- Build current and edge releases on Odroid C1
Odroid C2 and HC4 soft-reset fix for latest Armbian (24.08)
Thanks to g4751 for doing the tests for Odroid-HC4. The tests for the Odroid-C2 were performed by myself. Tests were performed on Armbian 24.08 Official releases. Fix is to add a section to the DTB to enable a recently (last year) added kernel driver "meson64-reboot" that is an updated version of the "odroid-reboot" in older kernels. For Odroid-C2: - save your existing DTB - use DTC to convert DTB->DTS - modify the DTS with the code below - use DTC to convert DTS->DTB - reboot (will fail because new DTB not loaded yet) - POR (will now load the new DTB) - log-in - reboot should now work. For Odroid-HC4: - save your existing DTB - use DTC to convert DTB->DTS - modify the DTS with the code below - use DTC to convert DTS->DTB - reboot (will fail because new DTB not loaded yet) - POR (will now load the new DTB) - log-in - reboot should now work. Notes: - As far as I know, only the Odroid -C4 has an Armbian patch to do the above automatically for each release. - For others, updates may overwrite the DTB and you'll need to perform this fix again. In theory, DTB changes are fairly rare.
- If you have an Odroid C2 (and possibly others) that fails to reboot - here's your fix.
1) It would be good if you could reload an earlier version of Armbian (incorporating the fixes for gpios = <0x44 0x06 0x06> and then with gpios = <0x44 0x06 0x03>) until the soft-reset works. 2) Using a second computer with a terminal program you could capture a text version of the boot log. If you're not comfortable with that then nvm.
EDIT: After discussion with a few users, to avoid the issue of having this modification wiped out by a future DTB update and create the unfortunate scenario where the /boot/armbianEnv.txt requests to load a DTB which no longer exists, it's a lot simpler to overwrite the original DTB thus keeping the naming identical. If the DTB gets overwritten by an update then the reboot functionality may just revert to the no-reboot behavior until the fix is re-applied to the newer DTB. The problem lies in the SDCARD signals not being in the right state for a reboot. To solve this we will de-compile the DTB in /boot/dtb/amlogic/meson-gxbb-odroidc2.dtb to create a source version (DTS), modify it, and re-generate the new DTB with the same name. The board will need to be re-started to load-in the new DTB after which the following reboots should be automatic. 1) Back-Up everything - if the DTB is somehow not at the right place or the 1 character editing goings wrong there's probably a way to recover from the u-boot console but I haven't explored that. 2) Go To: /boot/dtb/amlogic ls -al (you will see your meson-gxbb-odroidc2.dtb which is hardcoded in the bootloader as the DTB to load) 3) Convert to a source file by doing: dtc -I dtb -O dts -o meson-gxbb-odroidc2.dts meson-gxbb-odroidc2.dtb (you will now have a new DT Source file meson-gxbb-odroidc2.dts) 4) Edit: vi meson-gxbb-odroidc2.dts find the entry TF_IO look for the line gpios = <0x38 0x03 0x00>; the hex number in red is to be changed from 0x00 to 0x06 (what this does is set the SDCARD in a mode to be ready to boot by allowing the resistor pull-down to enable the VDDIO Regulator to go to 3.3V which is the proper boot voltage) save, exit 5) Return the DTS file to a new DTB file (which is the only format accepted by the bootloader). We will copy the original DTB to another name and overwrite the original: cp meson-gxbb-odroidc2.dtb meson-gxbb-odroidc2-ORIGINAL.dtb dtc -O dtb -o meson-gxbb-odroidc2.dtb meson-gxbb-odroidc2.dts many warnings will be emitted, they can be safely ignored 6) No changes need be performed to /boot/armbianEnv.txt (ie. the 'fdtfile=' directive) as the DTB file with the expected naming will be loaded except now it has the TF_IO mod. 7) Now you will reboot - THIS WILL SHUTDOWN BUT WILL NOT REBOOT AUTOMATICALLY BECAUSE THE NEW DTB IS NOT ACTIVE YET. 8 ) Do a Power Reset to bring-up the board and load the new DTB. 9) Now if you do a reboot you will finally get a proper reboot sequence.
Javelin
