Pinebook Pro Kernel on RockPro64
I got in contact with the kernels author and got told, that DP-Alt is not yet implemented for the rockpro64. Looking at the schematics, the usb-c controller seems identically to the pinebook pro. I am ready to start digging in the device-tree file for the rkp64 by comparing the pbp to the rkp64. But I don't know how to create and test the Kernel from these files.
- Pinebook Pro Kernel on RockPro64
So far i cant log in via ssh. The main LED is blinking and also the network LED seems to indicate a connection. But my Router does not give an IP to it. I will compile the image again and report here. Sorry if it might take me some days to reply sometimes, but I will continue to work on this.
I did that on my home Debian installation and the resulting image seems to boot, but there is no display output on HDMI or DP. It might be, because i did not do it in the recommended way of using ubuntu in a vm. I will try that and report here. I am using Debian for around eight years exclusively and do some python and arduino programming. I never worked on a big project.
Thanks. I understand that. I just thought maybe someone, who is more knowledgeable then me had this problem and found a solution. I want to add, that i found this Kernel repository, that seems to have patches that make DP-Alt mode work for PBP and maybe also RockPro. Maybe it can be of help.
Hi, I read everything I could possibly find on the DP-Alt mode for the RockPro64 and came to the conclusion that no Distro is offering that right now. However, the Pinebook Pro seems to have support via a Kernel Patch. Can the Pinebook Pro Kernel be installed on the RockPro64? Is there a repository for Armbian Kernels? Thanks very much.
rockmusic64
