DroZDI
  1. I gave up with that now... I installed Ubuntu and it works Maybe I would come back to Armbian later...
  2. For me all Armbian images stop after that: DDR Version V1.08 20220617 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB Manufacturer ID:0x6 CH0 RX Vref:30.7%, TX Vref:21.8%,20.8% CH1 RX Vref:31.7%, TX Vref:23.8%,22.8% CH2 RX Vref:30.7%, TX Vref:21.8%,20.8% CH3 RX Vref:31.7%, TX Vref:21.8%,21.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Jun 01 2023 - 11:41:40) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(806278dba1...) + OK ## Checking uboot 0x00200000 ... sha256(cc23d8931f...) + OK ## Checking fdt 0x00311f08 ... sha256(d2dda3ef7c...) + OK ## Checking atf-2 0x000f0000 ... sha256(c00c7fd75b...) + OK ## Checking atf-3 0xff100000 ... sha256(71c3a5841b...) + OK ## Checking atf-4 0xff001000 ... sha256(2301cf73be...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 920.859 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-405-gb52c2eadd:derrick.huang NOTICE: BL31: Built : 11:23:47, Aug 15 2022 INFO: spec: 0x1 INFO: ext 32k is valid
  3. yes I unpack and write SD card also I tried without unpacking results the same
  4. this is not video issue... I attached with serial port to see... it is not loading image I found something here: https://sd-card-images.johang.se/boards/orangepi_5_plus.html like a bootloader is needed?
  5. I lost whole day yesterday to try boot with new images from Armbian download page - kernel 6.1 / kernel 6.8 bookworm/trixi and none boots... If I take Ubuntu or Debian image I have no problem to boot from. Do you have the same?
  6. true... for be200 working we need the kernel in version at lest 6.1
