Armbian for H313 X96-Q LPDDR3 TV-Box
How to build my own 5.1 minimal ?
Home Assistant on Ugoos AM3 s912
Oh my God, it was obvious. Everything is working! thank you! Then let's go back to HA. If I just write image from @Igor to a USB flash drive, then boot through the reset clip, I get into the standard recovery. There is armbianEnv.txt should I also specify FDT there? Should I place u-boot there too? Just according to @Igor, you just need to write the image to usb flash, insert it into the box and it should load HA without any settings
label Armbian_community kernel /Image initrd /uInitrd fdtdir /dtb/amlogic/meson-gxm-q200.dtb append root=UUID=212049b6-44a7-4741-9789-815d023561d0 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles I talked about it, I do not indicate this dtb, he takes from somewhere himself
Damn I forgot about Microsd... thats output log https://www.dropbox.com/scl/fi/98i3qx0g11x8ngmwwukg9/2024-03-02-21.04.19.jpg?rlkey=kg35x3ocjuiag0ci1qldtzdug&dl=0 it's strange dtb source s905x which I definitely did not indicate
Armbian_community_24.5.0-trunk.93_Aml-s9xx-box_bookworm_current_6.6.18_minimal.img
Wow, I understood what was the problem.... it was necessary to create a boot dir and put the u-boot.ext there, and not put it in the root dir... but now another question. What is the password for user root? 1234 does not match
ok, what next?
No, your image didn't launch, so I started looking for alternative images I used different ones that in theory should match: meson-gxm-xxx u-boot-s905x-s912 - copy and rename this to u-boot.ext in same dir by holding reset button while boot https://github.com/ophub/amlogic-s9xxx-armbian/releases/download/Armbian_bookworm_save_2024.02/Armbian_24.5.0_amlogic_s912_bookworm_6.1.78_server_2024.02.20.img.gz runing fine I previously used the box as a retro console and this image https://github.com/EmuELEC/EmuELEC/releases/download/v3.9/EmuELEC-Amlogic.arm-3.9-Generic.img.gz worked fine As far as I understand, Ophub use some other bootloader
Nothing happens at all, u-boot not loading instead default recovery starts... i'm using "Armbian_community_24.5.0-trunk.93_Aml-s9xx-box_bookworm_current_6.6.18_minimal.img.xz" and do everything according to this guide but u-boot won't starts
@SteeMan i can run https://github.com/ophub/amlogic-s9xxx-armbian but https://github.com/armbian/community/ won't start. So I also tried to run this assembly and it doesn’t run =(
Hi! Is it possible to install this assembly on Ugoos AM3 S912?
Tribal_
