H313 MX10 F1 TV Box - no WiFi/Ethernet/BT
Hello @Nick A Thank you! 😄 Replacing the WiFi extension solved the issue. wlan0 is now created, scans successfully, connects to my AP, and receives both IPv4 and IPv6 addresses. I've attached a fresh dmesg from the working configuration. Bluetooth doesn't seem to be working yet, but that's not really important for me since I'd like to use this box as a headless server over Ethernet. Do you have any suggestions for enabling CPU frequency scaling and the onboard Ethernet? dmesg_nick2.log
Hello @Nick A Just to confirm: should I add post_family_tweaks__x96q() to x96q-lpddr3.csc, or to x98h.csc? (I'm using the official Armbian build tree.)
Hello @Nick A Thanks for your reply. I patched the dts. Still only the lo interface is visible. dmesg attached. dmesg_nick1.log sun50i-h313-x96q-lpddr3_nick1.dts Edit: I attached the android dmesg log... (i'm a bit confused. the board has AIC8800 chip, but the armbian dmsg logging marlin/unisoc wifi drivers) android_dmesg.log
Hello @Nick A, Thanks for the quick reply. The WiFi/BT chip is an AIC8800D40L. Board photos attached 😉
Hi, I'm trying to get Armbian fully working on an MX10 F1 TV Box (Allwinner H313, 2GB LPDDR3, 16GB eMMC). The box boots using the X96Q LPDDR3 DTB (X96Q TV-Box LPDDR3), but several onboard devices are not working: ❌ Ethernet ❌ Built-in WiFi ❌ Bluetooth ❌ CPU frequency scaling Working: ✅HDMI ✅GPU (Panfrost / OpenGL ES 3.1) ✅USB ✅SD card ✅eMMC I've extracted the original Android DTB and DTS, and I'm attaching them together with the Armbian dmesg. Could someone familiar with Allwinner Device Trees help identify what is missing or needs to be changed to create proper support for this board? Thanks! dmesg.txt mx10-f1-android.dtb mx10-f1-android.dts
install bookworm 6.6.63 on x96q pro+ h728
i also want to know it
- GPU driver installation problem on Rock5B (Armbian Bookworm Minimal)
@amazingfate This is it!!! You solved my root problem Thank you! I modified the EGL code, and now with device #1 works well. root@ubuntu:~/egl_example# ./egl_example dev1 Explicit device selection: 1 Loaded EGL 1.4 after reload. GL_VENDOR=Panfrost GL_RENDERER=Mali-G610 (Panfrost) GL_VERSION=3.3 (Compatibility Profile) Mesa 23.0.0-devel GL_SHADING_LANGUAGE_VERSION=3.30 root@ubuntu:~/egl_example# ./egl_example dev1 es2 Explicit device selection: 1 Loaded EGL 1.4 after reload. GL_VENDOR=Panfrost GL_RENDERER=Mali-G610 (Panfrost) GL_VERSION=OpenGL ES 3.1 Mesa 23.0.0-devel GL_SHADING_LANGUAGE_VERSION=OpenGL ES GLSL ES 3.10
@amazingfate Thank for your responses I tried the latest Radxa ubuntu server build (kernel 5.x) , and successfully installed mali g610 drivers. with glxinfo i see everything ok. but.... when im trying to create an opengl context for headless rendering, i getting a very strange error. rknpu_dri.so is missing. this is my initial problem, that is why i gave a try with Armbian. rknpu_dri.so issue (github) do you have any clue, which package contains this driver? so far no one could figure it out.
@amazingfate Thank you, i'm sorry about my clumsiness... finally i could install the mali g610 firmware, but now 'startx' can't start: X.Org X Server 1.21.1.7 X Protocol Version 11, Revision 0 Current Operating System: Linux rock-5b 6.8.0-rc1-edge-rockchip-rk3588 #1 SMP PREEMPT Sun Jan 21 22:11:32 UTC 2024 aarch64 Kernel command line: root=UUID=fb37e203-0f28-4a83-8200-4d1b92192ca3 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=dbfff1e9-1afa-704c-8661-c1a273d2de36 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 xorg-server 2:21.1.7-3+deb12u5 (https://www.debian.org/support) Current version of pixman: 0.42.2 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 2 15:45:43 2024 (==) Using config directory: "/etc/X11/xorg.conf.d" (==) Using system config directory "/usr/share/X11/xorg.conf.d" free(): double free detected in tcache 2 (EE) (EE) Backtrace: (EE) 0: /usr/lib/xorg/Xorg (OsLookupColor+0x188) [0xaaaae1ffb7e8] (EE) unw_get_proc_info failed: no unwind info found [-10] (EE) (EE) Fatal server error: (EE) Caught signal 6 (Aborted). Server aborting (EE) (EE) Please consult the The X.Org Foundation support at http://wiki.x.org for help. (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. (EE) (EE) Server terminated with error (1). Closing log file. i gave up at this point 😕
@amazingfate i followed the guide, but getting this: root@rock-5b:~# apt update Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://security.debian.org bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Ign:4 https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa ./ InRelease Hit:5 http://deb.debian.org/debian bookworm-backports InRelease Err:6 https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa ./ Release 404 Not Found [IP: 195.135.223.221 443] Hit:7 http://fi.mirror.armbian.de/beta bookworm InRelease Reading package lists... Done E: The repository 'https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa ./ Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. my sources.list: root@rock-5b:~# cat /etc/apt/sources.list deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware # deb-src http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware # deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware deb http://deb.debian.org/debian bookworm-backports main contrib non-free non-free-firmware # deb-src http://deb.debian.org/debian bookworm-backports main contrib non-free non-free-firmware deb http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware # deb-src http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware deb [signed-by=/etc/apt/keyrings/obs-home-amazingfate.gpg] https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa ./
@amazingfate thanks, meanwhile i realized, bookworm is debian can you help me how to i add that linked repo? log: root@rock-5b:~# add-apt-repository https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa Repository: 'deb https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa bookworm main' Description: Archive for codename: bookworm components: main More info: https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa Adding repository. Press [ENTER] to continue or Ctrl-c to cancel. Adding deb entry to /etc/apt/sources.list.d/archive_uri-https_build_opensuse_org_project_show_home_amazingfate_panfork-mesa-bookworm.list Adding disabled deb-src entry to /etc/apt/sources.list.d/archive_uri-https_build_opensuse_org_project_show_home_amazingfate_panfork-mesa-bookworm.list Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://security.debian.org bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Ign:5 https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa bookworm InRelease Err:6 https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa bookworm Release 404 Not Found [IP: 195.135.223.221 443] Hit:7 http://fi.mirror.armbian.de/beta bookworm InRelease Reading package lists... Done E: The repository 'https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa bookworm Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
Hello, I would like to install Mali-G610 drivers on my Rock5B, but getting error during adding PPA: root@rock-5b:~# add-apt-repository ppa:liujianfeng1994/panfork-mesa PPA publishes dbgsym, you may need to include 'main/debug' component Repository: 'deb https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu/ bookworm main' Description: https://gitlab.com/panfork/mesa You need to install mali-g610-firmware if you don't have file /lib/firmware/mali_csffw.bin More info: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/panfork-mesa Adding repository. Press [ENTER] to continue or Ctrl-c to cancel. Adding deb entry to /etc/apt/sources.list.d/liujianfeng1994-ubuntu-panfork-mesa-bookworm.list Adding disabled deb-src entry to /etc/apt/sources.list.d/liujianfeng1994-ubuntu-panfork-mesa-bookworm.list Adding key to /etc/apt/trusted.gpg.d/liujianfeng1994-ubuntu-panfork-mesa.gpg with fingerprint 0B2F0747E3BD546820A639B68065BE1FC67AABDE Hit:1 http://security.debian.org bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Ign:6 https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm InRelease Err:7 https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release 404 Not Found [IP: 185.125.190.80 443] Hit:5 http://fi.mirror.armbian.de/beta bookworm InRelease Reading package lists... Done E: The repository 'https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. I had to install python3-launchpadlib to get add-apt-repository work, which is not documented, i found it in the forums. HW: Rock5B (boot from: eMMC 32GB) OS: Armbian Bookworm Minimal (Feb 29, 2024) Followed the guide here: https://www.armbian.com/rock-5b/ How to fix this error?
