Horst
  1. Thanks for the feedback. I'll research the tips further in the future. I'm not familiar with Linux and Armbian. I spent a lot of time in the past understanding the issues that occurred here. I'd like to be able to leave OP2 on 24/7h if necessary, like OP1, without worrying about a power outage. But Open Media Vault, Docker, Bittorrent, must perform frequent reads and writes to the SD card, and I have bad memories of it, with the system failing to boot up several times.
  2. Hi everyone, Two Questions: 1) I have two Orange Pi 3 LTS boards at home. I installed AdGuard Home on one, serving as DHCP (I'll call it OP1), and on the other, I left a Docker with other apps (qbittorrent, omv6, samba, etc. - I'll call it OP2). Both are installed via SD card. But if there's a power outage, OP1 works normally again after, without any problems. But OP2, on the other hand, has experienced data corruption several times. Does anyone know why OP1 works fine and OP2 runs the risk of having to reinstall the system in such a case? 2) If I used a board with EMMC memory and unified all the systems on it, would the chances of this decrease, or is it unrelated? I see other people with same problem. Only using a UPS to prevent the OP2 problem? Thanks
  3. Thank you. This will help me until I got another fix for it.
  4. Hello, I'm a lay user, I don't know much about Armbian and networks - On my network I have a router whose default DNS is set to point to an OrangePI 3 lts with Armbian 23.02, where I installed AdGuard (v0.107.52) and created my rules to filter advertisements through URLs that I access through the web browser of any device. It works almost 100% as I would like - I use a NO-IP DDNS on the router to access the surveillance DVR and I can see the cameras fine on my smartphone. However, when there is a power outage and then it comes back on, there is often some kind of synchronization failure between the router and the OrangePI to access the cameras. So I need to restart the Orangepi to be able to view them remotely again. I believe it could be something related to the free and dynamic DDNS, or because I needed to disable the router's DHCP and transfer this function to the OrangePI (so that the network device logs could work correctly through AdGuard). I would like to know: 1) Is there a way to program the OrangePI to restart itself every X hours? What program do I need to install (with a tutorial if possible) and how can I configure a script for this? I tried to find something within armbian-config, I searched on Google, but I couldn't find exactly what I was looking for. So I want to test if this would solve my problem. 2) What is the easiest way to access the OrangePI system files from Windows? Is it via FTP? I use PuTTY for remote access, but I don't know much more about it. Thank you
