- Armbian doesnt seem to see sata harddrives.
Problem with apt update on stable release.
Hi, it is strange, I'm in Czech republic on Vodafone network. It really doesn't work. So I have tried to connect over my mobile phone and now it work fine. Can be some problem with routing on my provider? apt update Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://security.debian.org bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Err:5 http://imola.armbian.com/apt bookworm InRelease Could not connect to imola.armbian.com:80 (93.103.15.56), connection timed out Reading package lists... Done Building dependency tree... Done Reading state information... Done 11 packages can be upgraded. Run 'apt list --upgradable' to see them. W: Failed to fetch http://apt.armbian.com/dists/bookworm/InRelease Could not connect to imola.armbian.com:80 (93.103.15.56), connection timed out W: Some index files failed to download. They have been ignored, or old ones used instead.
All Armbians with Kernel 6.8.x woun't start on Radaxa Rock 5b
Hi, I hate you (sorry just joke) 🙂 I have no UART to USB cable so I found old Teensy 3.2 board. Made program for Serial to USB bridge. Updated SPI flash with new firmware with debug mode. And.... It works now! Dam or huray... 😉 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB Manufacturer ID:0x6 CH0 RX Vref:27.5%, TX Vref:25.8%,25.8% CH1 RX Vref:25.8%, TX Vref:25.8%,25.8% CH2 RX Vref:27.9%, TX Vref:24.8%,24.8% CH3 RX Vref:27.1%, TX Vref:24.8%,24.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28) Trying to boot from MMC2 MMC: no card present mmc_init: -123, time 0 spl: mmc init failed with error: -123 Trying to boot from MTD2 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK ## Checking uboot 0x00200000 ... sha256(25a398ffe0...) + OK ## Checking fdt 0x0031e9f8 ... sha256(5bee414074...) + OK ## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK ## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 489.724/719.766 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45 NOTICE: BL31: Built : 10:11:21, Dec 27 2023 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28 +0800) Model: Radxa ROCK 5B MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 16 GiB Sysmem: init Relocation Offset: eda3f000 Relocation fdt: eb9f96c0 - eb9fecc8 CR: M/C/I Using default environment DM: v2 mmc@fe2c0000: 1, mmc@fe2e0000: 0 Bootdev(assign): mmc 0 MMC0: HS400 Enhanced Strobe, 200Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Radxa ROCK 5B MPIDR: 0x81000000 CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... No working controllers found USB is stopped. Please issue 'usb start' first. MMC: no card present mmc_init: -123, time 0 pcie@fe150000: PCIe Linking... LTSSM is 0x0 pcie@fe150000: PCIe Linking... LTSSM is 0x0 pcie@fe150000: PCIe Linking... LTSSM is 0x6 pcie@fe150000: PCIe Linking... LTSSM is 0x210023 pcie@fe150000: PCIe Link up, LTSSM is 0x230011 pcie@fe150000: PCIE-0: Link up (Gen3-x2, Bus0) pcie@fe150000: invalid flags type! Device 0: unknown device Device 1: unknown device switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3920 bytes read in 8 ms (478.5 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0:1 172 bytes read in 8 ms (20.5 KiB/s) 26373283 bytes read in 112 ms (224.6 MiB/s) 32436736 bytes read in 142 ms (217.8 MiB/s) 163397 bytes read in 28 ms (5.6 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 26373219 Bytes = 25.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=8e000 Using Device Tree in place at 0000000008300000, end 0000000008390fff can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory WARNING: could not set reg FDT_ERR_BADOFFSET. Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000) Total: 2321.467/3095.859 ms Starting kernel ...
Problem with KODI on Armbian Noble Gnome + trunk MESA/VPU
Hi, I do not konow, it this is the right place to raise this ticket. But in stable releases of Armbian it works fine, but there is no video acceleration. I have tried Kodi on Armbian Noble Gnome + trunk MESA/VPU: Armbian_24.8.0-trunk.85_Rock-5b_noble_vendor_6.1.43_gnome-oibaf_desktop.img Kodi falling when I'm trying to install some of extensions. For example https://repo.sc2.zone/ Crash log in the attachment. System log: 2024-06-05T12:01:28.534687+02:00 rock-5b kodi.desktop[3739]: Fatal Python error: PyImport_AppendInittab: PyImport_AppendInittab() may not be called after Py_Initialize() 2024-06-05T12:01:28.535024+02:00 rock-5b kodi.desktop[3739]: Python runtime state: initialized 2024-06-05T12:01:28.535112+02:00 rock-5b kodi.desktop[3739]: Thread 0x0000ffff3afde0c0 (most recent call first): 2024-06-05T12:01:28.535191+02:00 rock-5b kodi.desktop[3739]: <no Python frame> 2024-06-05T12:01:28.612980+02:00 rock-5b kodi.desktop[3732]: Aborted 2024-06-05T12:01:28.640388+02:00 rock-5b kodi.desktop[3732]: Crash report available at /home/tomogo/kodi_crashlog-20240605_120128.log kodi_crashlog-20240605_115433.log
Hi, I've installed Armbian_24.5.1_Rock-5b_bookworm_vendor_6.1.43_cinnamon_desktop.img on my Rock 5b and when I have tried to do apt update get error message with armbian.com url. (timeout error) I did all necessary and now it work fine. But for dev info, there is some problem probably with all Stable images.
- All Armbians with Kernel 6.8.x woun't start on Radaxa Rock 5b
Tomogo
