- No wifi and bluetooth on fresh install Debian 13 trixie Minimal (CLI) — current 6.18.44
Hello comunity/maintainers, Please could anyone help me? After fesh install Debian 13 trixie Minimal (CLI) — current 6.18.44 there is no wlan0 nor hci0, only theese events in dmesg: [ 4.389072] Btrfs loaded, zoned=yes, fsverity=yes [ 4.987196] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE) [ 5.729379] sysfs: cannot create duplicate filename '/devices/virtual/tty/ttyBT0' [ 5.729536] mtty_probe+0x120/0x2c8 [sprdbt_tty] [ 5.729664] mtty_pdev_init+0x50/0xfb0 [sprdbt_tty] [ 5.729796] kobject: kobject_add_internal failed for ttyBT0 with -EEXIST, don't try to register things with the same name in the same directory. [ 5.812146] WCN: start_marlin [MARLIN_WIFI] [ 5.812162] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 40.964296] unisoc_wifi unisoc_wifi: probe with driver unisoc_wifi failed with error -1 Any help is appreciated Regards Jan
- "No SPI Image"?
"No SPI Image"?
Hi, still have problem with 5C lite and NVME. When i boot form SD, lsblk shows ZRAM, MMCBLK and NVME - when I install Armbian to NVME it boots from SSD only once and then, after seting up user and enviroment lsblk shows only zram and nvme...and next boot is KO. I have tried all the magic with SPI overlay on RADXA OS, in lsblk there is zram, mmcblk1 with three partitions and nvme - but when updating SPI BOOT, there is following error: radxa@rock-5c:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mmcblk1 179:0 0 29G 0 disk ├─mmcblk1p1 179:1 0 16M 0 part /config ├─mmcblk1p2 179:2 0 300M 0 part /boot/efi └─mmcblk1p3 179:3 0 28.6G 0 part / zram0 253:0 0 7.8G 0 disk [SWAP] nvme0n1 259:0 0 953.9G 0 disk └─nvme0n1p1 259:1 0 944.3G 0 part radxa@rock-5c:~$ sudo rsetup [sudo] password for radxa: /usr/lib/u-boot/rock-5c-spi/setup.sh: line 3: ERROR_REQUIRE_FILE: readonly variable /usr/lib/u-boot/rock-5c-spi/setup.sh: line 4: ERROR_ILLEGAL_PARAMETERS: readonly variable /usr/lib/u-boot/rock-5c-spi/setup.sh: line 5: ERROR_REQUIRE_TARGET: readonly variable /dev/mtd0 is missing. also kernel is weird... radxa@rock-5c:~$ uname -r 6.1.84-8-rk2410 I'm maybe too carefull, but I know, I wouldn't be able to fix broken bootloader:-] So please help, if you can Tried both vendor and current kernels (6.18 and 6.1) but results are the same Regards Jan
Orange Pi 5 no HDMI
Well, have same problem, OPI 5 always starts with HDMI disabled. I'm enabling it with: echo on > /sys/class/drm/card0-HDMI/status just chceck the path, if it's same for you (writing from memory, might be wrong)...but first part is solid (echo on > /sys/class/drm/) And I think it's from the moment, I have replaced monitor from pure HDMI to DP/HDMI one...so there might be problem with detection of monitor by OPI5. But if anyone has a permanent solution, please post
slmq
