USB 3.0 Drive Recognized as USB 2.0 After Boot
I am so glad that you posted this. I found a similar issue but more consistent. I have a Rock PI 4C+ running Armbian_23.11.1_Rockpi-4cplus_bookworm_current_6.1.63.img and this is what "lsusb" returns: ~# lsusb -t /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M I have a USB 3 drive that only registers at the bottom USB 3 port. It is ignored in any other port. But when inserted into the top USB 2 port and /dev/sg0 device shows up - which is as I understand a "generic SCSI layer". Only USB 2 devices are registered at any of the other ports. When I run "dmesg" it run amok in the end where it only stops on ctrl-c. So I post the boot log and start up log =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.10.09 20:01:31 =~=~=~=~=~=~=~=~=~=~=~= U-Boot TPL 2022.07-armbian (Nov 26 2023 - 16:22:47) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2022.07-armbian (Nov 26 2023 - 16:22:47 +0000) Trying to boot from MMC2 NOTICE: BL31: v1.3(release):845ee93 NOTICE: BL31: Built : 15:51:11, Jul 22 2020 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: If lpddr4 need support multi frequency, INFO: please update loader! INFO: Current ctl index[0] freq=400MHz INFO: Current ctl index[1] freq=800MHz INFO: plat_rockchip_pmu_init(1196): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2022.07-armbian (Nov 26 2023 - 16:22:47 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: Radxa ROCK Pi 4C DRAM: 3.9 GiB Core: 285 devices, 31 uclasses, devicetree: separate MMC: mmc@fe310000: 2, mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from SPIFlash... jedec_spi_nor flash@0: unrecognized JEDEC id bytes: ff, ff, ff *** Warning - spi_flash_probe_bus_cs() failed, using default environment In: serial Out: serial Err: serial Model: Radxa ROCK Pi 4C can't get vref-supply: -121 rockchip_dnl_key_pressed: adc_channel_single_shot fail! Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus usb@fe800000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fe900000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe800000 for devices... 1 USB Device(s) found scanning bus usb@fe900000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3252 bytes read in 5 ms (634.8 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 210 bytes read in 4 ms (50.8 KiB/s) 21615543 bytes read in 917 ms (22.5 MiB/s) 29729280 bytes read in 1259 ms (22.5 MiB/s) 78099 bytes read in 13 ms (5.7 MiB/s) 2698 bytes read in 8 ms (329.1 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=3f00000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 21615479 Bytes = 20.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f0a6e000, end f1f0b377 ... OK Loading Device Tree to 00000000f09f2000, end 00000000f0a6dfff ... OK Starting kernel ... efi_free_pool: illegal free 0x00000000f0f0d040 efi_free_pool: illegal free 0x00000000f0f0a040 [2J[3J[-1;-1fdone. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.38.1 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 armbi_root: clean, 49522/7378032 files, 961229/30900224 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Armbian 24.8.4 bookworm! OK Created slice system-getty.slice - Slice /system/getty. OK Created slice system-modpr…lice - Slice /system/modprobe. OK Created slice system-seria… - Slice /system/serial-getty. OK Created slice user.slice - User and Session Slice. OK Started systemd-ask-passwo… Requests to Wall Directory Watch. OK Set up automount proc-sys-…rmats File System Automount Point. Expecting device dev-ttyS2.device - /dev/ttyS2... OK Reached target integrityse…Local Integrity Protected Volumes. OK Reached target slices.target - Slice Units. OK Reached target swap.target - Swaps. OK Reached target time-set.target - System Time Set. OK Reached target veritysetup… - Local Verity Protected Volumes. OK Listening on rpcbind.socke… RPCbind Server Activation Socket. OK Listening on syslog.socket - Syslog Socket. OK Listening on systemd-fsckd…sck to fsckd communication Socket. OK Listening on systemd-initc… initctl Compatibility Named Pipe. OK Listening on systemd-journ…socket - Journal Audit Socket. OK Listening on systemd-journ…t - Journal Socket (/dev/log). OK Listening on systemd-journald.socket - Journal Socket. OK Listening on systemd-udevd….socket - udev Control Socket. OK Listening on systemd-udevd…l.socket - udev Kernel Socket. Mounting dev-hugepages.mount - Huge Pages File System... Mounting dev-mqueue.mount…POSIX Message Queue File System... Mounting sys-kernel-debug.… - Kernel Debug File System... Mounting sys-kernel-tracin… - Kernel Trace File System... Starting fake-hwclock.serv…estore / save the current clock... Starting keyboard-setup.se…Set the console keyboard layout... Starting kmod-static-nodes…ate List of Static Device Nodes... Starting modprobe@configfs…m - Load Kernel Module configfs... Starting modprobe@dm_mod.s…[0m - Load Kernel Module dm_mod... Starting modprobe@drm.service - Load Kernel Module drm... Starting modprobe@efi_psto…- Load Kernel Module efi_pstore... Starting modprobe@fuse.ser…e - Load Kernel Module fuse... Starting modprobe@loop.ser…e - Load Kernel Module loop... Starting systemd-modules-l…rvice - Load Kernel Modules... Starting systemd-remount-f…nt Root and Kernel File Systems... Starting systemd-udev-trig…[0m - Coldplug All udev Devices... OK Mounted dev-hugepages.mount - Huge Pages File System. OK Mounted dev-mqueue.mount[…- POSIX Message Queue File System. OK Mounted sys-kernel-debug.m…nt - Kernel Debug File System. OK Mounted sys-kernel-tracing…nt - Kernel Trace File System. OK Finished fake-hwclock.serv… Restore / save the current clock. OK Finished kmod-static-nodes…reate List of Static Device Nodes. OK Finished modprobe@configfs…[0m - Load Kernel Module configfs. OK Finished modprobe@dm_mod.s…e - Load Kernel Module dm_mod. OK Finished modprobe@drm.service - Load Kernel Module drm. OK Finished modprobe@efi_psto…m - Load Kernel Module efi_pstore. OK Finished modprobe@fuse.service - Load Kernel Module fuse. OK Finished modprobe@loop.service - Load Kernel Module loop. Mounting sys-fs-fuse-conne… - FUSE Control File System... Mounting sys-kernel-config…ernel Configuration File System... OK Finished systemd-modules-l…service - Load Kernel Modules. OK Finished systemd-remount-f…ount Root and Kernel File Systems. OK Mounted sys-fs-fuse-connec…nt - FUSE Control File System. OK Mounted sys-kernel-config.… Kernel Configuration File System. Starting systemd-random-se…ice - Load/Save Random Seed... Starting systemd-sysctl.se…ce - Apply Kernel Variables... Starting systemd-sysusers.…rvice - Create System Users... OK Finished systemd-sysctl.service - Apply Kernel Variables. OK Finished systemd-sysusers.service - Create System Users. Starting systemd-tmpfiles-…ate Static Device Nodes in /dev... OK Finished keyboard-setup.se…- Set the console keyboard layout. OK Finished systemd-tmpfiles-…reate Static Device Nodes in /dev. OK Reached target local-fs-pr…reparation for Local File Systems. Starting systemd-udevd.ser…ger for Device Events and Files... OK Started systemd-udevd.serv…nager for Device Events and Files. OK Finished systemd-udev-trig…e - Coldplug All udev Devices. Starting ifupdown-pre.serv…ynchronize boot up for ifupdown... Starting plymouth-start.se…[0m - Show Plymouth Boot Screen... OK Found device dev-ttyS2.device - /dev/ttyS2. OK Started plymouth-start.ser…e - Show Plymouth Boot Screen. OK Started systemd-ask-passwo…uests to Plymouth Directory Watch. OK Reached target cryptsetup.…get - Local Encrypted Volumes. OK Reached target paths.target - Path Units. Mounting tmp.mount - /tmp... OK Mounted tmp.mount - /tmp. OK Reached target local-fs.target - Local File Systems. Starting armbian-zram-conf…rvice - Armbian ZRAM config... Starting console-setup.ser…m - Set console font and keymap... Starting plymouth-read-wri…mouth To Write Out Runtime Data... Starting systemd-binfmt.se…et Up Additional Binary Formats... OK Finished console-setup.ser…[0m - Set console font and keymap. OK Finished plymouth-read-wri…lymouth To Write Out Runtime Data. Mounting proc-sys-fs-binfm…utable File Formats File System... Expecting device sys-subsy…/sys/subsystem/net/devices/end0... OK Mounted proc-sys-fs-binfmt…ecutable File Formats File System. OK Found device sys-subsystem…- /sys/subsystem/net/devices/end0. OK Started ifup@end0.service - ifup for end0. OK Finished systemd-binfmt.se… Set Up Additional Binary Formats. OK Reached target usb-gadget.…m - Hardware activated USB gadget. OK Finished systemd-random-se…rvice - Load/Save Random Seed. OK Listening on systemd-rfkil…l Switch Status /dev/rfkill Watch. OK Finished ifupdown-pre.serv… synchronize boot up for ifupdown. Starting networking.service - Raise network interfaces... Starting systemd-rfkill.se…Load/Save RF Kill Switch Status... OK Started systemd-rfkill.ser…- Load/Save RF Kill Switch Status. OK Finished armbian-zram-conf…service - Armbian ZRAM config. Starting armbian-ramlog.se…rmbian memory supported logging... OK Finished networking.service - Raise network interfaces. * Job armbian-ramlog.service/start running (4s / 32s) OK Finished armbian-ramlog.se… Armbian memory supported logging. Starting systemd-journald.service - Journal Service... OK Started systemd-journald.service - Journal Service. Starting systemd-journal-f…h Journal to Persistent Storage... OK Finished systemd-journal-f…ush Journal to Persistent Storage. Starting systemd-tmpfiles-…te System Files and Directories... OK Finished systemd-tmpfiles-…eate System Files and Directories. Mounting run-rpc_pipefs.mount - RPC Pipe File System... OK Started haveged.service[0…mon based on the HAVEGE algorithm. Starting rpcbind.service - RPC bind portmap service... Starting systemd-update-ut…rd System Boot/Shutdown in UTMP... OK Mounted run-rpc_pipefs.mount - RPC Pipe File System. OK Reached target rpc_pipefs.target. OK Reached target nfs-client.target - NFS client services. OK Finished systemd-update-ut…cord System Boot/Shutdown in UTMP. OK Reached target sysinit.target - System Initialization. OK Started systemd-tmpfiles-c… Cleanup of Temporary Directories. OK Listening on dbus.socket[…- D-Bus System Message Bus Socket. OK Reached target sockets.target - Socket Units. Starting armbian-hardware-…m - Armbian hardware monitoring... Starting armbian-hardware-…- Armbian hardware optimization... OK Finished armbian-hardware-…[0m - Armbian hardware monitoring. OK Started rpcbind.service - RPC bind portmap service. OK Reached target remote-fs-p…eparation for Remote File Systems. OK Reached target remote-fs.target - Remote File Systems. OK Reached target rpcbind.target - RPC Port Mapper. OK Finished armbian-hardware-…m - Armbian hardware optimization. OK Reached target basic.target - Basic System. OK Started cron.service -…kground program processing daemon. Starting dbus.service - D-Bus System Message Bus... Starting e2scrub_reap.serv…e ext4 Metadata Check Snapshots... Starting loadcpufreq.servi…eeded to enable cpufreq scaling... Starting rng-tools-debian.…LSB: rng-tools (Debian variant)... Starting rsyslog.service - System Logging Service... Starting sysstat.service - Resets System Activity Logs... Starting systemd-logind.se…ice - User Login Management... OK Finished e2scrub_reap.serv…ine ext4 Metadata Check Snapshots. OK Finished sysstat.service - Resets System Activity Logs. OK Started rsyslog.service - System Logging Service. OK Started dbus.service - D-Bus System Message Bus. Starting NetworkManager.service - Network Manager... Starting wpa_supplicant.service - WPA supplicant... OK Started systemd-logind.service - User Login Management. OK Started loadcpufreq.servic… needed to enable cpufreq scaling. OK Started rng-tools-debian.s…- LSB: rng-tools (Debian variant). Starting cpufrequtils.serv…: set CPUFreq kernel parameters... OK Started cpufrequtils.servi…SB: set CPUFreq kernel parameters. Starting sysfsutils.servic… variables from /etc/sysfs.conf... OK Started wpa_supplicant.service - WPA supplicant. OK Started sysfsutils.service…fs variables from /etc/sysfs.conf. ** Job NetworkManager.service/start running (8s / 1min 36s) OK Started NetworkManager.service - Network Manager. OK Reached target network.target - Network. OK Reached target network-online.target - Network is Online. Starting chrony.service - chrony, an NTP client/server... Starting openvpn.service - OpenVPN service... Starting rc-local.service…m - /etc/rc.local Compatibility... Starting rpc-statd-notify.…- Notify NFS peers of a restart... Starting ssh.service - OpenBSD Secure Shell server... Starting systemd-user-sess…vice - Permit User Sessions... OK Started unattended-upgrade…0m - Unattended Upgrades Shutdown. OK Started vnstat.service - vnStat network traffic monitor. OK Finished openvpn.service - OpenVPN service. OK Started rc-local.service - /etc/rc.local Compatibility. OK Started rpc-statd-notify.s…m - Notify NFS peers of a restart. OK Finished systemd-user-sess…ervice - Permit User Sessions. Starting plymouth-quit-wai… until boot process finishes up... Starting plymouth-quit.ser… Terminate Plymouth Boot Screen... Starting systemd-hostnamed.service - Hostname Service... Armbian 24.8.4 bookworm ttyS2 a002 login:
Bitcat
