NixiElectra
  1. Hello, I have created copies for both radxa-zero3-disabled-wireless.dts & radxa-zero3-disabled-ethernet.dts, add them using armbian-add-overlay and all working great. Thank you for the idea, cheers
  2. Hello, I have questions related with overlay. I'm using Radxa Zero 3W and in the /boot/armbianEnv.txt it has overlay_prefix=rk35xx. I want to use this overlay /boot/dtb/rockchip/overlay/radxa-zero3-disabled-wireless.dtbo. If I cat /boot/boot.cmd it read the overlays with this line ${overlay_prefix}-${overlay_file}.dtbo. It means if I add overlays=disabled-wireless in /boot/armbianEnv.txt, it will not find the dtbo right? So my questions are, 1. Can I manually edit the overlay_prefix to radxa-zero3? 2. If can then will that has impact on the feature, eg kernel upgrade or anything?
  3. I'm also face the same issue with USB Gigabit Ethernet on Zero 3W. https://paste.armbian.com/ozatawamaf
  4. Just to update, with Armbian 24.8.2 Bookworm the temperature is now available.
  5. Hello, I'm using Armbian 24.5.3 Bookworm Minimal / IOT but there is no temperature in motd. When I inspect the normal datasources, it symlink to non-existent folder.
  6. I found out that there was a file that caused this /etc/systemd/resolved.conf.d/00-armbian-default-dns.conf. After removing that, the issue solved. Now only one nameserver exist in the resolv.conf. Cheers
  7. Hello, I've issue with nameserver. My router DHCP DNS server point to the Pi which has IP 10.6.6.3. But for unknown reason 1.0.0.1 keep added in the /etc/resolv.conf: # This is /run/systemd/resolve/resolv.conf managed by man:systemd-resolved(8). # Do not edit. # # This file might be symlinked as /etc/resolv.conf. If you're looking at # /etc/resolv.conf and seeing this text, you have followed the symlink. # # This is a dynamic resolv.conf file for connecting local clients directly to # all known uplink DNS servers. This file lists all configured search domains. # # Third party programs should typically not access this file directly, but only # through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a # different way, replace this symlink by a static file or a different symlink. # # See man:systemd-resolved.service(8) for details about the supported modes of # operation for /etc/resolv.conf. nameserver 1.0.0.1 nameserver 10.6.6.3 search . I've tried to manually edit and remove it from /etc/resolv.conf but it will come back. I'm using image from https://github.com/armbian/community/releases/download/24.8.0-trunk.495/Armbian_community_24.8.0-trunk.495_Orangepizero2w_bookworm_current_6.6.36_minimal.img.xz 10-dhcp-all-interfaces.yaml # Added by Armbian # # Reference: https://netplan.readthedocs.io/en/stable/netplan-yaml/ # # Let systemd-networkd manage all Ethernet devices on this system, but be configured by Netplan. network: version: 2 renderer: networkd ethernets: all-eth-interfaces: match: name: "e*" dhcp4: yes link-local: [ ipv4 ] Is there anything I'm missing?
  8. After switching to Samsung 25W power adapter, able to achieve 95Mbps on download. Meaning the 5V2A as advertise in their website was not enough I guess if use with USB device but no issue if use WiFi. Can closed this.
  9. Hello, I'm using USB C to Ethernet adapter and the download speed is below 1Mbps while upload speed as expected. I have 600Mbps down and 500Mbps up ISP plan but since the adapter used USB2.0 it should cap both down and up at ~90Mbps, at least I have tested this with a Galaxy Tab. Image: Armbian_community_24.8.0-trunk.399_Orangepizero2w_bookworm_current_6.6.36_minimal.img.xz Power supply: 5V2A SD: Sandisk Ultra 64GB Adapter (100Mbps): Speedtest: ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: enxec9a0c1e8e6f: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000 link/ether ec:9a:0c:1e:8e:6f brd ff:ff:ff:ff:ff:ff inet 10.7.4.11/24 metric 100 brd 10.7.4.255 scope global dynamic enxec9a0c1e8e6f valid_lft 86390sec preferred_lft 86390sec 3: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000 link/ether fe:ae:6b:87:53:f1 brd ff:ff:ff:ff:ff:ff 4: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000 link/ether 48:f5:61:9d:46:2c brd ff:ff:ff:ff:ff:ff inet 169.254.247.42/16 metric 2048 brd 169.254.255.255 scope link wlan0 valid_lft forever preferred_lft forever
