Jens J.
  1. I think this is @Igor's signing key aml-s9xx-box:~:# gpg --keyserver keyserver.ubuntu.com --recv-keys 93D6889F9F0E78D5 gpg: key 93D6889F9F0E78D5: 1 duplicate signature removed gpg: key 93D6889F9F0E78D5: public key "Igor Pecovnik <igor@armbian.com>" imported gpg: Total number processed: 1 gpg: imported: 1
  2. also getting this on latest community builds of aml-s9xx-box at https://www.armbian.com/amlogic-s9xx-tv-box/ e.g. https://dl.armbian.com/aml-s9xx-box/Bookworm_current_xfce ``` PRETTY_NAME="Armbian_community 25.8.0-trunk.90 bookworm" ``` wondering if something is broken or missing on the build
  3. So when writing the u-boot to SD card, you need to follow a special process to "skip" over some bytes to prevent trashing the partition table. see https://www.cnx-software.com/2016/11/19/how-to-create-a-bootable-recovery-sd-card-for-amlogic-tv-boxes/ TLDR, something like: sudo umount /dev/sdX* sudo dd if=aml_sdc_burn.UBOOT of=/dev/sdX bs=1 count=442 sudo dd if=aml_sdc_burn.UBOOT of=/dev/sdX seek=1 skip=1 bs=512 sync
  4. Have you tried `/boot/dtb/amlogic/meson-gxm-mini-m8s-pro.dtb` ? What is wifi chip? Is it LTM8830? If so this is QCA9377 clone, and this dtb should be fully working.
  5. Hi there, trying to iterate on making small changes to a kernel driver module, and using armbian to help build the kernel (cross-compiling off the device). I'm aware of kernel-patch mode, but for making small changes, compiling, and iterating like this over and over, making and then putting patches into place on each cycle is quite cumbersome. Is there some way to tell armbian build _not_ to update the kernel, i.e. let me build with dirty tree, as I'm in a dev cycle? I just want to edit something in my local kernel tree, then build the kernel, and repeat
