Errors: linux-image-legacy-rk35xxErrors -
Thanks for the advice. Perhaps the problem arose because of the mirror - fastmirror.pp.ua. I am from Russia and perhaps because of this, not all packages could not stop properly, since the logs constantly had problems downloading from this mirror. If you replace the url in the /etc/apt/sources.list.d/arm bin.list file http://apt.armbian.com on http://mirror .yandex.ru/mirrors/armbian/apt then the problem will be solved (I took it with 4pda).
When executing a command - sudo opt upgrade - returns an error: Setting up linux-image-legacy-rk35xx (23.11.1) ... Armbian 'linux-image-legacy-rk35xx' for '5.10.160-legacy-rk35xx': 'postinst' sta rting. * dkms: running auto installation service for kernel 5.10.160-legacy-rk35xx [ OK ] update-initramfs: Generating /boot/initrd.img-5.10.160-legacy-rk35xx W: Possible missing firmware /lib/firmware/rtl_nic/rtl8125a-3.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168fp-3.fw for module r81 69 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-3.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-2.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-2.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-1.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-2.fw for module r8169 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-1.fw for module r8169 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8402-1.fw for module r8169 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-2.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-1.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-3.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-2.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-1.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-2.fw for module r816 9 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-1.fw for module r816 9 gzip: stdout: No space left on device E: mkinitramfs failure gzip 1 update-initramfs: failed for /boot/initrd.img-5.10.160-legacy-rk35xx with 1. run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1 Free space after deleting the package linux-image-legacy-rk35xx in /boot: 3.6M dpkg: error processing package linux-image-legacy-rk35xx (--configure): installed linux-image-legacy-rk35xx package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: linux-image-legacy-rk35xx E: Sub-process /usr/bin/dpkg returned an error code (1) what could be the problem and how to fix it?
Armbian doesn't run on Orange Pi 5 Plus
Hi. I had a problem when loading the "Armbian_23.11.1_Orangepi5-plus_jammy_legacy_5.10.160_gnome-amazingfated_desktop" image for the first time. Board - Orange Pi 5 Plus with 16 Gb of RAM, 256 Gb of eMMC. SD card - SanDisk Ultra microSDHC 32 ГБ. During the first boot, after entering the password, root asks you to select a shell (bash zsh). But, so that I do not enter or write, he asks me to re-select it. What could be the problem? The problem was solved by replacing the keyboard. The upper part stopped working.
MakKou86
