PookyFan
  1. Sorry for late response, I had a long break with my Armbian image creation attempts. I explained it briefly here, as it seems this user had similar problem:
  2. Digging this topic out since I am working on Armbian config for very similar CPU (Allwinner T113-S3) which is supposedly compatible. I came across this thread while looking for info about R528 which, in addition to being separate CPU model, seems to be umbrella term for all T113 family CPUs (at least from the PoV of U-boot). You can create your own board config by adding file in config/boards directory, similar to some of already existing (for example any other Allwinner based board). Since, as I already mentioned, your board's CPU should be compatible with T113-S3, you may try using DTS for a T113 based board - MangoPi MQ - by adding following records to your board's config file: BOARDFAMILY="sun8i" BOOT_FDT_FILE="sun8i-t113s-mangopi-mq-r-t113.dtb" BOOTCONFIG="mangopi_mq_r_defconfig" No promises it would work out of the box (I suppose your board may not have all external peripherals from MangoPi, like WiFi module, so no idea what would happen if it turns out they can't be initialized properly), but I guess it's a good starting point. Ideally you should create your own device tree for your board (looks like there is none in Linux), but using one for MangoPi could get you started somehow. If your board does have LCD connector, your LCD will not work, I can tell you that much now. You need to create device tree patch to add specific panel you're going to use with your board to enable it for Linux. U-boot is another story, I am currently working on adding LCD support in U-boot for my board, but if you're okay with display being usable only after Linux boots, then you should be good with just adding specific panel to Linux DT.
  3. Not sure if this should go in this section, but since my problem is about non-supported board, then I guess... I found out about Armbian only recently and decided to give it a try for my T113-S3 based board I bought on Aliexpress. It looks like it's some kind of a MangoPi MQ clone, at least judging by schematics. I managed to create a new configuration for my board, together with required U-Boot patches. I built two images, for "current" and "edge" kernel. For some time I was under impression that Linux doesn't boot at all (serial console output was stuck at "Starting kernel ..."), until I added earlycon=on to armbianEnv.txt. Then I finally saw some output from kernel being booted. But at some point it looks like it's stuck, or just doesn't show login prompt? It's hard to say. Logs from the "current" image look like this: Logs from "edge" image don't even come to that point: What could be wrong, or what could I be forgetting to set? I'd be grateful for any help, especially knowing that this board is not either officially nor unofficially supported. EDIT: I might have not been precise enough, I'm trying to login through serial console since I can't connect any screen to my board at the moment. I guess the lack of login prompt might be connected to this: "Warning: unable to open an initial console". It is connected with /dev/console device file, which might be needed for the serial console to work in userspace. I tried to track the warning down by adding some debug logs into kernel code and what I confirmed: - /dev/console device is created successfully - at the same time, while opening it (from within the kernel), open operation fails with ENODEV error What's going on?
