Why armbian-install can brick the TV-box?
You need to rebuild the U-Boot with this patch to disable the read limit. Then write the patched U-Boot to an SD-card with Armbian and boot into loader mode with the card inserted. It's also possible to patch the binary code of the original U-Boot from EMMC, but it's long to explain.
This comment describes a recovery method without shorting the pins. I haven't tried this method.
Ambian TV box rk3528
Please give at least compiled dtb's for your TV-boxes. I tried to rebuild the image for legacy kernel with the latest Armbian-build, and now HDMI doesn't work at all. Update: The problem seems to be that the TV boxes use gmac0, the driver of which is RK630_PHY, and this driver is not enabled in linux-rk35xx-vendor.config. compatible = "ethernet-phy-id0044.1400", "ethernet-phy-ieee802.3-c22"; #define RK630_PHY_ID 0x00441400 Update2: Still doesn't work, even with this driver (preinstalled Android uses this driver).
Is it like this in the dts file or did you do it another way? - ethernet0 = &gmac1; + ethernet0 = &gmac0; &gmac0 { - status = "disabled"; + status = "okay"; }; I tried this in rk3528-mangopi-m28k.dts but no luck.
Armbian now supports MangoPI M28K (BOARD=mangopi-m28k BRANCH=vendor), which uses kernel 6.1. HDMI-audio works with dtb from MangoPI. But now Ethernet port doesn't work, neither with this dtb, nor with what I did for the old kernel.
HELP- DQ08 RK3528 4Go RAM 64go SSD can't boot with multitool (with photos)
Most likely this: But did you notice that this is a "minimal" build? You need to install desktop packages if you need a desktop.
No. I don't know what you're talking about. I didn't make any changes to armbi_root, whatever this is. Sounds like a fake flash media that reports more capacity than it actually has.
There's an unsolved problem with the RK3528 video driver, it is necessary to connect an HDMI cable or turn on the monitor a few seconds after turning on the TV-box. Also, at the first boot there is nothing on screen, because first you need to enter the Armbian configuration script using ssh (over a LAN connection).
With BRCMFMAC driver or BCMDHD driver? Or did it work with both drivers?
The preinstalled Android on the RK3528 uses the BCMDHD driver, which is located in the "drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd" directory. As you can see, Rockchip has its own driver for Broadcom. Which is missing some patches. I'm pretty sure that these patches must include this line: {BCM4335_CHIP_ID, 1, DONT_CARE, "bcm4335b0_ag", "bcm4335"}, There's number of repositories on Github that have this line (link). But they have no history of driver updates.
jpegqs
