Alexander Buzin
  1. The image is coped on SD using: sudo dd if=Armbian_23.8.2_Orangepi3b_bookworm_edge_6.5.2.img of=/dev/sda bs=1M status=progress The initial startup is fine (booting, setting of root password, user name/password, wifi setup as well as locales/tzdata). We obtain a system with working internet connection, it can be upgraded using apt etc. However, after reboot wifi fails (the first impression was that we installed something wrong during upgrade phase. However, the sequence: fresh sdcard boot, armbian initialization, reboot (through the reboot command, not a button)) still results in the following: 1708 [ 6.944457] WCN_ERR: read marlin3E chip id fail, ret=-110 1709 [ 6.944506] WCN: marlin_scan_finish! 1710 [ 6.944515] sdiohal:probe ok 1711 [ 6.944740] sdiohal:scan end! 1712 [ 6.944756] WCN: then marlin start to download 1713 [ 6.944802] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! 1714 [ 6.949062] kworker/0:3: vmalloc error: size 18446744073709551615, exceeds total pages, mode:0xcc0(GFP_KERNEL), nodemask=(null),cpuset=/,mems_allowed=0 1715 [ 6.949147] CPU: 0 PID: 73 Comm: kworker/0:3 Not tainted 6.5.2-edge-rockchip64 #1 1716 [ 6.949162] Hardware name: Rockchip RK3566 OPi 3B (DT) 1717 [ 6.949173] Workqueue: events pre_btwifi_download_sdio 1718 [ 6.949205] Call trace: 1719 [ 6.949212] dump_backtrace+0x94/0x114 1720 [ 6.949230] show_stack+0x18/0x24 1721 [ 6.949241] dump_stack_lvl+0x48/0x60 1722 [ 6.949260] dump_stack+0x18/0x24 1723 [ 6.949273] warn_alloc+0x118/0x1b0 1724 [ 6.949290] __vmalloc_node_range+0x724/0x770 1725 [ 6.949302] vmalloc+0x5c/0x6c 1726 [ 6.949312] load_firmware_data_path+0x64/0x220 1727 [ 6.949327] pre_btwifi_download_sdio+0xe8/0x182c 1728 [ 6.949341] process_one_work+0x214/0x4a0 1729 [ 6.949355] worker_thread+0x6c/0x430 1730 [ 6.949366] kthread+0x104/0x108 1731 [ 6.949377] ret_from_fork+0x10/0x20 Full 'armbianmonitor -U' output is provided here https://pastebin.com/87nvKDsN I hope that somebody might get an idea what's happening inside... Kind regards, al P.S. this result doesn't depend on to which wifi network I'm connected (2.4GHz/5GHz).
