RuDy_74
  1. Hello all, I installed armbian on my TV box. It work correctly (I installed home assistant and It work properly). however, I have a problem with bluetooth. It doesn't work. I do some investigation : install the bluetooth support with apt-get update && apt-get install bluetooth check if this work with : service bluetooth status and it return bluetooth is running I try to connect device with bluetoothctl and it not working. It return No default controller available version : v25.02.0 for Aml.S912 running Armbian Linux 6.6.67-merry-christmas Packages: Debian stable (bullseye) I use this dtb file : meson-gxm-q201.dtb. I tried Different dtb file but it was not possible to install armbian. (I didn't try all files...) TVBox : Bqeel K12 (I opened the box and it's write on mother card Mini M8S pro C (S912)) wirless module is Fn-link 8223A-SR
  2. Hello all, I'm new member on this forum and I want became new user of armbian to install Home Assistant on my box. My box is a Bqeel K12 but i opened box and I see a label on the mother board where is write Mini M8S pro C. So I try to install armbian debian. I used this version "Armbian_23.5.1_Uefi-arm64_bookworm_current_6.1.30_cinnamon_desktop.img" I followed this topic to find the good dbt file : https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus/ I found differents dbt files which look like working properly (I have the desktop, I can navigate, open application...) BUT at each time is not possible to acces to internet (with Wifi or lan). I try to configure manually the connection with the tool available on desktop but is not working. a precision : before to install armbian, I totally remove android. Do you think that can be the root cause ? Thanks in advance
