Torte
  1. These error messages don't look good. Have you tried setting up and working with that wifi device alone (i.e. without all that bridging stuff)? This seems to me like a problem with either firmware loading for this adapter, or an unusable configuration, like unusable tx/rx power or channel for the specified region (e.g. if there has been no region code set for that interface).
  2. That might be due to little RAM. I did a test install about a year ago on a raspi 3b+ with 1GB RAM, and it became extremely slow after a short while. htop showed, that the system was completely busy with swapfile access. Even a shutdown took some hours. Homeassistant might claim, that 1GB can suffice, but IMO that's more a proof-of-concept than a workable solution. As soon as you add some integrations, the free memory becomes quickly too low.
  3. Board: MKS-Klipad50 Images: * Armbian_26.5.1_Mksklipad50_resolute_current_6.18.33_minimal.img.xz * Armbian_26.5.1_Mksklipad50_trixie_current_6.18.33_minimal.img.xz Passed tests: * gpg and sha checksum files * boot from emmc, leds, display, touch, usb, internal wifi * initial setup, uboot-console, reboot Result: All expected images do exist, verify and work properly. Sidenote: The Klipper ecosystem does not yet run on Ubuntu-Resolute (Python-3.14 incompatibility), but that shouldn't be a stopper for the release.
  4. @guy cal Igor just fixed that: https://github.com/armbian/configng/pull/765
  5. Did you try loading the "pinctrl-rk805" module? This was once directly compiled into the kernel and later externalized into a module. And IIRC that happened when switching to 6.12. If loading that module helps, then adding it to the MODULES line of the board's config like this should fix it.
  6. Board: MKS-Klipad50 Images: * Armbian_26.2.1_Mksklipad50_noble_current_6.18.8_minimal.img.xz * Armbian_26.2.1_Mksklipad50_trixie_current_6.18.8_minimal.img.xz Passed tests: * gpg and sha checksum files * boot from emmc, leds, display, touch, usb, internal wifi * initial setup, uboot-console, full klipper/klipperscreen install, reboot Result: All expected images do exist, verify and work properly.
  7. Please read my reply at https://github.com/torte71/InsideSovolKlipperScreen/issues/8#issuecomment-3796412735 In short: I think the screen on this device is a proprietary smart-device that can't be used as a standard display. Thus KlipperScreen (and any other X or Wayland app) will not be able to run.
  8. According to your serial log, the name of the dtb file is "rk-kernel.dtb". You should find that file somewhere below /boot/dtb/ . You can simply copy that from your running system (e.g. using "scp"). But if you want to extract it from an image, you can use e.g. "kpartx -av YOURIMAGE.img" to create loop devices ("/dev/mapper/loop*") for each contained partition, which you can then mount as usual. Too sad that ctrl+c does not seem to work. Did you try having "ctrl+c" already pressed before powering up the board - and keeping it pressed, while it boots? There's also a chance that the board will accidentally boot from the usb-drive, if it contains the same image as the emmc (i.e. the partition UUIDs need to be identical). It happened to me in about 1 out of 3-5 attempts. Described here.
  9. According to https://github.com/redrathnure/armbian-mkspi?tab=readme-ov-file#technical-details the mks-skipr is just an mks-pi with an additional mks-robin-nano attached via uart. That should be the reason, why there aren't separate mks-skipr images, only images for mks-pi. Btw, the images for mks-pi and mks-klipad50 both use the same kernel. After replacing the corresponding .dtb file with the one from your original image, these images should behave identical. Your approach of dd'ing the image from a usb-drive directly to the system that is currently running, sounds as dangerous as replacing a car engine while it's running. You said, that you've successfully used rkdeveloptool for a recovery. If that means, that you have flashed a *full* image to the emmc this way, then I would use this approach to directly flash the desired armbian image to that emmc (without using any other usb drive). Or try to intercept u-boot from the original image to boot from an usb-drive (as I wrote here). Then you could 'dd' an image stored on that usb-drive to the emmc - but neither the source or the destination filesystem should be mounted/in use during that process.
  10. FYI: The following refers to a supervised installation done with armbian-config (starting from "community_25.5.0-trunk.370"). Not sure if the ready homeassistant Armbian images behave differently. Before apt-upgrading the system running homeassistant (supervised), I recommend a) doing a full image backup and b) locking homeassistant-supervised ("apt mark hold homeassistant-supervised"): Updating homeassistant-supervised with apt-upgrade first showed a selection box of the used hardware (none of them matched my rockchip64/rock 4c+ AFAIK - in despair I chose qemu-aarch64), afterwards homeassistant went into first initialization setup (the "wait ~20 minutes to set up" message). Not sure, if it would have somehow fixed itself - I reverted to the (full-image) backup once I saw that message. Having locked the supervised package beforehand, "apt upgrade" was able to update the system without breaking homeassistant (at least it looks like that so far).
  11. u-boot has to be compiled specifically for the board that it runs on. That means the Armbian project for the board has to be changed and it may require some additional source code changes - these additional requirements show up, when trying to boot with that new bootloader and something does not work. I have managed to switch to a recent u-boot on a RK3328 board that I own (required changes can be seen in these commits) and I could try adopting that for the RockPi4b. But as that change would affect all RockPi4b boards and I don't have a direct way to test it before publishing (it took me dozens of image builds and boot attempts), I am reluctant to give it a go without more indications that the bootloop is really caused by that specific bootloader problem: It may have a completely different cause and the u-boot switch may also introduce new problems. So I'd rather wait until that loop can be reproduced and the log proves u-boot being the cause before opening that can of worms.
  12. Thanks for publishing these logs. Now we have to wait for the bootloop to happen, when the serial-adapter is still in reach . If the loop happens directly at the "illegal free" messages, then switching to a more recent bootloader (u-boot 2025) could fix this.
  13. Great! See https://wiki.radxa.com/Rockpi4/dev/serial-console for a guide on how to connect the serial lines to the board and setting up a terminal program. The wire colours are different, but take a look at the picture on that link: Do not connect the +5V or 3V3 pins GND cable needs to be connected to the 3rd GPIO-pin (GND) on the top/outer side of the connector (the black wire in the picture) RX cable needs to be connected to TX, that's the 4th GPIO-pin, just below the GND wire (it's white in the picture) TX cable needs to be connected to RX, that's the 5th GPIO-pin, just below the RX wire (it's green in the picture) (If you can't connect, then RX and TX needs to be swapped. Don't worry, having these lines swapped won't break anything, it just doesn't allow a connection when wrong.) Then start the terminal program (e.g. putty on Windows or minicom on Linux, both described in that link). When booting the RockPi, you should see the boot messages in the terminal window (otherwise try swapping RX/TX). Keeping the spacebar pressed (in the terminal program, make sure it is selected) should then interrupt the bootloop and you should be able to copy&paste the output. If interrupting still does not work: Putty has the opption to copy the whole content to clipboard: Right-click the title bar and select "Copy All to Clipboard". Then paste it into an editor. Once you have pasted that log into an editor, you can try to clean it up a little bit, it may contain several boot attempts. It would be sufficient to include just one complete boot attempt and the start of the next. But if in doubt, use the complete log. Finally post that log here.
  14. Torte replied to DiegoBM's topic in Rockchip
    There is no hidden magic in the .xz files. You assumed correctly, that this is "just some form of zip". Some image-writing software like rufus or etcher allow on-the-fly decompression of these files, but extracting them with "xz -d" and then writing the uncompressed .img file e.g. with dd should work. If the resulting image didn't work, then it must have a different cause (e.g. interrupted decompression, decompressed the wrong file, issues with the image file contents itself, etc.).
  15. You can take a look at the postinstall script from the u-boot package. It should be called sth like "/var/lib/dpkg/info/linux-u-boot-current-rockpi-s.postinst" and should be quite small, so easier to understand. You can extract the required commands from there. Assuming it is similar to my u-boot installer, this could result in a script like this: #!/bin/bash source /usr/lib/u-boot/platform_install.sh write_uboot_platform "$DIR" /dev/mmcblk0 sync That way you don't have to handle the hardcoded sector offsets yourself (not sure, if these offsets would ever change - but if they do, then that will probably be reflected in the platform_install script).
