Lele
  1. Maybe it's this? > uname -r 6.1.75-vendor-rk35xx I'm using this img: Armbian_24.11.2_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop.img After installed, I used armbian-config to disable the firmware update (because otherwise apt upgrade also break hardware acceleration in chrome). Then I ran: sudo apt update sudo apt upgrade Then, following jellyfin's guide (Rockchip VPU | Jellyfin), in /etc/udev/rules.d/99-rk-device-permissions.rules, I also changed this: KERNEL=="system", MODE="0660", GROUP="video" to this: KERNEL=="system", MODE="0666", GROUP="video" I also paste the whole clinfo message here: pastebin (clinfo)
  2. I want to install jellyfin on my OrangePi 5 Plus and need OpenCL to enable HDR-SDR mapping. I tried to follow the instruction on Jellyfin's official website: Rockchip VPU | Jellyfin However, I'm stucked on the step of installing OpenCL. I also tried this: Install OpenCL on Debian and Ubuntu and Armbian for Orange Pi 5 RK3588 But no luck either. Both instruction led to broken hardware acceleration in chrome and failing to start kernal in Jellyfin. Logs from ffmpeg: sudo /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device rkmpp=rk -init_hw_device opencl=ocl@rk Applying option init_hw_device (initialise hardware device) with argument opencl=ocl@rk. arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaab055f5460] 1 OpenCL platforms found. [AVHWDeviceContext @ 0xaaab055f5460] 1 OpenCL devices found on platform "ARM Platform". arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaab055f5460] 0.0: ARM Platform / Unknown Device Segmentation fault Logs from Jellyfin: Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Failed creating base context during opening of kernel driver. Kernel module may not have been loaded Logs from clinfo: arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded I want to know how to correctly enable OpenCL on OrangePi 5 Plus, thank you!
  3. Sorry, I don't understand there commands. After I ran sudo armbian-install and chosed option 7, it run for a while and then print "Done". I can't find how to get to the option 4 thereafter. I'm using Armbian_24.11.2_Orangepi5-plus_noble_vendor_6.1.75_gnome-kisak_desktop Can you help me? Thank you!
