- Orange Pi Zero 3
Orange PI PC HDMI LCD MPI3508 Touchscreen SPI move CS from pin 24 to pin 22
Ahhh gotcha. Maybe that's probably a step I'm missing. I'll look back through the thread for it. Focusing on getting the LCD display to work first, I went to a different image, and went through the steps I previously did, but this time went through the steps on the lcd wiki to load the lcd driver (not the touch sensor yet). After reboot no real change. I checked Dmesg, and it does show the below, which is more than I got before (just the first line with the warning). (This was the result of using an older DTS) [ 5.598832] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 5.608672] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 5.614293] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 5.615861] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 5.620811] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed... [ 5.621197] fb_ili9341: module is from the staging directory, the quality is unknown, you have been warned. [ 5.621724] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pa not found, using dummy regulator [ 5.622378] fb_ili9341 spi0.0: fbtft_property_value: regwidth = 8 [ 5.622388] fb_ili9341 spi0.0: fbtft_property_value: buswidth = 8 [ 5.622400] fb_ili9341 spi0.0: fbtft_property_value: debug = 0 [ 5.622409] fb_ili9341 spi0.0: fbtft_property_value: rotate = 0 [ 5.622419] fb_ili9341 spi0.0: fbtft_property_value: fps = 10 [ 5.622583] sun50i-h616-pinctrl 300b000.pinctrl: pin PA7 already requested by spi0.0; cannot claim for 300b000.pinctrl:7 [ 5.622595] sun50i-h616-pinctrl 300b000.pinctrl: error -EINVAL: pin-7 (300b000.pinctrl:7) [ 5.622610] fb_ili9341 spi0.0: error -EINVAL: Failed to request reset GPIO [ 5.622649] fb_ili9341: probe of spi0.0 failed with error -22 (This was the below is the newer DTS this reply of Peters) [ 5.550586] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 5.560145] fb_ili9341: module is from the staging directory, the quality is unknown, you have been warned. I noticed the difference between the older and newer DTS is pin assignments. I just compared the pinouts for the MPI3508 and the Orange Pi Zero 3 and everything seems to match up with their labels, with the one exception, on my OPiZ3, SPI1/CS/PH9(pin 24) is one pin above the TP_CS pin (26) on the MPI3508. I think another issue I'm having is the DTS that's been posted here is for the bigger Orange Pi, with the 40pin header, and my OPi has the 26pin header, which is the same count as that on the LCD. Because of that I probably need to rename/number something in the DTS, but I'm not sure what yet.
To be honest, I'm not sure what ads7846 is. This is the thread I've been following. They're been working on various Orange Pi Zero's. Most recently the Zero 2 and Zero 3. They have been working to get Armbian to work on the Zeros, and have gotten it working, and a few weeks ago were working on getting the SPI bus support going, which as far as I understand it is working now, but I'm not familiar with how that all works. Still learning a lot of how this works with armbian, and orange pi etc. UPDATE I noticed in the 99-fbdev.conf file it has Option "fbdev" "/dev/fb1". FB as i understand is frame buffer. I had a look in /dev earlier and didn't see any /dev/fb0 or fb1. I did something that did show /dev/fb0, so i went back into that config file and changed it to fb0. After a reboot the desktop popped up on the HDMI output, so at least now I know how to get the HDMI back. I may have to dig into dmesg and see if there are any clues in there.
OK, so still at the nothing happens stage for me. Nothing on the HDMI or LCD. evtest comes back with /dev/input/event0: DELL DELL USB Keyboard /dev/input/event3: BRLTTY 6.5 Linux Screen Driver Keyboard Whatever that BRLTTY is (something to do with TTY service?), doesn't seem to be anything to do with the touch screen, as it doesn't show any input when I try it (though if the pins aren't right that could be it). gpioinfo for chip1 has 32 lines, I'm assuming that's where the GPIO would show up for the screen, but it says they're all unused. Chip0 has 287 lines, most seem to be unnamed/unused (see bottom for examples). After dinner, I'll see if I can get the HDMI to come back. I guess the next step is to check the pinouts on my OPiZ3 compared with the screen and with the pinout above where it's said to have worked. For reference, I'm using the latest image that @pixdrift provided in another thread (bookworm edge 6.7.4). However, I may try the previous one, as now that I look at it, the one I'm using now appears to have something to do with audio. Also, I went into Armbian config and turned on all the options for SPI and the TFT options as well. Maybe I'll go back and turn TFT off and run the command that added the DTS again. When I tried that it said it was already configured so might be interfering and not loading that DTS. line 64: unnamed kernel input active-high [used] line 65: unnamed unused input active-high line 66: unnamed kernel input active-high [used] line 67: unnamed kernel input active-high [used] line 68: unnamed kernel input active-high [used] line 69: unnamed unused input active-high line 70: unnamed unused input active-high line 71: unnamed unused input active-high line 72: unnamed unused input active-high line 73: unnamed "interrupt" input active-high [used] line 74: unnamed unused input active-high line 75: unnamed unused input active-high line 76: unnamed "red:status" output active-high [used] line 77: unnamed "green:power" output active-high [used] line 78: unnamed unused input active-high line 79: unnamed unused input active-high line 80: unnamed "regulator-usb1-vbus" output active-high [used] ... line 192: unnamed kernel input active-high [used] line 193: unnamed kernel input active-high [used] line 194: unnamed kernel input active-high [used] line 195: unnamed kernel input active-high [used] line 196: unnamed kernel input active-high [used] line 197: unnamed kernel input active-high [used] line 198: unnamed unused input active-high line 199: unnamed unused input active-high line 200: unnamed unused input active-high line 201: unnamed unused input active-high line 202: unnamed unused input active-high line 203: unnamed unused input active-high line 204: unnamed unused input active-high line 205: unnamed unused input active-high line 206: unnamed unused input active-high line 207: unnamed unused input active-high line 208: unnamed unused input active-high line 209: unnamed unused input active-high line 210: unnamed "reset" output active-low [used]
Finally getting around to testing your steps @Peter Gregory I did it once with a newer image, but wasn't sure which one. When it rebooted nothing happened on the mpi3508, or the monitor on HDMI. I'm about to run through the steps you documented and see what happens. However, I haven't checked on the wiring. I'm using the OPiZ3, with that supposedly just hooking it up so that the ground and 3.3v pins are in the right places it's supposed to work, but I haven't checked the pinouts compared with what you have for your wiring. If this second round of setting up the OS doesn't work I'll have to look into the wiring. This might not be a bad thing, currently, the screen hangs off the side, due to how it has to be rotated. If I have to wire it to make it work, that may allow me to rotate it so it doesn't take up a bigger footprint.
Orange Pi Zero 3
The latest images should have working wifi. I haven't tested personally myself, since...two weeks ago maybe. I recall someone not long ago saying that the Wi-Fi CPU usage issue was fixed too. I haven't had the time lately, but I'm looking to make it work with the MPI3508 LCD Touch screen. I may have to end up compiling support for it, but I've gotta look at the various resources to figure it out.
Nice! I know this is an old post, but I have the same screen, MPI3508. I'm trying to get it to work on the Orange Pi Zero 3. As far as I recall from looking at the pin diagrams, physically it should work. Software/drivers on the other hand I haven't had much luck with. Though until recently, as far as I'm able to understand anyway, SPI hasn't been working on the builds they've been working on for the OPiZ2/3 until recently. Just curious though, in some places it seems like this, or similar displays can work without using the HDMI connection or am I misunderstanding? I guess similar screens may be capable of displaying images just using the 24-pin connector on the OrangePi, while others only use it for the touch interface. I'll look back over the steps you went through later and see if I can apply them to what I do know. Otherwise I'll look into what it takes to compile an image, and combine what you have, with what they've been doing to make Armbian work on the OPiZ2/3.
Orange Pi Zero 3
Awesome! Well, sort of....haha. I've had my OPiZ3 running for...looks like over 8 days now, on the PR6116 image @pixdrift was so kind to make available awhile back. Though granted it's just sitting there, not doing anything other than running random screen savers. Now of course I have to shut it down and grab one of the latest images to test. I've got a 3.5" touch screen attached to it, so I guess I'll see if i can get touch working, and if I'm not mistaken it SHOULD work without the HDMI hooked up, but maybe I have a false impression of what it's connector does. Maybe it only handles touch. If so no biggie, I can keep using it with HDMI as is. 🙂
Sma
