UmutU123
  1. @usual user I genuinely appreciate the time you take to answer my post. I am pretty sure, I am doing it right. I am going to keep trying once in a while. Thanks for your help, I will mark this as solved then. Next buy, I will make sure the recovery mode is easy to access haha
  2. @usual user I tried that exact method, for whatever reason, I am not getting into MaskRom_mode. I tried shorting with ground each point, I tried shorting against each other. I tried shorting one of them. I used simple jumper cables which might be the issue (I dont think so tbh) but nothing I do works. Same red LED lighting up, no response from the board. Same output as in the first post. I think I am going to give up trying tbh, I might have really bricked the first orange pi. Usually I could get it back up but this time I am kinda hopeless.
  3. @usual user So i got a dc charger but nothing I do gets me into the Maskrom mode. I am not even sure on how to flash the suitable firmware at this point. Prolly the first bricked orange pi it is lmao
  4. Hello everyone, I somehow managed to brick my OrangePi 4 LTS. I had the Armbian running on it and decided to try the newest install in a minimal format so no desktop. Installed it, made all the setup and restarted. Since then no other image works, neither the official orangepi images nor any other armbian image. I tried booting off without the SD Card, trying to flash another OS with the SD card and read out the TTL and this is what I get: DDR Version 1.25 20210517 In channel 0 CS = 0 MR0=0x18 MR4=0x2 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x2 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x2 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x2 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT After this, nothing happens. Red light still on, no HDMI image, nothing. I don't know what to do from here. Not even sure if I can reset it. I tried another SD card and nothing works. Any tips?
