Uko
  1. Is there any trick to make use of the integrated fan on Radxa 25W PoE Hat? I'm using 4GB Radxa Rock 5C Lite Armbian_25.5.1_Rock-5c_bookworm_vendor_6.1.115_minimal Some guides mention that one should enable an overlay. I didn't find any relevant overlays in armbian-config. In the Radxa repo I found rock-5a-radxa-25w-poe.dts which specifies that it's also compatible with Rock 5C. I've compiled it and enabled it, but by default the fan is not spinning (on high temps) and I'm not sure how to investigate that. Also, does it matter that I have 5C Lite? As it has another chip: RK3582
  2. Uko replied to ag123's topic in Allwinner sunxi
    Orange Pi Zero 2W has H618, same CPU as Orange Pi Zero 3. This is one of the things that make the two boards very similar. Orange Pi Zero 2, on the other hand, has H616. Strange naming and technology choices, but I can't help
  3. Uko replied to ag123's topic in Allwinner sunxi
    Hi everyone. I'm new to building Armbian images (I can build one, but I'm not a Linux expert who can confidently fix bugs). I'm writing in this topic because I have an Orange Pi Zero 2W, and some of you mentioned that it would be good to test some changes on another device with H618. At the same time, I'm not sure if that particular device is helpful, as (from what I can tell) it has the same components as OPi Zero 3. In any case, I will try to make things work with Zero 2W, and if you think it is important and you can direct me a bit, I'm happy to collaborate and contribute.
