mydeardiary
  1. Update: glmark2-es2-wayland scores for lima mali400 gpu running on sway headless session is around 115. ======================================================= glmark2 2023.01 ======================================================= OpenGL Information GL_VENDOR: lima GL_RENDERER: Mali400 GL_VERSION: OpenGL ES 2.0 Mesa 22.3.6 Surface Config: buf=32 r=8 g=8 b=8 a=8 depth=24 stencil=0 samples=0 Surface Size: 800x600 windowed ======================================================= [build] use-vbo=false: FPS: 144 FrameTime: 6.952 ms [build] use-vbo=true: FPS: 185 FrameTime: 5.430 ms [texture] texture-filter=nearest: FPS: 212 FrameTime: 4.737 ms [texture] texture-filter=linear: FPS: 207 FrameTime: 4.838 ms [texture] texture-filter=mipmap: FPS: 226 FrameTime: 4.435 ms [shading] shading=gouraud: FPS: 123 FrameTime: 8.195 ms [shading] shading=blinn-phong-inf: FPS: 109 FrameTime: 9.250 ms [shading] shading=phong: FPS: 84 FrameTime: 11.953 ms [shading] shading=cel: FPS: 60 FrameTime: 16.719 ms [bump] bump-render=high-poly: FPS: 49 FrameTime: 20.620 ms [bump] bump-render=normals: FPS: 202 FrameTime: 4.973 ms [bump] bump-render=height: FPS: 171 FrameTime: 5.853 ms [effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 56 FrameTime: 18.176 ms [effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 22 FrameTime: 46.372 ms [pulsar] light=false:quads=5:texture=false: FPS: 281 FrameTime: 3.561 ms [desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 29 FrameTime: 34.857 ms [desktop] effect=shadow:windows=4: FPS: 92 FrameTime: 10.950 ms [buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 40 FrameTime: 25.293 ms [buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 40 FrameTime: 25.563 ms [buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 52 FrameTime: 19.344 ms [ideas] speed=duration: FPS: 64 FrameTime: 15.756 ms [jellyfish] <default>: FPS: 62 FrameTime: 16.169 ms [terrain] <default>: Unsupported [shadow] <default>: FPS: 57 FrameTime: 17.550 ms [refract] <default>: FPS: 10 FrameTime: 100.697 ms [conditionals] fragment-steps=0:vertex-steps=0: FPS: 219 FrameTime: 4.579 ms [conditionals] fragment-steps=5:vertex-steps=0: FPS: 117 FrameTime: 8.591 ms [conditionals] fragment-steps=0:vertex-steps=5: FPS: 221 FrameTime: 4.540 ms [function] fragment-complexity=low:fragment-steps=5: FPS: 159 FrameTime: 6.322 ms [function] fragment-complexity=medium:fragment-steps=5: FPS: 77 FrameTime: 13.067 ms [loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 153 FrameTime: 6.570 ms [loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 150 FrameTime: 6.690 ms [loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 57 FrameTime: 17.550 ms ======================================================= glmark2 Score: 115 ======================================================= The cpu temperature hits 75 degree during glmark2-es2-wayland test run.
  2. Update: this box is now running Linux 6.6.17-current-rockchip Dtb applied: overlays=emmc led-conf7 The cpu speed is now capped at 1 GHz with better stability and hdmi output works (via usb to hdmi viewed on another laptop using ffplay). Excelent. Installed sway and lima gpu is being utilized. But before I can access the lima gpu, I have to add my login to render group. `sudo usermod -a -G render $LOGNAME` Well done!
