scolbeck
  1. Try 6.8-rc1. That one worked for me but I also had problems with other ones like 6.8-rc5 so reverted back to 6.8-rc1.
  2. I also had a problem with the 6.7 kernel not creating /dev/mtdblock0. Switching to the nightly 6.8 kernel fixed it for me.
  3. Looked to be a problem with 6.7.0-rc1-edge-rockchip-rk3588 kernel. I tried downgrading the kernel to 6.5.0-rc5-edge-rockchip-rk3588 but it wouldn't boot. However changing to nightly kernel 6.8.0-rc1-edge-rockchip-rk3588 looked to fix the problem.
  4. On a Rock 5B, I installed Armbian 23.11 Bookworm CLI via a SD card and now trying to setup boot via the NVMe drive. I followed the instructions on https://www.armbian.com/rock-5b/ to create a partition on the NVMe drive, format it, then tried `armbian-install` to boot from SPI. However armbian-install does not list the option to "Boot from SPI". It shows only the following options: 1 Boot from SD - system on SATA, USB, or NVMe 5 Install/Update the bootloader on SD/eMMC I then noticed I do not have a SPI device. /dev/mtdblock0 doesn't exist as well as "cat /proc/mtd" is empty. # ls /dev/mtd* ls: cannot access '/dev/mtd*': No such file or directory # cat /proc/mtd dev: size erasesize name # lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mmcblk1 179:0 0 29.7G 0 disk ├─mmcblk1p1 179:1 0 256M 0 part /boot └─mmcblk1p2 179:2 0 29.2G 0 part /var/log.hdd / zram0 251:0 0 7.7G 0 disk [SWAP] zram1 251:1 0 50M 0 disk /var/log zram2 251:2 0 0B 0 disk nvme0n1 259:0 0 3.7T 0 disk └─nvme0n1p1 259:1 0 10G 0 part # dmesg | grep -i spi [ 0.000000] GICv3: 480 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.679958] spi spi0.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg7 [ 0.679996] spi spi0.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs3-null-pins [ 0.680004] spi spi0.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs2-null-pins [ 0.680011] spi spi0.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs1-null-pins Is there something I need to do such as specifying a dtoverlay to enable SPI? Thanks in advance for your help.
