UART1 does not work Transmission
https://rapidshare.io/20Rr/IMG_20240130_101637.jpg https://rapidshare.io/20Rs/IMG_20240130_101714.jpg https://rapidshare.io/20Rt/IMG_20240130_101629.jpg https://i.postimg.cc/ZR4qnB4s/IMG-20240130-101629.jpg https://i.postimg.cc/j2kqMMNB/IMG-20240130-101637.jpg https://i.postimg.cc/sx2DPkBp/IMG-20240130-101714.jpg
- UART1 does not work Transmission
Very strange things. On my board, UART1 has errors at a speed of more than 1200. The higher the speed, the more errors. That is, when the port is opened at a speed of 1200, everything is fine, at 9600 the characters are unreadable, and at 115200 nothing is displayed at all. Here is an example of displaying the sequence 1234567890 5 times at 2000 baud: That is, the problem is not that UART1 TX does not send anything, but that it sends data with errors, and nothing is displayed at a speed of 115200. I have a very slow SD card. Could this be a possible reason for this behavior?
Hello. For some reason, UART1 does not work for transmission, only for reception. The transmitter pin itself is definitely working, I checked by switching this pin to output mode, and then switching it to a high/low logical level, everything works properly, the level on the Pin changes. How I check the UART itself: I installed picocom, shorted the TX and RX pins, and I’m trying to see what I’m sending. For UART2 this method works as it should, but UART1 only works for reception. I realized this when I opened the TX and RX, and was able to receive incoming data sent through the USB-UART converter.
Armbianer
