Kennedy Oliveira
  1. Updated to version 24.11.0-trunk.277 and the download speed improved a bit https://www.speedtest.net/result/c/5d2890bb-bda7-4423-8621-fa99332fe791 For the old version (24.8.4) on same conditions, same server etc: https://www.speedtest.net/result/c/f0124381-7625-4ec0-a3af-ab5238227a86 One thing I forgot to mention the problem is only for download, upload is fine, here I used speedtest cli for checking the speed, but using iperf3 has the same problem.
  2. I installed this version (v24.11) of Armbian on a Rock Pi 4A Plus with a PoE hat and observed significant network performance issues. When powered via PoE, the network speed becomes extremely slow and unreliable, averaging around 40 kbps. However, when I switch to using a power brick, the network operates as expected, reaching up to 1 Gbps. I also tested an older version (v24.8.4) and found that the network functions correctly with both the PoE hat and power brick. Could anyone provide insights into what might be causing these issues with the newer image?
