Gxbaby "P200" tv box (MXQ PRO) does not boot
Thank you for your answer
Update : When i use the latest armbian version ("Noble Numbat") + the meson-gxbb-beelink-mini-mx.dtb and u-boot-s905 as u-boot.ext, all the peripherals worked fine (including Wifi and ethernet). But now I'm trying to launch the installer from armbian-install command but I got an error : The [ :meson-gxbb: ] series in the [ /etc/model_database.conf ] file is empty and does not support write to eMMC ! So is there any chance of finding a linux version that can be installed on this box? (even if it's an old version of libreelec, openwrt, debian or whatever) because with Android 5 the box is unusable and Playstore no longer works.
Hi, I have an old Android 6 TV box that is slow (1GB ram), i think it's an S905 because it's the only kernel that can boot and its mainboard is a "gxbb p200" as I see on Aida64 : I just tried to boot the Armbian_community_24.8.0-trunk.139_Aml-s9xx-box_bookworm_current_6.6.33_minimal.img I flashed it on a 16GB microSD card on an SD card adapter. Then I added the line : FDT /dtb/amlogic/meson-gxbb-p200.dtb just after the lines label Armbian_community kernel /Image initrd /uInitrd fdtdir /dtb/ into extlinux.conf file. and then I renamed the u-boot-s905 file to u-boot.ext But the system still hangs at startup because it can't find the ROOT partition : I think it's because the kernel can't find the SD card reader, as an error appears: mmc0: error -110 whilst initialising SD card I checked the partitions on gnome-disk utility and there are fine : Here is the box : The only distro that worked was Libreelec but the Wi-Fi does not accept the password. (it always says "invalid credentials) is it a box that's too old to be saved?
