Obmor
  1. There is still such a problem. When the device reboots, the USB Ethernet adapter does not initialize. You have to pull it out and put it in again. When the device is turned off, there is no such thing.
  2. @jock So sure. Works without overlay
  3. @jock By the way, you don't have to apply this patch. You just need to install the driver.
  4. @jock Hi! Do I understand correctly that when changing/updating the kernel version, the driver will not load and you will need to rebuild the module?
  5. @jock It worked! thank you very much! There are already 2 WLANs: WLAN0 and WLAN1 hmm.. ip_a-v9.3.txt lsmod-v9.3.txt dmesg-v9.3.txt
  6. @jock You're right. The chip is identified as RTL8189ES/ETV, I was misled by the description from the Android dtb
  7. @fabiobassa I don't have a separate ssv6051 overlay in armbian-config. He's not on the blacklist either.
  8. @jock Hi! This option did not work. lsmod-v9.txt dmesg-v9.1.txt
  9. I dug out the dtb file from the native Android 8 firmware. And this is what caught my eye: wireless-lan { compatible = "wlan-platdata"; rockchip,grf = <0x38>; wifi_chip_type = "ssv6051"; sdio_vref = <0xce4>; WIFI,host_wake_irq = <0x6d 0x1c 0x00>; status = "okay"; }; I checked, this module is not loaded in Armbian does it make sense in modprobe ssv6051? rk-kernel.dts
  10. @fabiobassa Now I use this one: https://www.ozon.ru/product/ustroystvo-upravleniya-diskretnymi-signalami-usb-gpio-extender-1757581290/ but there are few lines. I ordered this one more : https://aliexpress.ru/item/1005005823954618.html?sku_id=12000034481303368
  11. @RaptorSDS Unfortunately, neither option works.
  12. @RaptorSDS I've only tried default single LED. Because there is only one LED on the stick. I'll try to go through all the options. Thanks for the tip!
  13. Here is such a device. Compact, 2 USB OTG + Wi-Fi. I use it for home automation, in conjunction with a USB GPIO adapter. I connect to the network via USB Ethernet, but I really want a WLAN. I checked its operation with LibreELEC 12. WiFi is working. I copied the rk322x-box.dtb file to Armbian. It didn't help. Can you help me find the UART interface on the board? I can't see it, and the radiator is glued shut.
  14. @fabiobassa @jock Thanks for the answer! Your help to the community is invaluable, I understand that. I am an aspiring enthusiast and would like to study arm architecture more thoroughly. I'm pretty good at Linux, but at the application programming level. I would just like to get some advice on how to proceed in my case. Should I pay attention to the dtb file that I pulled out of the old Android 8 firmware of my device. And replace the dtb file in Armbian with it. Thank you in advance! I just want some advice. Perhaps I will help someone else with my research.
  15. Hi guys. I have a problem with the rk3229 and rtl8189ETV hardware bundle. I am installing Armbian_community_25.2.0-trunk.160_Rk322x-box_noble_current_6.6.65_xfce_desktop.img.xz 1. Wi-Fi problem. rc322x-config detects rtl8189ETV but it does not start. I can't set up a Wi-Fi connection because this equipment is not in the list 2. The end0? network interface is constantly in the list of equipment, although I do not physically have this equipment and I use a USB HUB with an Ethernet port to connect to the network, which is defined in the system as enxdXXX I will be very grateful for your help dmesg.txt armbianEnv.txt
