AndrewCo
  1. it doesn't work even on a newest kernel: user@rockpro64:~$ uname -r 6.6.16-current-rockchip64 user@rockpro64:~$ sudo cat /etc/armbian-release |egrep -i "version|branch|board" BOARD=rockpro64 BOARD_NAME="RockPro 64" BOARDFAMILY=rockchip64 BOARD_TYPE=conf VERSION=24.2.1 BRANCH=current user@rockpro64:~$ sudo lspci -v -s 01:00.0 01:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9230 PCIe 2.0 x2 4-port SATA 6 Gb/s RAID Controller (rev 11) (prog-if 01 [AHCI 1.0]) Subsystem: Marvell Technology Group Ltd. 88SE9230 PCIe 2.0 x2 4-port SATA 6 Gb/s RAID Controller Flags: fast devsel, IRQ 59 Memory at fa040000 (32-bit, non-prefetchable) [size=2K] Expansion ROM at fa000000 [size=256K] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit- Capabilities: [70] Express Legacy Endpoint, MSI 00 Capabilities: [e0] SATA HBA v0.0 Capabilities: [100] Advanced Error Reporting After initiating it appeared with the disks connected: user@rockpro64:~$ echo "0000:01:00.0" | sudo tee /sys/bus/pci/drivers/ahci/bind 0000:01:00.0 @rockpro64:~$ sudo lspci -v -s 01:00.0 01:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9230 PCIe 2.0 x2 4-port SATA 6 Gb/s RAID Controller (rev 11) (prog-if 01 [AHCI 1.0]) Subsystem: Marvell Technology Group Ltd. 88SE9230 PCIe 2.0 x2 4-port SATA 6 Gb/s RAID Controller Flags: bus master, fast devsel, latency 0, IRQ 95 Memory at fa040000 (32-bit, non-prefetchable) [size=2K] Expansion ROM at fa000000 [size=256K] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [70] Express Legacy Endpoint, MSI 00 Capabilities: [e0] SATA HBA v0.0 Capabilities: [100] Advanced Error Reporting Kernel driver in use: ahci Thus the workaround with udev rules still needs to be applied. https://forum.pine64.org/showthread.php?tid=7453 was helpful
