- Build current and edge releases on Odroid C1
@torz77 Without logs and diagnostic information it's hard to tell what is going on because what you're saying is the equivalent of "it doesn't work" Nonetheless I had the same symptoms when my SDcard was dying (bad sectors here and there). The kernel and network layer was loaded in to memory OK, so pings would work, but ssh calls upon extra binaries and files from the SD card and I was getting I/O errors, hence would result in SSH dying which is the connection refused the client sees. I had to connect mine to a display for the duration of a diagnostic session but thankfully it was easily reproducible so the error glared out. A replacement SD card got me there.
OK my experimentation has continued and I've discovered an interesting problem. USB doesn't work. I've flashed a vanilla Hardkernel image (ubuntu-20.04-3.10-minimal-odroid-c1-20200519.img.xz) and all is well, ruling out any hardware issue. lsusb shows the root controller hub on the custom Bookworm armbian build: Armbian-unofficial_25.02.0-trunk_Odroidc1_bookworm_current_6.6.43_minimal.img. I've plugged in a webcam and a flash drive, non of which appear in lsusb nor generate any stimulus within dmesg. I've since done git pulls on the repo so I can't tell exactly which git rev this was built on or from; I'd suggest it dates from my last post, Dec 17 2024. lsusb under the Hardkernel image shows the controller hubs as well as the listing in lsusb, plus dmesg. All seems well. Any one else experience this?
Tomasz Grzegurzko
