- Emby server in Orange Pi5
Hope to get rtl8852be wifi driver support for kernel 6.1
@GicaContra I also noticed this problem: first boot can turn on the wifi but can not connect to AP. After install the DKMS driver ,try to reboot twice then it should be worked fine. Edge kernel is 6.10, the 8852be driver is included in the mainline kernel about 6.2, so it should work, but edge kernel will lost many hardware supports on the board, it's not recommended.
I think It's also wired after that PR the 8852BE driver is still not added into the OS build. Now I have compile the the DKMS driver by myself, you can simply install it through APT. Download here sudo apt install -f ./rtw8852be-dkms_1.0.0_all.deb Rember to turn off system auto-suspend: sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target Good luck!
- No WiFi on latest image
I have armbian-firmware-full installed. By the way, the config you mentioned in github is linux-rk35xx-legacy(kernel 5.10), not the linux-rk35xx-vendor(kernel 6.1) used in Armbian 24.5.1 Stable. This topic has also mentioned about the lost rtl8852be driver: No WiFi on latest image - Orange Pi 5 Plus - Armbian Community Forums Thanks!
Unfortunately, "sudo modprobe rtw89" didn't work. It returned this with error: "modprobe: FATAL: Module rtw89 not found in directory /lib/modules/6.1.43-vendor-rk35xx" I think it may be lost 8852BE kernel module? In directory /lib/modules/6.1.43-vendor-rk35xx/kernel/drivers/net/wireless/realtek/rtw89, I find "rtw89_8852c.ko", "rtw89_8852ae.ko", "rtw89_8852ce.ko", just without "rtw89_8852be.ko".
- Hope to get rtl8852be wifi driver support for kernel 6.1
