Alon djboy
  1. Is there any way to boot from usb/s card insted of the nand?
  2. The tool connects i'm using version 2.1.8 Erase flash (normal erase) Erase bootloader The image i'm using was sent to my by the suport of the device and has worked on another identical device.
  3. Hi, I have tried that and the burn tool errors out Uboot/Get Result/ Disk initial error And this is the serial output Attempt 1: ATA transfer complete... PIEI prepare done DDR4 probe ddr clke DATA transfer complete... AML DDR FW load done DATA transfeone DATA transfer complete... AML DDR FW load done DATA transization INFO : End of write delay center optimization INFO : Elly! 1D init succeed DATA transfer complete... Check phy resu 00000019 00000019 0000001a 00000017 00000019 00000017 00000018 00000018 00000019 dram_vref_reg_value 0x 0000006 1024MB DMC_DDR_CTRL: 00e0001bDDR size: 2048MB cs0 DataBus tesspi_post_bind(spifc): req_seq = 0 [MSG]MMC init in usb aml_priSM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:82;SD?:20000;USB:8; cfg ddr probe id done DATA transfer complete... fw parse donCheck phy result INFO : End of initialization INFO : ERROR : Tlt INFO : End of initialization 0.0;C bl2_stage_init 0x01 bl2_stage_init 0x81 hw id: 0x0001 - pwm id 0x00 bl2_stage_init 0xc0 bl2_stage_init 0x02 L0:00000000 L1:00000703 L2:00008067 L3:15000020 S1:00000000 B2:20282000 B1:a0f83180 TE: 2781386 BL2 Built : 20:29:41, Jun 18 2019. g12a ga659aac - luan.yuan@droid15-sz Board ID = 12 Set cpu clk to 24M Set clk81 to 24M Use GP1_pll as DSU clk. DSU clk: 1200 Mhz CPU clk: 1200 MHz Set clk81 to 166.6M DDR driver_vesion: LPDDR4_PHY_V_0_1_15 build time: Junfg ddr probe id done DATA transfer complete... fw parse done DATA transfer complete... PIEI prepare done DDR3 probe ddr DATA transfer complete... dmc_version 0001 2MHz DATA transfer complete... dmc_version 0001 Check phy rnd of read delay center optimization INFO : End of max read latINFO : End of 2D read delay Voltage center optimization 018 00000019 00000019 00000018 00000017 00000019 00000016 000000t aml_ddr_fw_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 201-2: Chip: SM1 Rev: C (2B:C - 10:2) INFO: BL3-2: crypto enginv->desc_buf = 0x0000000073e40a70 aml_priv->desc_buf = 0x0000000[MSG]sof Set Addr 10 Get DT cfg Get DT cfg Get DT cfg set CFG b 3 soc: sm1 plat: ac213 vari: 4g Find match dtb: 2 clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 found!!! nand init failed: -6 get_sys_clk_rate_mtd() 290, clocg cmd [store init 3] init failed [info]failed: 001000000, sz=0x14552 [MSG]Burn complete BULKcmd[download get_BULKcmd[disk_initial 1] Amlogic multi-dtb tool GZI0 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0,, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, statuscess BULKcmd[ low_power] [info]success ID[16] tplcmd[ P format, decompress... Multi dtb detected Multi d emmc/sd response timeout, cmd55, status=0x1ff2800 co-phase 0x3k setting 200! NAND device id: 0 ff ff ff ff ff No NAND devicSM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:82;SD?:20000;USB:8;55. Force loop cfg DATA transfer complete... fw parse done DAining INFO : End of MPR read delay center optimization INFO : INFO : End of 2D write delay Voltage center optimization INFO : Training has run successfully! channel==0 RxClkDly_Margin_A0==149 ps 11 TxDqDly_Margin_A0==149 ps 11 RxClkDly_Margin_A1==rainedVREFDQ_A1==74 VrefDac_Margin_A0==29 DeviceVref_Margin_A0==40 VrefDac_Margin_A1==28 DeviceVref_Margin_A1==40 channel==1 RxClkDly_Margin_A0==135 ps 10 TxDqDly_Margin_A0==149 ps fDac_Margin_A0==27 DeviceVref_Margin_A0==40 VrefDac_Margin_A1=t aml_ddr_fw_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 2012241b5 2019-07-02 17:22:49 luan.yuan@droid15-sz] OPS=0x10 ri073e42db0 SDIO Port B: 0, SDIO Port C: 1 Cfg max: 5, cur: 2. Board id: 255. Force loop cfg ddr probe idid done DATA transfer complete... fw parse done DATA transfere id done DATA transfer complete... fw parse done DATA transftage center optimization =28 DeviceVref_Margin_A1==40 dwc_ddrphy_apb_wr((0<<20)|(2<<4 2D init succeed ddr init done, boot next stage result reporng efuse init 2b 0c 10 00 01 19 15 00 00 18 37 31 56 52 52 50 iver_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 2019 20:29:37 board id: 12 Cfg max: 5, cur: 1. Board id: 2er complete... AML DDR FW load done DATA transfer complete... INFO : End of initialization INFO : End of read dq deskew traINFO : End of 2D read delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization 149 ps 11 TxDqDly_Margin_A1==135 ps 10 TrainedVREFDQ_A0==74 T11 RxClkDly_Margin_A1==135 ps 10 TxDqDly_Margin_A1==149 ps 11 TrainedVREFDQ_A0==74 TrainedVREFDQ_A1==74 Vre16)|(0<<12)|(0xb0):0004 soc_vref_reg_value 0x 0000001a 00000 00000018 00000019 00000019 00000016 00000018 00000017 00000018 00000017 00000018 dram_vref_reg_value 0x 0000006t pass cs1 DataBus test pass cs0 AddrBus test pass cs1 AddrBu [0.017355 Inits done] secure task start! high task start! 001000000, sz=0x14552 [MSG]Burn complete BULKcmd[download get_ 0000000000200000 1 10: tee 0000000002000e 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400[info]success [MSG]Burn Start... [MSG]load dt.img to 0x000000000800000 1 01: recovery 0000000001800000 1 02: misc 0000, clock 400000 emmc/sd response timeout, cmd8, response timeout, cmd8, status=0x1ff2800 co-phase 0x3, tx-dly 0 ID[16] tplcmd[ echo 12345] 12345 [MSG]ret = 0 [info]sucstatus] [info]success oot 0000000001000000 1 set has_boot_slot = 0 07: rsv 000esponse timeout, cmd55, status=0x1ff2800 co-phase 0x3, tx-dly 0 nand init failed: -6 NAND init failed deviceINFO : End of 2D read delay Voltage center optimization INFO : End of 2D read delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization INFO :149 ps 11 TxDqDly_Margin_A1==135 ps 10 TrainedVREFDQ_A0==74 TDac_Margin_A0==28 DeviceVref_Margin_A0==40 VrefDac_Margin_A1== aml_ddr_fw_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 2019c40b1 NOTICE: BL31: Built : 15:57:33, May 22 2019 NOTICE: BLEVICE_SECURE 0xb200000e U-Boot 2015.01-g32cc24e (Aug 26 202SM1: transfer complete... dmc_version 0001 Check phy result INFd done DATA transfer complete... fw parse done DATA transfer d! Cfg max: 5, cur: 4. Board id: 255. Force loop cfg ddr probend of initialization INFO : End of read enable training INFO : initialization Training has run successfully! channel==0 RxClkDly_Margin_A27 DeviceVref_Margin_A1==40 dwc_ddrphy_apb_wr((0<<20)|(2<<1 pass cs1 DataBus test pass cs0 AddrBus test pass cs1 AddrBus low task start! run into bl31 NOTICE: BL31: v1.3(release):4fSet Addr 14 Get DT cfg 82000 B1:a0f83180 TE: 2727178 BL2 Built : 20:29:41, Jun 1lete... PIEI prepare done DDR4 probe ddr clk to 1152MHz DATATA transfer complete... dmc_version 0001 Check phy result IPIEI prepare done LPDDR4 probe ddr clk to 1152MHz DATA transf End of fine write leveling INFO : End of Write leveling coarse 00000018 00000019 0000001a 00000016 00000017 00000016 00000019 00018 00000018 00000019 00000019 dram_vref_reg_value 0x 00000063 test pass DATA transfer complete... .. RUN bl2 usb boot MVN_1=0x00000000 MVN_2=0x00000000 [Image: g12a_v1.1.3389-9Get DT cfg Get DT cfg set CFG 001000000, sz=0x14552 [MSG]Burn complete BULKcmd[download get_ 4g dtb 2 soc: sm1 plat: ac213 vari: 2g dto 0000000000800000 1 01: recovery 0000000001800000 1 02: clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 setting 200! NAND device id: 0 ff ff ff ff ff No NAND device 14552) fmt(normal) [MSG]totalSlotNum = 0, nextWriteBackSlot 2 : sm1 platform: ac213 variant: 2g dtb 0 soc: g12a plalti-dtb tool Single dtb detected parts: 17 00: log 0000000008000000 1 13: system 0000000080000000 1 14: proe found!!! nand init failed: -6 NAND init fail ID[16] tplcmd[ echo 12345] 12345 [MSG]ret = 0 [info]success BULKcmd[ low_power] [info]success ID[16] tplcmd[ status] [info]success b 3 soc: sm1 plat: ac213 vari: 4g Find match dtb: 2 rsv 0000000001000000 1 08: metadata 0000000001000000 1 09:0 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0,ut, cmd8, status=0x1ff2800 co-phase 0x3, tx-dly 0, clock 400000, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, statusþðüÿ<ø~ Attempt 2: 0.0;C bl2_stage_init 0x01 bl2_stage_init 0x81 hw id: 0x0001 -plete... PIEI prepare done DDR4 probe ddr clk to 1152MHz DAT! Cfg max: 5, cur: 3. Board id: 255. Force loop cfg ddr probe PIEI prepare done LPDDR4 probe ddr clk to 1152MHz DATA transINFO : Training has run successfully! Check phy result INFO : f initialization c40b1 NOTICE: BL31: Built : 15:57:33, May 22 2019 NOTICE: BL-13-gc341bc0 #1 Thu Jun 27 19:33:34 2019 +0800 arm INFO: BL3spi_post_bind(spifc): req_seq = 0 [MSG]MMC init in usb aml_priInUsbBurn [MSG]sof download mem dtb normal 83282] [MSG]Down(mem) part(dtb) sz(0x000000800000 1 03: dtbo 0000000000800000 1 04: cri_data nand init failed: -6 get_sys_clk_rate_mtd() 290, clock setting BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;8 2019. g12a ga659aac - luan.yuan@droid15-sz Board ID = 12 SCfg max: 5, cur: 2. Board id: 255. Force loop cfg ddr probe id complete... AML DDR FW load done DATA transfer complete... PIDATA transfer complete... dmc_version 0001 Check phy result of CA training INFO : End of initialization I delay INFO : Training has run successfully! Check phy result el==1 RxClkDly_Margin_A0==149 ps 11 TxDqDly_Margin_A0==149 ps _A1==149 ps 11 TrainedVREFDQ_A0==74 TrainedVREFDQ_A1==74 Vrefa 00000018 00000016 00000018 00000016 0000001b 00000017 00000016 20:29:43 auto size-- 65535DDR cs0 size: 1024MB DDR cs1 size: 31: G12A normal boot! 0 - 10:58:36) DRAM: 2 GiB Relocation Offset is: 76e50000 InUsbBurn tb tool version: v2 . Support 4 dtbs. aml_dt soc cri_data 0000000000800000 2 05: param 0000000001000000 2 emmc/sd response timeout, cmd55, status=0x1ff2800 co-phase 0x3k setting 200! NAND device id: 0 ff ff ff ff ff No NAND devic
  4. Hi, I have a probox2 S905X3 I tried to flash it a while back and it bricked, recently I got a serial adapter and attempted to get some data this is the output SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:82;SD?:20000;USB:8; LOOP:1;EMMC:0;READ:E;READ:800;READ:800;SD?:20000;USB:8; LOOP:2;EMMC:0;READ:E;READ:800;READ:800;SD?:20000;USB:8; LOOP:3;EMMC:0;READ:E;READ:800;READ:800;SD?:20000;USB:8; ..... As far as I can understand it looks like it is not booting and has some kind of read error, I tried to boot while holding down the reset btn w/wo usb/sd card, but I get the same result. Can I do anything? Thank you.
