fensoft
  1. "no". but don't trust anybody, that was the point. you don't know me. moreover, you probably already have on your stock firmware, like a lot of chinese android tvbox
  2. you clearly didn't get the point
  3. i've updated the image to include info on screen like IP / cpu usage / ram usage (in %) any software can write to /tmp/screen to change content you can download here
  4. for thoses who want to install sd to emmc, use this script (remove the line about haos near the end)
  5. everything is in the main post
  6. I already said i cant and dont want to. Anyway, in the meantime, I tried to port to latest version of armbian and didn't managed to finish because of some issues with devicetree. I gave up because no time for the moment (and found nomore fun in debugging for something i dont need) Final goal was to port haos to it anyway. Armbian was only a step for me.
  7. 100mbps is enough for all my projects. if not, there are some usb3 gigabit adapters
  8. i never connected anything on the hdmi port, sorry. i'm using 10 of them for different projects, some are used 24/7/365 for home assistant or video encoding
  9. you don't have to. it's already trying to boot by default to sd. you can either try to install the same android as me, change the sdcard or plug an usb2serial cable @ 1.5Mbauds to check uboot logs.
  10. I have uploaded an updated version here. Also, for thoses who want to use internal emmc (boot without sdcard), you can run this script: You can reinstall android using this, connecting DQ08's usb2 port (using a male-male usb cable) to the computer while pushing the button in the AV connector. Then, in the app (extracted to c:\), choose firmware / firmware.bin / restore / run.
  11. I have the original software from vendor if needed. But, as I dont trust internal emmc, I never tried.
  12. If I understand well, boot loader is at the begining of the emmc. Doing armbian-install will probably ends with system not booting anymore.
  13. Toxicity level over 9000, you better keep it for yourself next time. About PR, I can't and dont want. It's not my patch. Feel free to do it yourself if it's so important.
  14. do you want me to remove all binaries ? about tvbox in the genuine armbian, i'm pretty sure that i've read somewhere armbian would not support them
