Gabriel Souza
  1. When I run the Linux kernel on the Odroid XU4 board, it enters a loop with this error during boot: U-Boot 2017.05-00008-g6a9ddb8303-dirty (May 19 2020 - 19:48:01 +0900) for ODROID-XU4 CPU: Exynos5422 @ 800 MHz Model: Odroid XU4 based on EXYNOS5422 Board: Odroid XU4 based on EXYNOS5422 Type: xu4 DRAM: 2 GiB MMC: EXYNOS DWMMC: 0, EXYNOS DWMMC: 1 MMC Device 0 ( SD ): 29.7 GiB mmc_init: -5, time 4 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: No ethernet found. Press quickly 'Enter' twice to stop autoboot: 0 reading /boot.ini 2401 bytes read in 4 ms (585.9 KiB/s) ## Executing script at 43e00000 reading config.ini 6911 bytes read in 5 ms (1.3 MiB/s) ini: Imported macaddr as 00:1e:06:61:7a:39 ini: Imported vout as hdmi ini: Imported HPD as true ini: Imported cecenable as false ini: Imported disable_vu7 as false ini: Imported ddr_freq as 825 ini: Imported overlay_resize as 16384 ini: Imported overlay_profile as ini: Imported overlays as spi0 i2c0 i2c1 uart0 No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! reading zImage 7299952 bytes read in 490 ms (14.2 MiB/s) reading exynos5422-odroidxu4.dtb 88559 bytes read in 11 ms (7.7 MiB/s) reading overlays/spi0.dtbo 691 bytes read in 5 ms (134.8 KiB/s) reading overlays/i2c0.dtbo 224 bytes read in 5 ms (43 KiB/s) reading overlays/i2c1.dtbo 226 bytes read in 5 ms (43.9 KiB/s) reading overlays/uart0.dtbo 227 bytes read in 6 ms (36.1 KiB/s) Kernel image @ 0x40008000 [ 0x000000 - 0x6f6370 ] ## Flattened Device Tree blob at 44000000 Booting using the fdt blob at 0x44000000 reserving fdt memory region: addr=44000000 size=2c000 Using Device Tree in place at 44000000, end 4402efff Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x100 [ 0.000000] Linux version 6.1.77+ (odroid@odroid) (gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Wed Mar 6 17:56:35 -03 2024 [ 0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Hardkernel ODROID XU4 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 128 MiB at 0x00000000b6800000 [ 0.000000] Samsung CPU ID: 0xe5422001 [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff] [ 0.000000] HighMem [mem 0x0000000070000000-0x00000000be9fffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x00000000be9fffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000be9fffff] [ 0.000000] Running under secure firmware. [ 0.000000] percpu: Embedded 17 pages/cpu s39124 r8192 d22316 u69632 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516928 [ 0.000000] Kernel command line: console=tty1 console=ttySAC2,115200n8 root=UUID=e139ce78-9841-40fe-8823-96a304a09859 rootwait ro fsck.repair=yes net.ifnames=0 HPD=true vout=hdmi e [ 0.000000] hdmi: using HDMI mode [ 0.000000] Unknown kernel command line parameters "false HPD=true vout=hdmi", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1903668K/2074624K available (12288K kernel code, 1139K rwdata, 2940K rodata, 2048K init, 363K bss, 39884K reserved, 131072K cma-reserved, 1157120K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] trace event string verifier disabled [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] Switching to timer-based delay loop, resolution 41ns [ 0.000000] clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000032] genirq: irq_chip COMBINER did not update eff. affinity mask of irq 57 [ 0.001509] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.001535] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.001555] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001572] Ignoring duplicate/late registration of read_current_timer delay [ 0.002351] Console: colour dummy device 80x30 [ 0.003109] printk: console [tty1] enabled [ 0.003176] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.003223] CPU: Testing write buffer coherency: ok [ 0.003313] pid_max: default: 32768 minimum: 301 [ 0.003464] LSM: Security Framework initializing [ 0.003658] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.003711] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.005467] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100 [ 0.006882] cblist_init_generic: Setting adjustable number of callback queues. [ 0.006928] cblist_init_generic: Setting shift to 3 and lim to 1. [ 0.007116] cblist_init_generic: Setting adjustable number of callback queues. [ 0.007151] cblist_init_generic: Setting shift to 3 and lim to 1. [ 0.007359] Setting up static identity map for 0x40200000 - 0x40200060 [ 0.007711] ARM CCI driver probed [ 0.008305] Exynos MCPM support installed [ 0.008707] rcu: Hierarchical SRCU implementation. [ 0.008734] rcu: Max phase no-delay instances is 1000. [ 0.010012] smp: Bringing up secondary CPUs ... [ 0.011171] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101 [ 0.012478] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102 [ 0.013707] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103 [ 0.014902] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.014919] CPU4: detected I-Cache line size mismatch, workaround enabled [ 0.014927] CPU4: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable [ 0.015018] CPU4: Spectre BHB: enabling loop workaround for all CPUs [ 0.016286] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.016300] CPU5: detected I-Cache line size mismatch, workaround enabled [ 0.016307] CPU5: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable [ 0.017624] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.017638] CPU6: detected I-Cache line size mismatch, workaround enabled [ 0.017645] CPU6: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable [ 0.018922] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.018937] CPU7: detected I-Cache line size mismatch, workaround enabled [ 0.018945] CPU7: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable [ 0.019180] smp: Brought up 1 node, 8 CPUs [ 0.019244] SMP: Total of 8 processors activated (384.00 BogoMIPS). [ 0.019276] CPU: All CPU(s) started in HYP mode. [ 0.019297] CPU: Virtualization extensions available. [ 0.020752] devtmpfs: initialized [ 0.042523] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.042807] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.042850] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.045974] pinctrl core: initialized pinctrl subsystem [ 0.048866] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.052562] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.054296] audit: initializing netlink subsys (disabled) [ 0.054571] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1 [ 0.055157] thermal_sys: Registered thermal governor 'step_wise' [ 0.055436] cpuidle: using governor menu [ 0.055910] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.055941] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.185987] EXYNOS5420 PMU initialized [ 0.292725] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible. [ 0.294707] fbcon: Taking over console [ 0.296476] iommu: Default domain type: Translated [ 0.296501] iommu: DMA domain TLB invalidation policy: lazy mode [ 0.296909] usbcore: registered new interface driver usbfs [ 0.296979] usbcore: registered new interface driver hub [ 0.297050] usbcore: registered new device driver usb [ 0.297807] s3c-i2c 12c70000.i2c: slave address 0x00 [ 0.297837] s3c-i2c 12c70000.i2c: bus frequency set to 378 KHz [ 0.298170] s3c-i2c 12c70000.i2c: i2c-0: S3C I2C adapter [ 0.298383] s3c-i2c 12c80000.i2c: slave address 0x00 [ 0.298412] s3c-i2c 12c80000.i2c: bus frequency set to 65 KHz [ 0.298719] s3c-i2c 12c80000.i2c: i2c-2: S3C I2C adapter [ 0.299209] mc: Linux media interface: v0.10 [ 0.299295] videodev: Linux video capture interface: v2.00 [ 0.299921] Advanced Linux Sound Architecture Driver Initialized. [ 0.301010] clocksource: Switched to clocksource mct-frc [ 0.301481] VFS: Disk quotas dquot_6.6.0 [ 0.301559] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.315803] NET: Registered PF_INET protocol family [ 0.316073] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.317886] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.317937] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.318036] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.318132] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 0.318434] TCP: Hash tables configured (established 8192 bind 8192) [ 0.318557] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.318617] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.318871] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.318931] NET: Registered PF_XDP protocol family [ 0.320817] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available [ 0.322010] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.324097] Initialise system trusted keyrings [ 0.324437] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.333908] romfs: ROMFS MTD (C) 2007 Red Hat, Inc. [ 0.421548] NET: Registered PF_ALG protocol family [ 0.421584] Key type asymmetric registered [ 0.421605] Asymmetric key parser 'x509' registered [ 0.421839] bounce: pool size: 64 pages [ 0.421992] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.422397] io scheduler mq-deadline registered [ 0.422425] io scheduler kyber registered [ 0.422681] io scheduler bfq registered [ 0.424520] samsung-pinctrl 13400000.pinctrl: Failed to create device link (0x180) with soc [ 0.426837] samsung-usb2-phy 12130000.phy: supply vbus not found, using dummy regulator [ 0.427839] exynos5_usb3drd_phy 12100000.phy: supply vbus not found, using dummy regulator [ 0.428032] exynos5_usb3drd_phy 12100000.phy: supply vbus-boost not found, using dummy regulator [ 0.428460] exynos5_usb3drd_phy 12500000.phy: supply vbus not found, using dummy regulator [ 0.428634] exynos5_usb3drd_phy 12500000.phy: supply vbus-boost not found, using dummy regulator [ 0.436864] dma-pl330 3880000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.436898] dma-pl330 3880000.dma-controller: DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6 [ 0.439976] dma-pl330 121a0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.440008] dma-pl330 121a0000.dma-controller: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32 [ 0.443083] dma-pl330 121b0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.443116] dma-pl330 121b0000.dma-controller: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32 [ 0.444270] dma-pl330 10800000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.444300] dma-pl330 10800000.dma-controller: DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32 [ 0.461998] dma-pl330 3880000.dma-controller: PM domain MAU will not be powered off [ 0.533568] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.536218] 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 124, base_baud = 0) is a S3C6400/10 [ 0.536771] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 125, base_baud = 0) is a S3C6400/10 [ 1.553526] printk: console [ttySAC2] enabled [ 1.560131] exynos-trng 10830600.rng: Exynos True Random Number Generator. [ 1.567245] exynos-mixer 14450000.mixer: Adding to iommu group 0 [ 1.574772] exynos-drm-g2d 10850000.g2d: Adding to iommu group 1 [ 1.581147] exynos-rotator 11c00000.rotator: Adding to iommu group 2 [ 1.587248] exynos-scaler 12800000.scaler: Adding to iommu group 3 [ 1.593888] exynos-scaler 12810000.scaler: Adding to iommu group 4 [ 1.600295] exynos-scaler 12820000.scaler: Adding to iommu group 5 [ 1.607009] exynos-drm-gsc 13e00000.video-scaler: Adding to iommu group 6 [ 1.613211] exynos-drm-gsc 13e00000.video-scaler: drm gsc registered successfully. [ 1.620298] exynos-drm-gsc 13e10000.video-scaler: Adding to iommu group 7 [ 1.627466] exynos-drm-gsc 13e10000.video-scaler: drm gsc registered successfully. [ 1.652020] brd: module loaded [ 1.654773] usbcore: registered new device driver r8152-cfgselector [ 1.659902] usbcore: registered new interface driver r8152 [ 1.665405] usbcore: registered new interface driver cdc_ether [ 1.671186] usbcore: registered new interface driver cdc_subset [ 1.677065] usbcore: registered new interface driver r8153_ecm [ 1.685749] phy phy-12130000.phy.6: phy_power_on was called before phy_init [ 1.691276] exynos-ehci 12110000.usb: EHCI Host Controller [ 1.696714] exynos-ehci 12110000.usb: new USB bus registered, assigned bus number 1 [ 1.704845] exynos-ehci 12110000.usb: irq 133, io mem 0x12110000 [ 1.731064] exynos-ehci 12110000.usb: USB 2.0 started, EHCI 1.00 [ 1.735818] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 1.743876] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.751068] usb usb1: Product: EHCI Host Controller [ 1.755880] usb usb1: Manufacturer: Linux 6.1.77+ ehci_hcd [ 1.761370] usb usb1: SerialNumber: 12110000.usb [ 1.766665] hub 1-0:1.0: USB hub found [ 1.769693] hub 1-0:1.0: 3 ports detected [ 1.774988] phy phy-12130000.phy.6: phy_power_on was called before phy_init [ 1.780583] exynos-ohci 12120000.usb: USB Host Controller [ 1.786000] exynos-ohci 12120000.usb: new USB bus registered, assigned bus number 2 [ 1.793806] exynos-ohci 12120000.usb: irq 133, io mem 0x12120000 [ 1.865293] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 1.872132] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.879280] usb usb2: Product: USB Host Controller [ 1.884074] usb usb2: Manufacturer: Linux 6.1.77+ ohci_hcd [ 1.889502] usb usb2: SerialNumber: 12120000.usb [ 1.894774] hub 2-0:1.0: USB hub found [ 1.897855] hub 2-0:1.0: 3 ports detected [ 1.904077] UDC core: dbgp: couldn't find an available UDC [ 1.908531] mousedev: PS/2 mouse device common for all mice [ 1.915382] i2c_dev: i2c /dev entries driver [ 1.943247] vdd_ldo9: Bringing 3300000uV into 3000000-3000000uV [ 1.960292] vddq_mmc2: Bringing 3300000uV into 2800000-2800000uV [ 1.979785] vdd_sd: Bringing 3300000uV into 2800000-2800000uV [ 2.049199] s5m-rtc s2mps14-rtc: registered as rtc0 [ 2.054487] s5m-rtc s2mps14-rtc: setting system clock to 2000-01-01T00:00:08 UTC (946684808) [ 2.061844] s2mps11-clk s2mps11-clk: DMA mask not set [ 2.076557] exynos-tmu 10060000.tmu: More trip points than supported by this TMU. [ 2.082622] exynos-tmu 10060000.tmu: 2 trip points should be configured in polling mode. [ 2.092426] exynos-tmu 10064000.tmu: More trip points than supported by this TMU. [ 2.098440] exynos-tmu 10064000.tmu: 2 trip points should be configured in polling mode. [ 2.108348] exynos-tmu 10068000.tmu: More trip points than supported by this TMU. [ 2.114407] exynos-tmu 10068000.tmu: 2 trip points should be configured in polling mode. [ 2.124320] exynos-tmu 1006c000.tmu: More trip points than supported by this TMU. [ 2.130338] exynos-tmu 1006c000.tmu: 2 trip points should be configured in polling mode. [ 2.140250] exynos-tmu 100a0000.tmu: More trip points than supported by this TMU. [ 2.146302] exynos-tmu 100a0000.tmu: 6 trip points should be configured in polling mode. [ 2.155544] s3c2410-wdt 101d0000.watchdog: watchdog inactive, reset disabled, irq disabled [ 2.163331] device-mapper: uevent: version 1.0.3 [ 2.167537] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com [ 2.191451] sdhci: Secure Digital Host Controller Interface driver [ 2.196199] sdhci: Copyright(c) Pierre Ossman [ 2.201064] Synopsys Designware Multimedia Card Interface Driver [ 2.208067] dwmmc_exynos 12220000.mmc: IDMAC supports 32-bit address mode. [ 2.208115] dwmmc_exynos 12200000.mmc: IDMAC supports 32-bit address mode. [ 2.220477] dwmmc_exynos 12220000.mmc: Using internal DMA controller. [ 2.224492] s5p-secss 10830000.sss: s5p-sss driver registered [ 2.226796] dwmmc_exynos 12220000.mmc: Version ID is 250a [ 2.232750] dwmmc_exynos 12200000.mmc: Using internal DMA controller. [ 2.234102] hid: raw HID events driver (C) Jiri Kosina [ 2.238124] dwmmc_exynos 12220000.mmc: DW MMC controller at irq 144,64 bit host data width,64 deep fifo [ 2.244291] dwmmc_exynos 12200000.mmc: Version ID is 250a [ 2.264162] dwmmc_exynos 12200000.mmc: DW MMC controller at irq 145,64 bit host data width,64 deep fifo [ 2.268759] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 2.275936] dwmmc_exynos 12200000.mmc: allocated mmc-pwrseq [ 2.292675] exynos-nocp: new NoC Probe device registered: 10ca1000.nocp [ 2.297970] exynos-nocp: new NoC Probe device registered: 10ca1400.nocp [ 2.304571] exynos-nocp: new NoC Probe device registered: 10ca1800.nocp [ 2.305514] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 2.312086] exynos-nocp: new NoC Probe device registered: 10ca1c00.nocp [ 2.327451] exynos-ppmu: new PPMU device registered 10d00000.ppmu (ppmu-event3-dmc0-0) [ 2.335102] exynos-ppmu: new PPMU device registered 10d10000.ppmu (ppmu-event3-dmc0-1) [ 2.342974] exynos-ppmu: new PPMU device registered 10d60000.ppmu (ppmu-event3-dmc1-0) [ 2.350839] exynos-ppmu: new PPMU device registered 10d70000.ppmu (ppmu-event3-dmc1-1) [ 2.361081] exynos5-dmc 10c20000.memory-controller: error -ENXIO: IRQ drex_0 not found [ 2.367518] exynos5-dmc 10c20000.memory-controller: error -ENXIO: IRQ drex_1 not found [ 2.375591] exynos5-dmc 10c20000.memory-controller: DMC initialized, in irq mode: 0 [ 2.384755] mmc_host mmc0: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0) [ 2.394797] samsung-i2s 3830000.i2s-sec: DMA channels sourced from device 3830000.i2s [ 2.397011] mmc0: new ultra high speed SDR104 SDHC card at address aaaa [ 2.407340] NET: Registered PF_PACKET protocol family [ 2.409624] mmcblk0: mmc0:aaaa SE32G 29.7 GiB [ 2.412797] NET: Registered PF_KEY protocol family [ 2.422627] Key type dns_resolver registered [ 2.426187] mmcblk0: p1 p2 [ 2.426754] Registering SWP/SWPB emulation handler [ 2.434051] registered taskstats version 1 [ 2.437817] Loading compiled-in X.509 certificates [ 2.443116] Key type .fscrypt registered [ 2.446464] Key type fscrypt-provisioning registered [ 2.457336] Key type encrypted registered [ 2.588749] exynos-chipid 10000000.chipid: cpu0 opp0, freq: 1500 missing [ 2.594193] exynos-chipid 10000000.chipid: cpu4 opp0, freq: 2100 missing [ 2.600762] exynos-chipid 10000000.chipid: Exynos: CPU[EXYNOS5800] PRO_ID[0xe5422000] REV[0x1] Detected [ 2.617722] OF: graph: no port node found in /soc/hdmi@14530000 [ 2.624147] [drm] Exynos DRM: using 14450000.mixer device for DMA mapping operations [ 2.630520] exynos-drm exynos-drm: bound 14450000.mixer (ops 0xc0e7bc8c) [ 2.637165] exynos-drm exynos-drm: bound 14530000.hdmi (ops 0xc0e7c26c) [ 2.643884] exynos-drm-g2d 10850000.g2d: The Exynos G2D (ver 4.1) successfully registered. [ 2.651958] exynos-drm exynos-drm: bound 10850000.g2d (ops 0xc0e7d27c) [ 2.658441] exynos-rotator 11c00000.rotator: The exynos rotator has been probed successfully [ 2.666855] exynos-drm exynos-drm: bound 11c00000.rotator (ops 0xc0e7db08) [ 2.673723] exynos-scaler 12800000.scaler: The exynos scaler has been probed successfully [ 2.681842] exynos-drm exynos-drm: bound 12800000.scaler (ops 0xc0e7e250) [ 2.688607] exynos-scaler 12810000.scaler: The exynos scaler has been probed successfully [ 2.696755] exynos-drm exynos-drm: bound 12810000.scaler (ops 0xc0e7e250) [ 2.703526] exynos-scaler 12820000.scaler: The exynos scaler has been probed successfully [ 2.711662] exynos-drm exynos-drm: bound 12820000.scaler (ops 0xc0e7e250) [ 2.718396] exynos-drm-gsc 13e00000.video-scaler: The exynos gscaler has been probed successfully [ 2.727314] exynos-drm exynos-drm: bound 13e00000.video-scaler (ops 0xc0e7eb24) [ 2.734594] exynos-drm-gsc 13e10000.video-scaler: The exynos gscaler has been probed successfully [ 2.743425] exynos-drm exynos-drm: bound 13e10000.video-scaler (ops 0xc0e7eb24) [ 2.791131] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 2.838676] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 2.878753] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 2.907827] Console: switching to colour frame buffer device 180x56 [ 2.973325] exynos-drm exynos-drm: [drm] fb0: exynosdrmfb frame buffer device [ 2.984476] [drm] Initialized exynos 1.1.0 20180330 for exynos-drm on minor 0 [ 3.004351] mali 11800000.gpu: GPU identified as 0x0620 r0p1 status 0 [ 3.010719] mali 11800000.gpu: Protected mode not available [ 3.018316] mali 11800000.gpu: Probed as mali0 [ 3.026735] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [ 3.030849] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3 [ 3.039677] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010 [ 3.048138] xhci-hcd xhci-hcd.8.auto: irq 153, io mem 0x12000000 [ 3.054235] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [ 3.059294] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4 [ 3.066981] xhci-hcd xhci-hcd.8.auto: Host supports USB 3.0 SuperSpeed [ 3.073679] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 3.081733] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.088855] usb usb3: Product: xHCI Host Controller [ 3.093692] usb usb3: Manufacturer: Linux 6.1.77+ xhci-hcd [ 3.099147] usb usb3: SerialNumber: xhci-hcd.8.auto [ 3.105733] hub 3-0:1.0: USB hub found [ 3.108240] hub 3-0:1.0: 1 port detected [ 3.113412] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.120627] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 3.128666] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.135843] usb usb4: Product: xHCI Host Controller [ 3.140461] usb usb4: Manufacturer: Linux 6.1.77+ xhci-hcd [ 3.148036] usb usb4: SerialNumber: xhci-hcd.8.auto [ 3.153685] hub 4-0:1.0: USB hub found [ 3.157741] hub 4-0:1.0: 1 port detected [ 3.169399] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller [ 3.175224] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5 [ 3.183781] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010 [ 3.193572] xhci-hcd xhci-hcd.9.auto: irq 154, io mem 0x12400000 [ 3.200100] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller [ 3.205886] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6 [ 3.213785] xhci-hcd xhci-hcd.9.auto: Host supports USB 3.0 SuperSpeed [ 3.220664] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 3.229213] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.236762] usb usb5: Product: xHCI Host Controller [ 3.241897] usb usb5: Manufacturer: Linux 6.1.77+ xhci-hcd [ 3.247575] usb usb5: SerialNumber: xhci-hcd.9.auto [ 3.253145] hub 5-0:1.0: USB hub found [ 3.257072] hub 5-0:1.0: 1 port detected [ 3.261543] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.269904] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 3.278421] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.285801] usb usb6: Product: xHCI Host Controller [ 3.290803] usb usb6: Manufacturer: Linux 6.1.77+ xhci-hcd [ 3.292505] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 3.294925] usb usb6: SerialNumber: xhci-hcd.9.auto [ 3.314476] hub 6-0:1.0: USB hub found [ 3.318373] hub 6-0:1.0: 1 port detected [ 3.324905] s3c-rtc 101e0000.rtc: rtc disabled, re-enabling [ 3.330709] s3c-rtc 101e0000.rtc: registered as rtc1 [ 3.340796] exynos-bus: new bus device registered: soc:bus-wcore ( 88700 KHz ~ 532000 KHz) [ 3.345656] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 3.348273] exynos-bus: new bus device registered: soc:bus-noc ( 66600 KHz ~ 111000 KHz) [ 3.370263] exynos-bus: new bus device registered: soc:bus-fsys-apb (111000 KHz ~ 222000 KHz) [ 3.379488] exynos-bus: new bus device registered: soc:bus-fsys2 ( 75000 KHz ~ 200000 KHz) [ 3.388608] exynos-bus: new bus device registered: soc:bus-mfc ( 83250 KHz ~ 333000 KHz) [ 3.397524] exynos-bus: new bus device registered: soc:bus-gen ( 88700 KHz ~ 266000 KHz) [ 3.406667] exynos-bus: new bus device registered: soc:bus-peri ( 66600 KHz ~ 66600 KHz) [ 3.411109] usb 3-1: new high-speed USB device number 2 using xhci-hcd [ 3.419851] exynos-bus: new bus device registered: soc:bus-g2d ( 83250 KHz ~ 333000 KHz) [ 3.431814] exynos-bus: new bus device registered: soc:bus-g2d-acp ( 66500 KHz ~ 266000 KHz) [ 3.440249] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 3.440969] exynos-bus: new bus device registered: soc:bus-jpeg ( 75000 KHz ~ 300000 KHz) [ 3.460397] exynos-bus: new bus device registered: soc:bus-jpeg-apb ( 83250 KHz ~ 166500 KHz) [ 3.469573] exynos-bus: new bus device registered: soc:bus-disp1-fimd (120000 KHz ~ 200000 KHz) [ 3.478997] exynos-bus: new bus device registered: soc:bus-disp1 (120000 KHz ~ 300000 KHz) [ 3.487932] exynos-bus: new bus device registered: soc:bus-gscl-scaler (150000 KHz ~ 300000 KHz) [ 3.497582] exynos-bus: new bus device registered: soc:bus-mscl ( 84000 KHz ~ 666000 KHz) [ 3.508589] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 3.535680] ALSA device list: [ 3.539420] #0: ODROID-XU4 [ 3.544075] Waiting for root device UUID=e139ce78-9841-40fe-8823-96a304a09859... [ 3.605856] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=22.23 [ 3.615230] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.623491] usb 3-1: Product: USB2.0 Hub [ 3.628491] usb 3-1: Manufacturer: GenesysLogic [ 3.682358] hub 3-1:1.0: USB hub found [ 3.689564] hub 3-1:1.0: 2 ports detected [ 3.751499] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd [ 3.794759] usb 4-1: New USB device found, idVendor=05e3, idProduct=0616, bcdDevice=22.23 [ 3.805887] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.815965] usb 4-1: Product: USB3.0 Hub [ 3.822775] usb 4-1: Manufacturer: GenesysLogic [ 3.858309] hub 4-1:1.0: USB hub found [ 3.863915] hub 4-1:1.0: 2 ports detected [ 4.061238] usb 3-1.1: new low-speed USB device number 3 using xhci-hcd [ 4.206144] usb 3-1.1: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00 [ 4.221958] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.233307] usb 3-1.1: Product: USB Optical Mouse [ 4.238474] usb 3-1.1: Manufacturer: Logitech [ 4.371238] usb 6-1: new SuperSpeed USB device number 2 using xhci-hcd [ 4.391069] usb 3-1.2: new low-speed USB device number 4 using xhci-hcd [ 4.412822] usb 6-1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00 [ 4.422627] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 4.431336] usb 6-1: Product: USB 10/100/1000 LAN [ 4.437514] usb 6-1: Manufacturer: Realtek [ 4.443094] usb 6-1: SerialNumber: 000001000000 [ 4.536824] usb 3-1.2: New USB device found, idVendor=1a2c, idProduct=2d23, bcdDevice= 1.10 [ 4.549773] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.559722] usb 3-1.2: Product: USB Keyboard [ 4.564096] usb 3-1.2: Manufacturer: USB [ 4.677461] r8152-cfgselector 6-1: reset SuperSpeed USB device number 2 using xhci-hcd [ 4.733246] r8152 6-1:1.0: Direct firmware load for rtl_nic/rtl8153a-3.fw failed with error -2 [ 4.742982] r8152 6-1:1.0: unable to load firmware patch rtl_nic/rtl8153a-3.fw (-2) [ 4.793138] r8152 6-1:1.0 eth0: v1.12.13 [ 4.939315] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 5.000498] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 5.060339] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 5.119528] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 5.459354] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 5.522765] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 5.578951] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 5.635751] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 5.979379] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 6.042260] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 6.098485] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 6.157505] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 6.498761] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 6.556671] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 6.612113] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 6.668707] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 7.009370] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 7.070667] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 7.126100] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 7.183829] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
