70 arm64 [upgradable from: 24.5.0-trunk.93] linux-u-boot-rockpi-4c-current/bookworm 26.2.0-trunk.70 arm64 [upgradable from: 24.5.0-trunk.93]
  5. Oh yea, my trust with Radxa was gone a few months after purchasing two of these. It was a mini NAS kit. The 4c has it's CPU on the bottom side. Making it difficult to use it anywhere else. Not to mention they stopped developing for the 4c after Bullseye. You can't even find it in their new docs page lesson learned. If I ever go SoB again it'll have to be a Raspberry Pi. Which I feel is overpriced when compared to other options.
  6. Ok, I got the serial output working. Oddly everything worked and the unit booted. 😕 So I go and put the Radxa Penta SATA HAT and boom back to the same issue. The HAT appears to be causing an issue. Activity light is on but in a continuous double blink. The NIC is also showing activity but I can not access or ping. Switch shows a link but no data. Sucks because of the Penta HAT, I am not able to connect the serial to USB cable. The HAT is covering the entire GPIO. https://radxa.com/products/accessories/penta-sata-hat Thought to myself. Ok, let's revert back to an older release (Bookworm). It has the same issue. It's not until I get to Bullseye that it works. Has me thinking. Am I that few who purchased the Rock Pi 4C non plus with their Penta SATA HAT?
  7. I'll have to order a USB serial cable based on CH340. Give me a few days and I'll have those logs for you.
  8. Hello fellow geeks/nerds, Here still using a Rock Pi 4c on 26.2.0-trunk.44. After upgrading to 26.2.0-trunk.62 the Rockpi just does not come back. No display no network. Wish I could provide more details beside the versions. I've went ahead and froze the kernel updates. If there's a way to maybe pull a log of sorts please let me know and I'll post it.
  9. Did some more searching and came across a post of yours. After sudo apt update && apt upgrade -y && linux-headers-current-rockchip64 Followed by some cleaning up and undoing of the other kernel. Reinstalled zfsutils-linux zfs-dkms zfs-zed packages and ran into errors. Setting up zfs-dkms (2.0.3-9+deb11u1) ... Removing old zfs-2.0.3 DKMS files... ------------------------------ Deleting module version: 2.0.3 completely from the DKMS tree. ------------------------------ Done. Loading new zfs-2.0.3 DKMS files... Building for 6.6.39-current-rockchip64 Building initial module for 6.6.39-current-rockchip64 configure: error: *** None of the expected "PDE_DATA" interfaces were detected. *** This may be because your kernel version is newer than what is *** supported, or you are using a patched custom kernel with *** incompatible modifications. *** *** ZFS Version: zfs-2.0.3-9+deb11u1 *** Compatible Kernels: 3.10 - 5.10 Error! Bad return status for module build on kernel: 6.6.39-current-rockchip64 (aarch64) Consult /var/lib/dkms/zfs/2.0.3/build/make.log for more information. dpkg: error processing package zfs-dkms (--configure): installed zfs-dkms package post-installation script subprocess returned error exit status 10 dpkg: dependency problems prevent configuration of zfs-zed: zfs-zed depends on zfs-modules | zfs-dkms; however: Package zfs-modules is not installed. Package zfs-dkms which provides zfs-modules is not configured yet. Package zfs-dkms is not configured yet. dpkg: error processing package zfs-zed (--configure): dependency problems - leaving unconfigured Processing triggers for initramfs-tools (0.140) ... update-initramfs: Generating /boot/initrd.img-6.6.39-current-rockchip64 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.39-current-rockchip64 Image Name: uInitrd Created: Mon Aug 5 02:43:51 2024..............................................................................] Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 20403257 Bytes = 19925.06 KiB = 19.46 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.39-current-rockchip64 to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.6.39-current-rockchip64' update-initramfs: Armbian: done. Errors were encountered while processing: zfs-dkms zfs-zed E: Sub-process /usr/bin/dpkg returned an error code (1) /var/lib/dkms/zfs/2.0.3/build/make.log: DKMS make.log for zfs-2.0.3 for kernel 6.6.39-current-rockchip64 (aarch64) Mon 05 Aug 2024 02:42:54 AM EDT make: *** No targets specified and no makefile found. Stop. Seems as though I have to use kernel 5.10...?
  10. ### lsusb: Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M ### Group membership of *REDACTED* : *REDACTED* tty disk dialout sudo audio video plugdev games users systemd-journal input netdev ssh docker ### Userland: PRETTY_NAME="Armbian 23.8.1 bullseye" ARMBIAN_PRETTY_NAME="Armbian 23.8.1 bullseye" ### Installed packages: rc armbian-bsp-cli-rockpi-4c 23.8.1 arm64 Armbian CLI BSP for board 'rockpi-4c' - transitional package ii armbian-bsp-cli-rockpi-4c-current 23.8.1 arm64 Armbian CLI BSP for board 'rockpi-4c' branch 'current' ii armbian-config 24.5.5 all Armbian configuration utility ii armbian-firmware 24.5.6 all Armbian - Linux firmware ii armbian-plymouth-theme 24.5.5 all boot animation, logger and I/O multiplexer - Armbian theme ii hostapd 3:2.10-6~armbian22.02.3+1 arm64 IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator ii htop 3.1.0-0~armbian20.08.2+1 arm64 interactive processes viewer ii linux-base 4.6 all Linux image base package ii linux-dtb-current-rockchip64 24.5.3 arm64 Armbian Linux current DTBs in /boot/dtb-6.6.39-current-rockchip64 ii linux-headers-5.10.0-31-arm64 5.10.221-1 arm64 Header files for Linux 5.10.0-31-arm64 ii linux-headers-5.10.0-31-common 5.10.221-1 all Common header files for Linux 5.10.0-31 ii linux-headers-arm64 5.10.221-1 arm64 Header files for Linux arm64 configuration (meta-package) hi linux-image-5.10.0-31-arm64 5.10.221-1 arm64 Linux 5.10 for 64-bit ARMv8 machines (signed) ii linux-image-current-rockchip64 24.5.3 arm64 Armbian Linux current kernel image 6.6.39-current-rockchip64 ii linux-kbuild-5.10 5.10.221-1 arm64 Kbuild infrastructure for Linux 5.10 ii linux-libc-dev:arm64 23.02.2 arm64 Armbian Linux support headers for userspace development ii linux-u-boot-rockpi-4c-current 24.5.1 arm64 Das U-Boot for rockpi-4c ### Loaded modules: Module Size Used by dm_crypt 49152 1 trusted 12288 1 dm_crypt dm_mod 126976 3 dm_crypt xt_conntrack 12288 1 nft_chain_nat 12288 3 xt_MASQUERADE 16384 1 nf_nat 45056 2 nft_chain_nat,xt_MASQUERADE nf_conntrack_netlink 45056 0 nf_conntrack 118784 4 xt_conntrack,nf_nat,nf_conntrack_netlink,xt_MASQUERADE nf_defrag_ipv6 20480 1 nf_conntrack nf_defrag_ipv4 12288 1 nf_conntrack xfrm_user 40960 1 xfrm_algo 12288 1 xfrm_user xt_addrtype 12288 2 nft_compat 16384 4 nf_tables 225280 75 nft_compat,nft_chain_nat nfnetlink 16384 4 nft_compat,nf_conntrack_netlink,nf_tables br_netfilter 28672 0 bridge 241664 1 br_netfilter lz4hc 12288 0 lz4 12288 0 zram 32768 3 raid1 45056 1 snd_soc_hdmi_codec 20480 1 snd_soc_simple_card 20480 0 brcmfmac_wcc 12288 0 md_mod 151552 2 raid1 snd_soc_audio_graph_card 16384 0 snd_soc_simple_card_utils 24576 2 snd_soc_audio_graph_card,snd_soc_simple_card snd_soc_spdif_tx 12288 0 dw_hdmi_i2s_audio 12288 0 hci_uart 135168 0 panfrost 69632 0 dw_hdmi_cec 12288 0 gpu_sched 36864 1 panfrost drm_shmem_helper 16384 1 panfrost rk_crypto 28672 0 btqca 20480 1 hci_uart rng_core 16384 1 rk_crypto snd_soc_rockchip_i2s 24576 4 btsdio 16384 0 btrtl 28672 1 hci_uart btintel 40960 1 hci_uart hantro_vpu 249856 0 rockchip_vdec 77824 0 snd_soc_es8316 36864 1 brcmfmac 368640 1 brcmfmac_wcc btbcm 20480 1 hci_uart snd_soc_core 208896 7 snd_soc_spdif_tx,snd_soc_hdmi_codec,snd_soc_audio_graph_card,snd_soc_simple_card_utils,snd_soc_rockchip_i2s,snd_soc_simple_card,snd_soc_es8316 v4l2_vp9 20480 2 rockchip_vdec,hantro_vpu rockchip_rga 20480 0 brcmutil 16384 1 brcmfmac bluetooth 663552 7 btrtl,btqca,btsdio,btintel,hci_uart,btbcm videobuf2_dma_contig 20480 2 rockchip_vdec,hantro_vpu snd_compress 24576 1 snd_soc_core v4l2_h264 16384 2 rockchip_vdec,hantro_vpu snd_pcm_dmaengine 12288 1 snd_soc_core v4l2_mem2mem 24576 3 rockchip_vdec,hantro_vpu,rockchip_rga videobuf2_dma_sg 16384 1 rockchip_rga cfg80211 802816 1 brcmfmac realtek 32768 1 snd_pcm 106496 6 snd_soc_hdmi_codec,snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_soc_es8316,snd_pcm_dmaengine videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_dma_sg videobuf2_v4l2 20480 4 rockchip_vdec,hantro_vpu,rockchip_rga,v4l2_mem2mem sg 28672 0 snd_timer 36864 1 snd_pcm videodev 229376 5 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem rfkill 24576 5 bluetooth,cfg80211 snd 77824 5 snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm videobuf2_common 49152 8 rockchip_vdec,videobuf2_dma_contig,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_dma_sg,v4l2_mem2mem,videobuf2_memops mc 53248 6 rockchip_vdec,videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem soundcore 12288 1 snd dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 233472 3 stmmac_platform,dwmac_rk pcs_xpcs 20480 1 stmmac cpufreq_dt 16384 0 ip_tables 28672 0 x_tables 36864 5 xt_conntrack,nft_compat,xt_addrtype,ip_tables,xt_MASQUERADE autofs4 40960 2 ### nand-sata-install.log: ### Current system health: Time CPU n/a load %cpu %sys %usr %nice %io %irq Tcpu 23:45:28 --- 1.36 3% 1% 1% 0% 0% 0% 38.1 °C 23:45:29 --- 1.36 13% 5% 0% 0% 6% 0% 38.8 °C 23:45:29 --- 1.36 5% 4% 0% 0% 0% 0% 38.8 °C 23:45:29 --- 1.36 7% 5% 0% 0% 0% 0% 38.8 °C 23:45:30 --- 1.36 6% 5% 0% 0% 0% 0% 38.8 °C 23:45:30 --- 1.36 3% 1% 1% 0% 0% 0% 38.1 °C 23:45:31 --- 1.36 15% 14% 0% 0% 0% 0% 38.8 °C 23:45:31 --- 1.36 18% 12% 3% 0% 0% 1% 38.8 °C 23:45:31 --- 1.36 10% 2% 0% 0% 6% 0% 38.1 °C 23:45:32 --- 1.36 12% 6% 0% 0% 5% 0% 38.8 °C ### resolv.conf -rw-r--r-- 1 root root 82 Aug 4 22:13 /etc/resolv.conf # Generated by NetworkManager search mynetworksettings.com nameserver XXX.XXX.1.1 ### Current sysinfo: Linux 6.6.39-current-rockchip64 (*REDACTED*) 08/04/2024 _aarch64_ (6 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 1.08 0.00 1.74 0.47 0.00 96.70 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd mmcblk0 5.36 98.19 124.17 0.00 556727 704048 0 mmcblk0p1 5.33 97.59 124.17 0.00 553295 704048 0 mmcblk0boot0 0.03 0.13 0.00 0.00 760 0 0 mmcblk0boot1 0.03 0.13 0.00 0.00 760 0 0 sda 51.97 25080.47 364.52 0.00 142201730 2066762 0 sda1 51.94 25079.83 364.52 0.00 142198110 2066762 0 sdb 51.81 1.29 25441.61 0.00 7333 144249354 0 sdb1 51.79 0.87 25441.61 0.00 4929 144249354 0 md127 1.38 3.09 363.63 0.00 17520 2061704 0 zram0 0.03 0.63 0.00 0.00 3552 4 0 zram1 1.84 0.49 9.49 0.00 2768 53804 0 zram2 0.00 0.00 0.00 0.00 0 0 0 dm-0 1.31 1.31 362.87 0.00 7401 2057404 0 --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- r b swpd free buff cache si so bi bo in cs us sy id wa st 1 0 0 2852696 87652 758476 0 0 17 84 72 79 1 2 97 0 0 total used free shared buff/cache available Mem: 3.8Gi 249Mi 2.7Gi 6.0Mi 826Mi 3.4Gi Swap: 1.9Gi 0B 1.9Gi NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram0 lzo-rle 1.9G 4K 74B 12K 6 [SWAP] /dev/zram1 zstd 50M 1.6M 169.1K 748K 6 /var/log 23:45:32 up 1:34, 2 users, load average: 1.41, 1.34, 1.13 [ 11.029453] systemd[1]: Mounting Kernel Trace File System... [ 11.036976] systemd[1]: Starting Restore / save the current clock... [ 11.043059] systemd[1]: Starting Set the console keyboard layout... [ 11.049490] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 11.055273] systemd[1]: Starting Load Kernel Module configfs... [ 11.061097] systemd[1]: Starting Load Kernel Module drm... [ 11.067007] systemd[1]: Starting Load Kernel Module fuse... [ 11.074905] systemd[1]: Started Nameserver information manager. [ 11.076390] systemd[1]: Reached target Network (Pre). [ 11.078239] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 11.078532] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 11.085766] systemd[1]: Starting Load Kernel Modules... [ 11.092078] systemd[1]: Starting Remount Root and Kernel File Systems... [ 11.098340] systemd[1]: Starting Coldplug All udev Devices... [ 11.109477] systemd[1]: Mounted Huge Pages File System. [ 11.110442] systemd[1]: Mounted POSIX Message Queue File System. [ 11.111668] systemd[1]: Mounted Kernel Debug File System. [ 11.112610] systemd[1]: Mounted Kernel Trace File System. [ 11.115214] systemd[1]: Finished Restore / save the current clock. [ 11.118234] systemd[1]: Finished Create list of static device nodes for the current kernel. [ 11.120119] systemd[1]: modprobe@configfs.service: Succeeded. [ 11.121741] systemd[1]: Finished Load Kernel Module configfs. [ 11.123734] systemd[1]: modprobe@drm.service: Succeeded. [ 11.125235] systemd[1]: Finished Load Kernel Module drm. [ 11.127108] systemd[1]: modprobe@fuse.service: Succeeded. [ 11.128707] systemd[1]: Finished Load Kernel Module fuse. [ 11.133332] systemd[1]: Finished Load Kernel Modules. [ 11.176850] systemd[1]: Mounting FUSE Control File System... [ 11.185205] systemd[1]: Mounting Kernel Configuration File System... [ 11.192924] EXT4-fs (mmcblk0p1): re-mounted 58156628-a1ec-48f7-971d-8c646a89e424 r/w. Quota mode: none. [ 11.193739] systemd[1]: Starting Apply Kernel Variables... [ 11.206913] systemd[1]: Finished Remount Root and Kernel File Systems. [ 11.208080] systemd[1]: Mounted FUSE Control File System. [ 11.208832] systemd[1]: Mounted Kernel Configuration File System. [ 11.211070] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 11.211572] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 11.219188] systemd[1]: Starting Load/Save Random Seed... [ 11.228196] systemd[1]: Starting Create System Users... [ 11.252755] systemd[1]: Finished Apply Kernel Variables. [ 11.299605] systemd[1]: Finished Load/Save Random Seed. [ 11.302490] systemd[1]: Finished Create System Users. [ 11.303527] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 11.308998] systemd[1]: Starting Create Static Device Nodes in /dev... [ 11.377873] systemd[1]: Finished Set the console keyboard layout. [ 11.380851] systemd[1]: Finished Create Static Device Nodes in /dev. [ 11.381677] systemd[1]: Reached target Local File Systems (Pre). [ 11.412109] systemd[1]: Mounting /tmp... [ 11.421698] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 11.430419] systemd[1]: Mounted /tmp. [ 11.539254] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 11.688082] systemd[1]: Finished Coldplug All udev Devices. [ 11.732929] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 11.744740] systemd[1]: Starting Show Plymouth Boot Screen... [ 11.754511] systemd[1]: Starting Wait for udev To Complete Device Initialization... [ 11.767593] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 11.818605] cpu cpu0: OPP table can't be empty [ 11.819767] systemd[1]: Started Show Plymouth Boot Screen. [ 11.820700] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 11.821404] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 11.821630] systemd[1]: Reached target Paths. [ 11.913384] systemd[1]: Found device /dev/ttyS2. [ 11.930685] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found [ 11.930708] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found [ 11.930861] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock [ 11.931113] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 11.931128] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 11.931141] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11). [ 11.931159] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ 11.931216] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 11.947395] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 11.947901] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 11.947926] rk_gmac-dwmac fe300000.ethernet: DWMAC1000 [ 11.947938] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported [ 11.947948] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported [ 11.947957] rk_gmac-dwmac fe300000.ethernet: COE Type 2 [ 11.947967] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported [ 11.947976] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported [ 11.948112] rk_gmac-dwmac fe300000.ethernet: Normal descriptors [ 11.948124] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled [ 11.948133] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 11.956858] mc: Linux media interface: v0.10 [ 12.006164] videodev: Linux video capture interface: v2.00 [ 12.024337] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 12.037495] sd 3:0:0:0: Attached scsi generic sg1 type 0 [ 12.086013] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 12.088325] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 12.089990] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 12.106142] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid [ 12.113244] rockchip-rga ff680000.rga: HW Version: 0x03.02 [ 12.116359] Bluetooth: Core ver 2.22 [ 12.119692] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0 [ 12.124169] NET: Registered PF_BLUETOOTH protocol family [ 12.124200] Bluetooth: HCI device and connection manager initialized [ 12.124230] Bluetooth: HCI socket layer initialized [ 12.124246] Bluetooth: L2CAP socket layer initialized [ 12.124312] Bluetooth: SCO socket layer initialized [ 12.152862] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL) [ 12.152889] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL) [ 12.155279] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 12.163118] brcmfmac: F1 signature read @0x18000000=0x15294345 [ 12.165874] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 12.167496] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1 [ 12.167575] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 12.169043] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.radxa,rockpi4c.bin failed with error -2 [ 12.179711] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2 [ 12.187906] usbcore: registered new interface driver brcmfmac [ 12.189377] rkvdec ff660000.video-codec: Adding to iommu group 1 [ 12.326236] rk3288-crypto ff8b0000.crypto: will run requests pump with realtime priority [ 12.326355] rk3288-crypto ff8b0000.crypto: Register ecb(aes) as ecb-aes-rk [ 12.326471] rk3288-crypto ff8b0000.crypto: Register cbc(aes) as cbc-aes-rk [ 12.326515] rk3288-crypto ff8b0000.crypto: Register ecb(des) as ecb-des-rk [ 12.326556] rk3288-crypto ff8b0000.crypto: Register cbc(des) as cbc-des-rk [ 12.326597] rk3288-crypto ff8b0000.crypto: Register ecb(des3_ede) as ecb-des3-ede-rk [ 12.326638] rk3288-crypto ff8b0000.crypto: Register cbc(des3_ede) as cbc-des3-ede-rk [ 12.326679] rk3288-crypto ff8b0000.crypto: Register sha1 as rk-sha1 [ 12.326722] rk3288-crypto ff8b0000.crypto: Register sha256 as rk-sha256 [ 12.326765] rk3288-crypto ff8b0000.crypto: Register md5 as rk-md5 [ 12.326806] rk3288-crypto ff8b0000.crypto: Register TRNG with sample=1200 [ 12.372159] panfrost ff9a0000.gpu: clock rate = 500000000 [ 12.375101] rk3288-crypto ff8b8000.crypto: will run requests pump with realtime priority [ 12.401373] Bluetooth: HCI UART driver ver 2.3 [ 12.401406] Bluetooth: HCI UART protocol H4 registered [ 12.401417] Bluetooth: HCI UART protocol BCSP registered [ 12.404734] Bluetooth: HCI UART protocol LL registered [ 12.404763] Bluetooth: HCI UART protocol ATH3K registered [ 12.404867] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 12.405167] Bluetooth: HCI UART protocol Intel registered [ 12.405545] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 12.405571] panfrost ff9a0000.gpu: features: 00000000,00000407, issues: 00000000,24040400 [ 12.405590] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 12.405612] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 12.406923] Bluetooth: HCI UART protocol Broadcom registered [ 12.407046] Bluetooth: HCI UART protocol QCA registered [ 12.407059] Bluetooth: HCI UART protocol AG6XX registered [ 12.407149] Bluetooth: HCI UART protocol Marvell registered [ 12.412904] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 1 [ 12.523684] dw-apb-uart ff180000.serial: failed to request DMA [ 12.536248] asoc-audio-graph-card sound: ASoC: DAPM unknown pin Headphones [ 12.691413] asoc-audio-graph-card sound: ASoC: DAPM unknown pin Headphones [ 12.700558] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2) [ 12.701713] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Jun 16 2017 12:38:26 version XXX.XXX.96.2 (66c4e21@sh-git) (r) FWID 01-1813af84 [ 12.724993] input: Analog Headphones as /devices/platform/sound/sound/card0/input0 [ 12.775738] block device autoloading is deprecated and will be removed. [ 12.800391] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 12.801321] Bluetooth: hci0: BCM: chip id 130 [ 12.802223] Bluetooth: hci0: BCM: features 0x0f [ 12.805097] Bluetooth: hci0: BCM4345C5 [ 12.805136] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0000 [ 12.807564] Bluetooth: hci0: BCM4345C5 'brcm/BCM4345C5.hcd' Patch [ 12.864598] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 13.008216] md/raid1:md127: not clean -- starting background reconstruction [ 13.008246] md/raid1:md127: active with 2 out of 2 mirrors [ 13.042626] systemd[1]: Started Load/Save RF Kill Switch Status. [ 13.086290] systemd[1]: Started Timer to wait for more drives before activating degraded array md127.. [ 13.086513] systemd[1]: Reached target Bluetooth. [ 13.086647] systemd[1]: Reached target Sound Card. [ 13.186104] md127: detected capacity change from 0 to 1953257472 [ 13.334598] systemd[1]: mdadm-last-resort@md127.timer: Succeeded. [ 13.334645] systemd[1]: Stopped Timer to wait for more drives before activating degraded array md127.. [ 13.364253] systemd[1]: Started MD array monitor. [ 13.404853] systemd[1]: Finished Wait for udev To Complete Device Initialization. [ 13.718326] Bluetooth: hci0: BCM: features 0x0f [ 13.722257] Bluetooth: hci0: BCM4345C5 Ampak_CL1 UART 37.4 MHz BT 5.0 [Version: Version: 0039.0089] [ 13.722297] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0089 [ 18.015740] systemd[1]: systemd-rfkill.service: Succeeded. [ 23.008896] platform sound-dit: deferred probe pending [ 101.050295] systemd[1]: dev-disk-by-uuid-1efe5ff5-c91e-4181-beb3-67d382095a5e.device: Job dev-disk-by-uuid-1efe5ff5-c91e-4181-beb3-67d382095a5e.device/start timed out. [ 101.050338] systemd[1]: Timed out waiting for device /dev/disk/by-uuid/1efe5ff5-c91e-4181-beb3-67d382095a5e. [ 101.050538] systemd[1]: Dependency failed for Cryptography Setup for luks-1efe5ff5-c91e-4181-beb3-67d382095a5e. [ 101.050651] systemd[1]: Dependency failed for Local Encrypted Volumes. [ 101.050756] systemd[1]: cryptsetup.target: Job cryptsetup.target/start failed with result 'dependency'. [ 101.050823] systemd[1]: systemd-cryptsetup@luks-1efe5ff5-c91e-4181-beb3-67d382095a5e.service: Job systemd-cryptsetup@luks-1efe5ff5-c91e-4181-beb3-67d382095a5e.service/start failed with result 'dependency'. [ 101.050869] systemd[1]: dev-disk-by-uuid-1efe5ff5-c91e-4181-beb3-67d382095a5e.device: Job dev-disk-by-uuid-1efe5ff5-c91e-4181-beb3-67d382095a5e.device/start failed with result 'timeout'. [ 101.050954] systemd[1]: dev-disk-by-uuid-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.device: Job dev-disk-by-uuid-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.device/start timed out. [ 101.050974] systemd[1]: Timed out waiting for device /dev/disk/by-uuid/30e48ec2-bb9f-49e0-afd1-71f5dccd2435. [ 101.051138] systemd[1]: Dependency failed for Cryptography Setup for luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435. [ 101.051284] systemd[1]: systemd-cryptsetup@luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.service: Job systemd-cryptsetup@luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.service/start failed with result 'dependency'. [ 101.051396] systemd[1]: dev-disk-by-uuid-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.device: Job dev-disk-by-uuid-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.device/start failed with result 'timeout'. [ 101.051548] systemd[1]: Reached target Block Device Preparation for /dev/mapper/luks-1efe5ff5-c91e-4181-beb3-67d382095a5e. [ 101.052379] systemd[1]: Reached target Block Device Preparation for /dev/mapper/luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435. [ 101.088408] systemd[1]: Starting Install ZFS kernel module... [ 101.089415] systemd[1]: Stopped target Block Device Preparation for /dev/mapper/luks-1efe5ff5-c91e-4181-beb3-67d382095a5e. [ 101.089623] systemd[1]: Stopped target Block Device Preparation for /dev/mapper/luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435. [ 101.100061] systemd[1]: zfs-load-module.service: Main process exited, code=exited, status=1/FAILURE [ 101.100924] systemd[1]: zfs-load-module.service: Failed with result 'exit-code'. [ 101.102723] systemd[1]: Failed to start Install ZFS kernel module. [ 101.102944] systemd[1]: Dependency failed for Import ZFS pools by cache file. [ 101.103070] systemd[1]: zfs-import-cache.service: Job zfs-import-cache.service/start failed with result 'dependency'. [ 101.103618] systemd[1]: Reached target ZFS pool import target. [ 101.103825] systemd[1]: Condition check resulted in Mount ZFS filesystems being skipped. [ 101.103918] systemd[1]: Reached target Local File Systems. [ 101.109267] systemd[1]: Starting Armbian leds state... [ 101.115048] systemd[1]: Starting Armbian ZRAM config... [ 101.121155] systemd[1]: Starting Set console font and keymap... [ 101.127712] systemd[1]: Starting Raise network interfaces... [ 101.134102] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 101.134557] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 101.134809] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 101.134956] systemd[1]: Condition check resulted in Wait for ZFS Volume (zvol) links in /dev being skipped. [ 101.135105] systemd[1]: Reached target ZFS volumes are ready. [ 101.150780] systemd[1]: Finished Set console font and keymap. [ 101.152479] systemd[1]: Received SIGRTMIN+20 from PID 270 (plymouthd). [ 101.158406] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 101.218457] systemd[1]: Finished Armbian leds state. [ 101.322310] zram: Added device: zram0 [ 101.323687] zram: Added device: zram1 [ 101.324852] zram: Added device: zram2 [ 101.421341] zram0: detected capacity change from 0 to 3952888 [ 101.461798] Adding 1976440k swap on /dev/zram0. Priority:5 extents:1 across:1976440k SS [ 101.484675] systemd[1]: Finished Raise network interfaces. [ 101.696246] zram1: detected capacity change from 0 to 102400 [ 101.755534] systemd[1]: Finished Armbian ZRAM config. [ 101.797108] systemd[1]: Starting Armbian memory supported logging... [ 101.897210] EXT4-fs (zram1): mounted filesystem 24de4176-fb3a-49d5-bf49-baf1c2b1b99b r/w without journal. Quota mode: none. [ 101.897287] ext4 filesystem being mounted at /var/log supports timestamps until 2038-01-19 (0x7fffffff) [ 117.158724] systemd[1]: Finished Armbian memory supported logging. [ 117.188825] systemd[1]: Starting Journal Service... [ 117.595993] systemd[1]: Started Journal Service. [ 117.680099] systemd-journald[657]: Received client request to flush runtime journal. [ 118.809081] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 120.219836] rk_gmac-dwmac fe300000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 120.229515] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 120.229571] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found [ 120.229595] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW [ 120.231528] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode [ 124.295179] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 124.301982] Bridge firewalling registered [ 124.328027] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 125.022086] Initializing XFRM netlink socket [ 128.462731] systemd-journald[657]: Received client request to flush runtime journal. [ 129.138946] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 198.475560] systemd[2453]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set [ 246.674030] systemd-journald[657]: Received client request to flush runtime journal. [ 246.750322] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 1146.740058] systemd-journald[657]: Received client request to flush runtime journal. [ 1146.808901] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 2046.709361] systemd-journald[657]: Received client request to flush runtime journal. [ 2046.789845] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 2946.702604] systemd-journald[657]: Received client request to flush runtime journal. [ 2946.775122] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 3846.684206] systemd-journald[657]: Received client request to flush runtime journal. [ 3846.776059] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 4184.598033] md: resync of RAID array md127 [ 4189.064476] device-mapper: uevent: version 1.0.3 [ 4189.065162] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com [ 4212.546008] EXT4-fs (dm-0): mounted filesystem 5602eb7e-12b3-42fb-9798-1556b2a90df5 r/w with ordered data mode. Quota mode: none. [ 4746.765355] systemd-journald[657]: Received client request to flush runtime journal. [ 4746.826781] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 5462.651092] systemd-journald[657]: Received client request to flush runtime journal. [ 5462.716166] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. vm.admin_reserve_kbytes = 8192 vm.compaction_proactiveness = 20 vm.compact_unevictable_allowed = 1 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extfrag_threshold = 500 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.memfd_noexec = 0 vm.min_free_kbytes = 22528 vm.min_slab_ratio = 5 vm.min_unmapped_ratio = 1 vm.mmap_min_addr = 4096 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_hugepages_mempolicy = 0 vm.nr_overcommit_hugepages = 0 vm.numa_stat = 1 vm.numa_zonelist_order = Node vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_high_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 121725 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 vm.zone_reclaim_mode = 0 ### interrupts: CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 18: 0 0 0 0 0 0 GICv3 25 Level vgic 20: 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer 23: 54633 65433 62030 49947 115779 61484 GICv3 30 Level arch_timer 25: 83504 64289 75597 60595 90417 72349 GICv3 113 Level rk_timer 31: 0 0 0 0 0 0 GICv3 37 Level ff6d0000.dma-controller 32: 0 0 0 0 0 0 GICv3 38 Level ff6d0000.dma-controller 33: 0 0 0 0 0 0 GICv3 39 Level ff6e0000.dma-controller 34: 0 0 0 0 0 0 GICv3 40 Level ff6e0000.dma-controller 35: 1236 0 0 0 0 0 GICv3 131 Level ttyS0 36: 693 0 0 0 0 0 GICv3 132 Level ttyS2 37: 0 0 0 0 0 0 GICv3 147 Level ff650800.iommu 38: 0 0 0 0 0 0 GICv3 149 Level ff660480.iommu 39: 0 0 0 0 0 0 GICv3 151 Level ff8f3f00.iommu, ff8f0000.vop 40: 0 0 0 0 0 0 GICv3 150 Level ff903f00.iommu, ff900000.vop 41: 0 0 0 0 0 0 GICv3 75 Level ff914000.iommu 42: 0 0 0 0 0 0 GICv3 76 Level ff924000.iommu 43: 66 0 0 0 0 0 GICv3 91 Level ff110000.i2c 44: 0 0 0 0 0 0 GICv3 66 Level ff130000.i2c 45: 61977 0 0 0 0 0 GICv3 68 Level ff160000.i2c 46: 429 0 0 0 0 0 GICv3 89 Level ff3c0000.i2c 47: 0 0 0 0 0 0 GICv3 88 Level ff3d0000.i2c 48: 0 0 0 0 0 0 GICv3 129 Level rockchip_thermal 49: 0 0 0 0 0 0 GICv3 152 Edge ff848000.watchdog 50: 9719 0 0 0 0 0 GICv3 96 Level dw-mci 51: 0 0 0 0 0 0 GICv3 97 Level dw-mci 52: 36031 0 0 0 0 0 GICv3 43 Level mmc0 53: 3 0 0 0 0 0 GICv3 94 Level ff100000.saradc 54: 0 0 0 0 0 0 GICv3-23 0 Level arm-pmu 55: 0 0 0 0 0 0 GICv3-23 1 Level arm-pmu 56: 0 0 0 0 0 0 rockchip_gpio_irq 7 Edge fe320000.mmc cd 57: 0 0 0 0 0 0 GICv3 59 Level rockchip_usb2phy 58: 0 0 0 0 0 0 GICv3 63 Level rockchip_usb2phy 59: 0 0 0 0 0 0 GICv3 137 Level xhci-hcd:usb1 60: 0 0 0 0 0 0 GICv3 142 Level xhci-hcd:usb3 61: 0 0 0 0 0 0 GICv3 58 Level ehci_hcd:usb5 62: 0 0 0 0 0 0 GICv3 62 Level ehci_hcd:usb7 63: 0 0 0 0 0 0 GICv3 60 Level ohci_hcd:usb6 64: 0 0 0 0 0 0 rockchip_gpio_irq 21 Level rk808 70: 0 0 0 0 0 0 rk808 5 Edge RTC alarm 74: 0 0 0 0 0 0 GICv3 64 Level ohci_hcd:usb8 75: 0 0 0 0 0 0 GICv3 81 Level pcie-sys 77: 154 0 0 0 0 0 GICv3 83 Level pcie-client 79: 0 0 0 0 0 0 ITS-MSI 0 Edge PCIe PME, aerdrv 80: 0 300801 0 0 0 0 ITS-MSI 524288 Edge ahci0 81: 0 0 0 0 0 0 ITS-MSI 524289 Edge ahci1 82: 0 0 0 0 0 0 ITS-MSI 524290 Edge ahci2 83: 0 0 0 0 166292 0 ITS-MSI 524291 Edge ahci3 84: 0 0 0 0 0 0 ITS-MSI 524292 Edge ahci4 88: 0 0 0 0 0 0 GICv3 55 Level ff940000.hdmi, dw-hdmi-cec 89: 25429 0 0 0 0 0 GICv3 44 Level eth0 90: 0 0 0 0 0 0 GICv3 87 Level ff680000.rga 91: 0 0 0 0 0 0 rockchip_gpio_irq 1 Level es8316 92: 0 0 0 0 0 0 GICv3 146 Level ff650000.video-codec 93: 0 0 0 0 0 0 GICv3 145 Level ff650000.video-codec 94: 335 0 0 0 0 0 rockchip_gpio_irq 3 Level brcmf_oob_intr 95: 0 0 0 0 0 0 GICv3 148 Level ff660000.video-codec 96: 0 0 0 0 0 0 GICv3 32 Level rk-crypto 97: 0 0 0 0 0 0 GICv3 167 Level rk-crypto 98: 0 0 0 0 0 0 GICv3 51 Level panfrost-gpu 99: 0 0 0 0 0 0 GICv3 53 Level panfrost-mmu 100: 6 0 0 0 0 0 rockchip_gpio_irq 4 Edge host_wake 101: 0 0 0 0 0 0 GICv3 52 Level panfrost-job 102: 0 0 0 0 0 0 rockchip_gpio_irq 0 Edge Headphone detection IPI0: 7051 6118 5124 6091 4565 4011 Rescheduling interrupts IPI1: 142253 90762 189514 163483 115662 95731 Function call interrupts IPI2: 0 0 0 0 0 0 CPU stop interrupts IPI3: 0 0 0 0 0 0 CPU stop (for crash dump) interrupts IPI4: 22657 24662 28699 29222 29184 28897 Timer broadcast interrupts IPI5: 0 0 0 0 0 0 IRQ work interrupts IPI6: 0 0 0 0 0 0 CPU wake-up interrupts Err: 0
  11. Attempting to install ZFS. But it seems that the latest linux headers are linux-headers-5.10.0-31-arm64. I am not able to install ZFS. Pretty sure I need to lower the kernel to match. sudo modprobe zfs modprobe: FATAL: Module zfs not found in directory /lib/modules/6.6.39-current-rockchip64 Installed linux-image-5.10.0.31-arm64. I also sudo apt-mark hold linux-image-5.10.0.31-arm64. But I do not know how to set the kernel to boot. Search tells me to use armbian-config. Had to install it and after running it the "Other" option is missing. There isn't any options to change the kernel.
