rtl8812au failing on 6.6.45-current-bcm2712 (24.8.2)
[ 2.336390] ------------[ cut here ]------------ [ 2.336395] WARNING: CPU: 1 PID: 317 at drivers/net/wireless/rtl8812au/core/rtw_odm.c:62 rtw_odm_init_ic_type+0x64/0x88 [88XXau] [ 2.336482] Modules linked in: rpivid_hevc(C) drm_kms_helper brcmfmac 88XXau(+) hci_uart pisp_be brcmutil btbcm snd_soc_core v4l2_mem2mem bluetooth cfg80211 videobuf2_dma_contig snd_compress videobuf2_memops snd_pcm_dmaengine ecdh_generic videobuf2_v4l2 snd_pcm rfkill videodev snd_timer ecc snd videobuf2_common v3d mc dw_axi_dmac_platform raspberrypi_hwmon gpu_sched pwm_brcmstb rp1_adc aes_ce_blk pwm_rp1 drm_shmem_helper aes_ce_cipher polyval_ce polyval_generic ghash_ce sha2_ce sha256_arm64 sha1_ce pwm_fan uio_pdrv_genirq nvmem_rmem uio sch_fq_codel drm i2c_dev drm_panel_orientation_quirks backlight fuse ipv6 macb spidev dwc3 roles phylink i2c_designware_platform i2c_designware_core gpio_brcmstb gpio_generic i2c_brcmstb spi_bcm2835 gpio_keys reset_brcmstb [ 2.336543] CPU: 1 PID: 317 Comm: systemd-udevd Tainted: G C 6.6.45-current-bcm2712 #1 [ 2.336546] Hardware name: Raspberry Pi 5 Model B Rev 1.0 (DT) [ 2.336547] pstate: 80400009 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.336550] pc : rtw_odm_init_ic_type+0x64/0x88 [88XXau] [ 2.336585] lr : rtw_hal_read_chip_version+0x2c/0x48 [88XXau] [ 2.336619] sp : ffff8000810f3770 [ 2.336620] x29: ffff8000810f3770 x28: 0000000000000000 x27: 00000000ffffffed [ 2.336624] x26: ffffa0003a271080 x25: ffff000100ca0000 x24: ffffa0003a271010 [ 2.336628] x23: ffffa0003a2717c8 x22: ffff000104e6e000 x21: ffff000101465000 [ 2.336631] x20: 0000000000000001 x19: ffff8000810fd000 x18: ffffffffffffffff [ 2.336634] x17: ffffa0003a2104c0 x16: ffffa00084d2fd18 x15: ffff8001010f36f0 [ 2.336637] x14: 0000000000000001 x13: ffff8000810f36f8 x12: ffffa00085618b98 [ 2.336640] x11: 0000000000000002 x10: 000000000000000a x9 : ffffa0003a1e9754 [ 2.336644] x8 : 000000000000000a x7 : 0000000000000004 x6 : 0000000000000029 [ 2.336647] x5 : ffff8000810f36fb x4 : 0000000000000002 x3 : 0000000000000000 [ 2.336650] x2 : 0000000000000000 x1 : 0000000000000004 x0 : ffff8000815a0ed0 [ 2.336653] Call trace: [ 2.336654] rtw_odm_init_ic_type+0x64/0x88 [88XXau] [ 2.336688] rtw_hal_read_chip_version+0x2c/0x48 [88XXau] [ 2.336721] rtw_usb_primary_adapter_init+0x130/0x8a8 [88XXau] [ 2.336754] rtw_usb_primary_adapter_init+0x384/0x8a8 [88XXau] [ 2.336786] usb_probe_interface+0xdc/0x298 [ 2.336791] really_probe+0x150/0x2c0 [ 2.336795] __driver_probe_device+0x80/0x140 [ 2.336797] driver_probe_device+0x44/0x170 [ 2.336800] __driver_attach+0x9c/0x1b0 [ 2.336802] bus_for_each_dev+0x7c/0xe8 [ 2.336804] driver_attach+0x2c/0x40 [ 2.336806] bus_add_driver+0xec/0x218 [ 2.336808] driver_register+0x68/0x138 [ 2.336810] usb_register_driver+0x84/0x180 [ 2.336814] init_module+0x60/0xff8 [88XXau] [ 2.336848] do_one_initcall+0x4c/0x2a0 [ 2.336851] do_init_module+0x60/0x218 [ 2.336856] load_module+0x1c10/0x1d38 [ 2.336858] init_module_from_file+0x8c/0xd8 [ 2.336861] __arm64_sys_finit_module+0x1c0/0x290 [ 2.336865] invoke_syscall+0x50/0x128 [ 2.336869] el0_svc_common.constprop.0+0xd0/0xf8 [ 2.336872] do_el0_svc+0x28/0x40 [ 2.336875] el0_svc+0x48/0x108 [ 2.336879] el0t_64_sync_handler+0x13c/0x158 [ 2.336881] el0t_64_sync+0x190/0x198 [ 2.336884] ---[ end trace 0000000000000000 ]--- [ 2.415424] usb 1-2: 88XXau b0:19:21:6c:6d:18 hw_info[107] [ 2.416755] ------------[ cut here ]------------ [ 2.416769] WARNING: CPU: 1 PID: 317 at drivers/net/wireless/rtl8812au/core/rtw_odm.c:62 rtw_odm_init_ic_type+0x64/0x88 [88XXau] [ 2.416936] Modules linked in: rpivid_hevc(C) drm_kms_helper brcmfmac 88XXau(+) hci_uart pisp_be brcmutil btbcm snd_soc_core v4l2_mem2mem bluetooth cfg80211 videobuf2_dma_contig snd_compress videobuf2_memops snd_pcm_dmaengine ecdh_generic videobuf2_v4l2 snd_pcm rfkill videodev snd_timer ecc snd videobuf2_common v3d mc dw_axi_dmac_platform raspberrypi_hwmon gpu_sched pwm_brcmstb rp1_adc aes_ce_blk pwm_rp1 drm_shmem_helper aes_ce_cipher polyval_ce polyval_generic ghash_ce sha2_ce sha256_arm64 sha1_ce pwm_fan uio_pdrv_genirq nvmem_rmem uio sch_fq_codel drm i2c_dev drm_panel_orientation_quirks backlight fuse ipv6 macb spidev dwc3 roles phylink i2c_designware_platform i2c_designware_core gpio_brcmstb gpio_generic i2c_brcmstb spi_bcm2835 gpio_keys reset_brcmstb [ 2.417033] CPU: 1 PID: 317 Comm: systemd-udevd Tainted: G WC 6.6.45-current-bcm2712 #1 [ 2.417039] Hardware name: Raspberry Pi 5 Model B Rev 1.0 (DT) [ 2.417042] pstate: 80400009 (Nzcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.417046] pc : rtw_odm_init_ic_type+0x64/0x88 [88XXau] [ 2.417093] lr : Init_ODM_ComInfo+0x48/0x540 [88XXau] [ 2.417137] sp : ffff8000810f3690 [ 2.417138] x29: ffff8000810f3690 x28: 0000000000000000 x27: 00000000ffffffed [ 2.417143] x26: ffff8000815ac000 x25: ffff000100ca0000 x24: ffff000101465000 [ 2.417148] x23: 00000000ffffffff x22: ffff8000810fd000 x21: ffff80008159d000 [ 2.417152] x20: ffff8000815a0ed0 x19: ffff80008159d000 x18: ffffffffffffffff [ 2.417156] x17: 0000000000000000 x16: ffffa00084d0bc00 x15: 0000000000000068 [ 2.417161] x14: 0000000000003ed0 x13: 0000000000000000 x12: ffffa00085811b60 [ 2.417165] x11: ffff800080000000 x10: ffff0001fef3fe00 x9 : ffffa0003a2017d0 [ 2.417169] x8 : ffff800081100790 x7 : ffffffffffffffff x6 : 000000000000003f [ 2.417174] x5 : 0000000000000040 x4 : 0000000000000008 x3 : 000000000000000c [ 2.417178] x2 : 0000000000000000 x1 : 0000000000000004 x0 : ffff8000815a0ed0 [ 2.417183] Call trace: [ 2.417184] rtw_odm_init_ic_type+0x64/0x88 [88XXau] [ 2.417228] Init_ODM_ComInfo+0x48/0x540 [88XXau] [ 2.417270] rtl8812_init_dm_priv+0x58/0xc8 [88XXau] [ 2.417313] rtw_hal_dm_init+0x28/0x58 [88XXau] [ 2.417356] rtw_init_drv_sw+0x228/0x258 [88XXau] [ 2.417399] rtw_usb_primary_adapter_init+0x158/0x8a8 [88XXau] [ 2.417442] rtw_usb_primary_adapter_init+0x384/0x8a8 [88XXau] [ 2.417484] usb_probe_interface+0xdc/0x298 [ 2.417491] really_probe+0x150/0x2c0 [ 2.417495] __driver_probe_device+0x80/0x140 [ 2.417499] driver_probe_device+0x44/0x170 [ 2.417502] __driver_attach+0x9c/0x1b0 [ 2.417506] bus_for_each_dev+0x7c/0xe8 [ 2.417508] driver_attach+0x2c/0x40 [ 2.417512] bus_add_driver+0xec/0x218 [ 2.417514] driver_register+0x68/0x138 [ 2.417517] usb_register_driver+0x84/0x180 [ 2.417524] init_module+0x60/0xff8 [88XXau] [ 2.417567] do_one_initcall+0x4c/0x2a0 [ 2.417572] do_init_module+0x60/0x218 [ 2.417577] load_module+0x1c10/0x1d38 [ 2.417580] init_module_from_file+0x8c/0xd8 [ 2.417584] __arm64_sys_finit_module+0x1c0/0x290 [ 2.417588] invoke_syscall+0x50/0x128 [ 2.417593] el0_svc_common.constprop.0+0xd0/0xf8 [ 2.417597] do_el0_svc+0x28/0x40 [ 2.417601] el0_svc+0x48/0x108 [ 2.417605] el0t_64_sync_handler+0x13c/0x158 [ 2.417608] el0t_64_sync+0x190/0x198 [ 2.417611] ---[ end trace 0000000000000000 ]--- Anyone seen these? WiFi is not working. Any hints for solution other than downgrade to 6.6.31 we already do? Downgrade instruction: sudo apt install linux-image-current-bcm2712=24.5.1 linux-headers-current-bcm2712=24.5.1 Same symptoms described in https://github.com/aircrack-ng/rtl8812au/issues/1155, they seem to find working patch. Is there any RPi5 maintainer here? Another related: https://github.com/aircrack-ng/rtl8812au/issues/1169
- Device Tree override options not working on Armbian
Missing libcamera
Y? `python3-libcamera` would be abstraction over full libcamera, so we rather talking about: https://packages.ubuntu.com/jammy/libcamera0 https://packages.ubuntu.com/jammy/libcamera-dev
I have a `.dts` file built on Raspberry Pi OS for Raspberry Pi 5, that has following section allowing to provide options to both userspace `dtoverlay` and as parameters in `/boot/firmware/config.txt`: __overrides__ { rotation = <&cam_node>,"rotation:0"; orientation = <&cam_node>,"orientation:0"; media-controller = <&csi>,"brcm,media-controller?"; cam0 = <&i2c_frag>, "target:0=",<&i2c_csi_dsi0>, <&csi_frag>, "target:0=",<&csi0>, <&cam_node>, "VIN-supply:0=",<&cam0_reg>; }; Then following use: sudo dtoverlay -v ovaone cam0=on Overrides proper fields in the overlay fragments on Raspberry Pi OS, but despite overrides being recognized they don't seem to apply and camera driver is starting with wrong I²C attached. The same problem with with `dtparam` in `config.txt` as it works on Raspberry Pi OS, but not on Armbian (I actually wonder how other `dtparam`s work on Armbian). I have to patch the `.dts` file prior to compilation with I²C references replaced for `fragment@100` and `fragment@101`. Our `.dts` is just a little stripped version of original for imx219 camera. Suggestions or explanations welcome.
Armbian's DEB/APT repositories empty
@Werner you don't keep snapshots like Aptly does???
About 2h ago most of APT repositories (probably in the mirror) became empty and I can't install packages anymore (both my desktop and CI runner): http://armbian.tnahosting.net/apt/dists/jammy/ is totally empty and most other releases as well.
Michał Fita
