Atomic firmware upgrade
@SteeMan this is supposed to be a remote and unattended system, so I would like to control the updates very carefully in order to avoid breaking anything using apt (it happens sometimes...). I know this is quite a challenge, but frameworks like rauc and swupdate are purposely designed to guarantee atomically and safe system upgrades. I would disable apt unattended system upgrades, protect the rootfs using overlayroot and possibly use rauc to upgrade the systems using a full image. I am also evaluating tools like systemd-repart that may repartition the storage (eMMC, or SD) live.
Hi all, has anyone ever tried to use an atomic firmware upgrade system like rauc or swupdate? https://rauc.readthedocs.io/en/latest/ https://sbabic.github.io/swupdate/swupdate.html I am playing with rauc, in order to do that I have to customize the partitioning of the SD/eMMC: - root1 (4GB) - root2 (4GB) - data (8GB, or remaining space) Can someone suggest how to customize partitioning in such way? I played around setting USE_HOOK_FOR_PARTITION=yes, and hooking the create_partition_table but had no luck. Any hint? Thanks in advance! Andrea
- kernel source modification & build without doing kernel-patch process
- Is it still possible to build just the kernel?
- Allwinner H616: Flash eMMC via USB
- Build fails while compiling ATF ("cannot find cr")
- OrangePi Zero 2 H616: PWM support
- Error executing partprobe during build
Despite the fact the problem is very similar, I am not using WSL2 to build. I am using a Ubuntu VM : Ubuntu 22.04.3 LTS (GNU/Linux 5.15.0-94-generic x86_64) andrea@armbian:~$ uname -a Linux armbian 5.15.0-94-generic #104-Ubuntu SMP Tue Jan 9 15:25:40 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux User adeepn confirms that it happens also on Ubuntu w/kernel 5.15. I will try to upgrade to 6.1 and let you know. Thanks for the hint
Andrea
