jam123
  1. Hi, i got similar results, rk3588-eflasher-debian-bookworm-core-6.1-arm64-20240522.img works without issues but Armbian_community_24.5.0-trunk.667_Nanopi-r6s_bookworm_edge_6.8.10_minimal.img doesnt. Red light is the only one on. I got this result from the serial console - it shows an error about OPTEE: DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB Manufacturer ID:0x1 CH0 RX Vref:27.1%, TX Vref:19.8%,20.8% CH1 RX Vref:27.9%, TX Vref:19.8%,20.8% CH2 RX Vref:26.7%, TX Vref:21.8%,21.8% CH3 RX Vref:27.1%, TX Vref:20.8%,19.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-g1b1171b7c71-220418 #fa (Apr 18 2024 - 11:12:44) unknown raw ID 0 0 0 unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 No misc partition spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7efcd01a0f...) + OK ## Checking uboot 0x00200000 ... sha256(b76f2f6c2a...) + OK ## Checking fdt 0x0031ec90 ... sha256(c5d44f02b4...) + OK ## Checking atf-2 0x000f0000 ... sha256(da90adf3a4...) + OK ## Checking atf-3 0xff100000 ... sha256(1163474a5b...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 402.313/555.636 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-589-g3389cfdda:derrick.huang NOTICE: BL31: Built : 10:14:29, May 9 2023 INFO: spec: 0x13 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: system boots from cpu-hwid-0 INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 ERROR: dfs get fsp_params[0] error, 0xfead0004 != 0xfead0003 ERROR: dfs get fsp_params[1] error, 0x1111 != 0xfead0003 ERROR: dfs get fsp_params[2] error, 0x0 != 0xfead0003 ERROR: dfs get fsp_params[3] error, 0x60241520 != 0xfead0003 ERROR: loader&trust unmatch!!! Please update trust if need enable dmc INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (May 21 2024 - 16:20:03 +0000) Model: NanoPi R6S MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 8 GiB Sysmem: init Relocation Offset: eda3f000 Relocation fdt: eb9f9960 - eb9fecd0 CR: M/C/I Using default environment optee check api revision fail: -1.0 optee api revision is too low ### ERROR ### Please RESET the board ### I have no idea (yet) what that means or how to fix it. Any hints are apreciated :), thanks, J.
