UltimateSolar
  1. hi thanks for this excellent device wished it was not sold out and had hdmi though X-D https://dwaves.de/2024/12/24/test-review-benchmark-armbian-gnu-linux-on-rockpi-e-rk3588-armv8-no-gpu-but-desktop-via-x11vnc-and-xvfb-how-to-download-run-geekbench-v5-v6-arm-x86-out-of-ram-fixed-risc-v-faster/ https://shop.allnetchina.cn/products/copy-of-rock-pi-e?variant=31974543425638 but it's possible to run full desktop virtualized installed https://www.armbian.com/rockpie/ running fine and dandy until one fine day, thought about, let's upgrade this thing: after: apt update apt upgrade reboot only 1x nic still working :( lshw -class network *-network:0 DISABLED <- this one failed description: Ethernet interface physical id: 9 logical name: end0 serial: 5e:...95 capacity: 1Gbit/s capabilities: ethernet physical tp aui bnc mii fibre 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation configuration: autonegotiation=off broadcast=yes driver=st_gmac driverversion=6.14.0-rc4-edge-rockchip64 duplex=half link=no multicast=yes port=MII *-network:1 <- this one works description: Ethernet interface physical id: a logical name: end1 serial: 5e... b5 size: 100Mbit/s capacity: 100Mbit/s capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=st_gmac driverversion=6.14.0-rc4-edge-rockchip64 duplex=full ip=169.254.2.98 link=yes multicast=yes port=twisted pair speed=100Mbit/s # running this kernel Operating System: Armbian 25.2.2 noble Kernel: Linux 6.12.17-current-rockchip64 cat /proc/device-tree/model Radxa ROCK Pi E dmesg | grep rk_gmac [ 4.059672] rk_gmac-dwmac ff540000.ethernet: IRQ eth_wake_irq not found [ 4.059723] rk_gmac-dwmac ff540000.ethernet: IRQ eth_lpi not found [ 4.059739] rk_gmac-dwmac ff540000.ethernet: IRQ sfty not found [ 4.059925] rk_gmac-dwmac ff540000.ethernet: PTP uses main clock [ 4.060263] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input). [ 4.060297] rk_gmac-dwmac ff540000.ethernet: TX delay(0x26). [ 4.060315] rk_gmac-dwmac ff540000.ethernet: RX delay(0x11). [ 4.060341] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no). [ 4.060419] rk_gmac-dwmac ff540000.ethernet: clock input from PHY [ 4.065461] rk_gmac-dwmac ff540000.ethernet: init for RGMII [ 4.067905] rk_gmac-dwmac ff540000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 4.067948] rk_gmac-dwmac ff540000.ethernet: DWMAC1000 [ 4.067964] rk_gmac-dwmac ff540000.ethernet: DMA HW capability register supported [ 4.067978] rk_gmac-dwmac ff540000.ethernet: RX Checksum Offload Engine supported [ 4.067990] rk_gmac-dwmac ff540000.ethernet: COE Type 2 [ 4.068004] rk_gmac-dwmac ff540000.ethernet: TX Checksum insertion supported [ 4.068016] rk_gmac-dwmac ff540000.ethernet: Wake-Up On Lan supported [ 4.068203] rk_gmac-dwmac ff540000.ethernet: Normal descriptors [ 4.068227] rk_gmac-dwmac ff540000.ethernet: Ring mode enabled [ 4.068240] rk_gmac-dwmac ff540000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.079393] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found [ 4.079427] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found [ 4.079443] rk_gmac-dwmac ff550000.ethernet: IRQ sfty not found [ 4.079597] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock [ 4.079668] rk_gmac-dwmac ff550000.ethernet: supply phy not found, using dummy regulator [ 4.079934] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output). [ 4.079965] rk_gmac-dwmac ff550000.ethernet: Can not read property: tx_delay. [ 4.079978] rk_gmac-dwmac ff550000.ethernet: set tx_delay to 0x30 [ 4.079994] rk_gmac-dwmac ff550000.ethernet: Can not read property: rx_delay. [ 4.080006] rk_gmac-dwmac ff550000.ethernet: set rx_delay to 0x10 [ 4.080040] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes). [ 4.085988] rk_gmac-dwmac ff550000.ethernet: init for RMII [ 4.127956] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 4.127997] rk_gmac-dwmac ff550000.ethernet: DWMAC1000 [ 4.128014] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported [ 4.128027] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported [ 4.128039] rk_gmac-dwmac ff550000.ethernet: COE Type 2 [ 4.128053] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported [ 4.128065] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported [ 4.128218] rk_gmac-dwmac ff550000.ethernet: Normal descriptors [ 4.128241] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled [ 4.128254] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.214207] rk_gmac-dwmac ff540000.ethernet end0: renamed from eth0 [ 4.219592] rk_gmac-dwmac ff550000.ethernet end1: renamed from eth1 [ 17.950956] rk_gmac-dwmac ff540000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 17.951976] rk_gmac-dwmac ff540000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19) [ 17.956903] rk_gmac-dwmac ff550000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 18.014746] rk_gmac-dwmac ff550000.ethernet end1: PHY [stmmac-1:00] driver [Rockchip integrated EPHY] (irq=POLL) [ 18.024841] rk_gmac-dwmac ff550000.ethernet end1: No Safety Features support found [ 18.024873] rk_gmac-dwmac ff550000.ethernet end1: PTP not supported by HW [ 18.025357] rk_gmac-dwmac ff550000.ethernet end1: configuring for phy/rmii link mode [ 20.065194] rk_gmac-dwmac ff550000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx [ 179.477935] rk_gmac-dwmac ff540000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 179.480074] rk_gmac-dwmac ff540000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19) [ 529.140404] rk_gmac-dwmac ff540000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 529.142478] rk_gmac-dwmac ff540000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19) ip link set end0 up; # does not work :( RTNETLINK answers: No such device ifconfig end0 192.168.123.123 up; SIOCSIFFLAGS: No such device SIOCSIFFLAGS: No such device rfkill unblock end0; # does not work :( rfkill: invalid identifier: end0 # tried upgrading the kernel to latest apt install linux-image-edge-rockchip64 reboot hostnamectl; Operating System: Armbian 25.2.2 noble Kernel: Linux 6.14.0-rc4-edge-rockchip64 <- new kernel up and running Architecture: arm64 # still same problem :( # found the device here /sys/firmware/devicetree/base/ethernet@ff540000 lsmod|grep rk_gmac-dwmac lsmod|grep dwmac dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 241664 3 stmmac_platform,dwmac_rk modinfo stmmac filename: /lib/modules/6.14.0-rc4-edge-rockchip64/kernel/drivers/net/ethernet/stmicro/stmmac/stmmac.ko license: GPL author: Giuseppe Cavallaro <peppe.cavallaro@st.com> description: STMMAC 10/100/1000 Ethernet device driver depends: pcs_xpcs intree: Y name: stmmac vermagic: 6.14.0-rc4-edge-rockchip64 SMP preempt mod_unload aarch64 parm: watchdog:Transmit timeout in milliseconds (default 5s) (int) parm: debug:Message Level (-1: default, 0: no output, 16: all) (int) parm: phyaddr:Physical device address (int) parm: flow_ctrl:Flow control ability [on/off] (int) parm: pause:Flow Control Pause Time (int) parm: tc:DMA threshold control value (int) parm: buf_sz:DMA buffer size (int) parm: eee_timer:LPI tx expiration time in msec (uint) parm: chain_mode:To use chain instead of ring mode (int) cat /etc/apt/sources.list deb http://ports.ubuntu.com/ noble main restricted universe multiverse #deb-src http://ports.ubuntu.com/ noble main restricted universe multiverse deb http://ports.ubuntu.com/ noble-security main restricted universe multiverse #deb-src http://ports.ubuntu.com/ noble-security main restricted universe multiverse deb http://ports.ubuntu.com/ noble-updates main restricted universe multiverse #deb-src http://ports.ubuntu.com/ noble-updates main restricted universe multiverse deb http://ports.ubuntu.com/ noble-backports main restricted universe multiverse #deb-src http://ports.ubuntu.com/ noble-backports main restricted universe multiverse what now? how to fix this? HEEEELP
