- Armbian doesnt seem to see sata harddrives.
@Tomogo: SATA works great with the kernel provided. I really hope that it will be accesible in normal way. Now switching kernel and installing ZFS is doable but painful. My concusion: If someone want's OMV, I recommend DELL SFF Intel 6100T based unit. It is cheaper (used), uses less power (5W with the same amount of discs) and works. I had been using it for some time. Thanks!
one of the ok boots after attempt to switch kernel to older one. Still 6.1.75 but randomly discs are visible v24.11.1 for Rock 5 ITX running Armbian Linux 6.1.75-vendor-rk35xx Packages: Debian stable (bookworm) IP addresses: (LAN) IPv4: 192.168.3.10 IPv6: xxxxxxxxxxxxxxxxx (WAN) 83.xxxxxxxxxxxxx Performance: Load: 1% Up time: 8 min Memory usage: 1% of 15.59G CPU temp: 33°C Usage of /: 5% of 27G Commands: Configuration : armbian-config Monitoring : htop Last login: Thu Dec 5 14:33:14 2024 from 192.168.3.79 root@rock-5-itx:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 2,7T 0 disk ├─sda1 8:1 0 2,7T 0 part └─sda9 8:9 0 8M 0 part sdb 8:16 0 931,5G 0 disk └─sdb1 8:17 0 931,5G 0 part sdc 8:32 0 5,5T 0 disk ├─sdc1 8:33 0 2,7T 0 part └─sdc2 8:34 0 2,8T 0 part sdd 8:48 0 2,7T 0 disk ├─sdd1 8:49 0 2,7T 0 part └─sdd9 8:57 0 8M 0 part mtdblock0 31:0 0 16M 0 disk mmcblk0 179:0 0 7,3G 0 disk └─mmcblk0p1 179:1 0 7,2G 0 part mmcblk0boot0 179:32 0 4M 1 disk mmcblk0boot1 179:64 0 4M 1 disk zram0 252:0 0 7,8G 0 disk [SWAP] zram1 252:1 0 50M 0 disk zram2 252:2 0 0B 0 disk nvme0n1 259:0 0 27,3G 0 disk └─nvme0n1p1 259:1 0 27G 0 part /
Thank you for your input and patience. Yes, latest version, fresh install from image then apt-get update, apt-get upgrade: v24.11.1 for Rock 5 ITX running Armbian Linux 6.1.75-vendor-rk35xx Packages: Debian stable (bookworm) IP addresses: (LAN) IPv4: 192.168.3.10 IPv6: xxxxxxxxxxxxxxxx (WAN) 83.xxxxxxxxxxxx Performance: Load: 5% Up time: 0 min Memory usage: 1% of 15.59G CPU temp: 34°C Usage of /: 5% of 27G lsblk: NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mtdblock0 31:0 0 16M 0 disk mmcblk0 179:0 0 7,3G 0 disk └─mmcblk0p1 179:1 0 7,2G 0 part mmcblk0boot0 179:32 0 4M 1 disk mmcblk0boot1 179:64 0 4M 1 disk zram0 252:0 0 7,8G 0 disk [SWAP] zram1 252:1 0 50M 0 disk zram2 252:2 0 0B 0 disk nvme0n1 259:0 0 27,3G 0 disk └─nvme0n1p1 259:1 0 27G 0 part / Sata discs are missing, but appeared once on second reboot Regarding archived versions: all of them have 6.1.75 kernels and all of them have the same issue. In fact they are 4 months old only so within the timeframe of the issue. Tried to install alternative kernel 6.1.43 from 24.5.1 using armbian-config: did nothing I still have 6.1.75. Tried installing the same way: 5.10.160: the board won't boot.
Few months have passed and the problem is still there. Today I tried : Armbian 24.11.1 Bookworm Minimal / IOT Kernel: 6.1.75, Size: 238.3 MB, Release date: Nov 28, 2024 the sata problem is still there. My current setup: Rock 5 ITX 16 GB 1x NVME intel Optane Memory 32 GB with armbian on it - NVMe always works 3x SATA HDD 1x SATA SSD same issue with our without it 200W- flex ATX PSU suspicious dmesg errors: [ 11.384685] ahci 0001:11:00.0: controller reset failed (0xffffffff) [ 12.951128] rk-pcie fe170000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=0 I'm not that advanced to play with beta kernels. The board is listed as supported by armbian but very basic functionality is missing/random. Is there a chance for a working image without tinkering from user side? Thank you in advance.
Maurycy
