Armbian 25.11.2 for ROCK5 ITX released
Many thanks for your replies. @Werner I can only say that I got the image via Armbian Imager, well designed for lazy people like me. This: On the Armbian Rock5 ITX web page, There are two candidates: 1 ) This one, because it's the only image in the list with variant "Gnome": or 2) this one, because it has the same size (1.4 GB), but doesn't say anything about the variant. The two images above have two different sha hashes. If it's true that isn't good for desktop (I agree with you because it doesn't work properly), I don't understand why it's tagged as "Recommended" on Armbian Imager. Anyway, I deleted everything and started from scratch, using another image tagged as "Recommended" based on Debian 13 and CLI only. This one is less complicated and till now works. @eselarm I tried two different monitors: the first one is quite modern as it supports not only many resolutions, but also different frequencies and other stuff. The second one is very basic: it can support up to 1980p at 60hz. In both cases, I got the same behavior. I also tried in the past EDK2-UEFI, but it didn't work very well on my Rock 5 ITX due to unexpected behaviors that I could not control in an effective way. That being said, unfortunately I don't have the exact filename and sha256sum of the previous image because I changed the image.
Yesterday I was happy to see the new and fresh Armbian release for the Rock 5 ITX after about 1 year from the last update. I also tried the Armbian Imager and the SD creation was very easy and smooth. I selected the recommended release based on Ubuntu 24.04 + Gnome desktop. Unfortunately when the desktop was about to start, everything when black, stucked and zero interface. On the other hand, the OS is alive and I can connect remotely via SSH. Did anyone have the same problem? Possible solution? [EDIT]. sudo systemctl restart gdm and desktop pops up. Restarting the system, black again.
Armbian doesnt seem to see sata harddrives.
Honestly I was quite tired of playing with kernels where things are not working as expected. It's not a criticism towards the armbian developers community, but despite the ongoing effort, a stable maturity of the kernel\sotware is not reached yet. For my personal use cases, I need: - server mode and no vendor Radxa Os. - SATA working - audio working Despite some overoptimistic initail tests with the 6.1.99 vendor kernel, at the end of the day SATA is not stable enough. Sometimes I've to turn off/on the device up to 3 / 4 times before having the SATA drives detected. Taken by an overwhelming frustration, I took the risk and removed the R29 resistor as described here. Now SATA is working as expected everytime at least with vendor kernel 6.1.99: I need this version also because it has the audio drivers working correctly. I hope that a definitive software solution can be found in the near future without the need of hardware hacks.
Rock 5 ITX as Multi-purpose App server
Thank you Werner. I'm not into Armbian enough to understand how the hardware is supported across all the kernel versions. The best I can do is to test different versions until I find the mininum support for the things I want to do. Till now, kernel 6.1.99-vendor-rk35xx works more or less, but SATA HDDs are not always detected at boot. OS is installed on a NMVE pcie drive, while the main storage is given by 2 4TB drives in RAID1. HDMI output doesn't work for me when kernel 6.12 is used (I have rock 5 ITX - Board version 1.12). Kernel 15-rc solves the SATA support, but audio doesn't work. I went throught many webpages to check if I can solve some issues here and there, but my limited knowledge doesn't allow me to really understand what's going on and the interactions between elements of the system. I have to rely on the hard work of the developers community, waiting for better support in the future, if any.
- Rock 5 ITX as Multi-purpose App server
Hello, I'm quite new to SBC and linux. On one hand I'm learning a lot, but on the other hand I'm struggling to make it work as I would like. I already have a low performance Zimaboard (just 2GB Ram) that I use as a NAS and I want the ROCK 5 ITX 8GB to be used as a general purpose apps server for home automation, streaming music, listening music, etc. One of my use case I'm playing with is the following: 1) music files are on the NAS 2) Music files are played from the Rock5 ITx via the speakers plugged into the headphone jack, 3) The music player is controlled remotely using Lyrion Music Server + Squeezelite. I've already tested the above using the official rock-5-itx_bookworm_kde_b3.output.img.xz image and it works: no rocket science . Unfortunately the vendor official image is not very stable: the docker containers crash randomly and even if the SATA drives are detected and mounted at boot time, the got disconnected randomly after some hours. That's why I decided to go experimental and now I'm playing with the following setup and 6 containers running: OS: Armbian-unofficial 25.05.0-trunk bookworm aarch64 ?******************; Host: Radxa ROCK 5 ITX '*n` .'`^,;;,^`'. ,cc. Kernel: Linux 6.15.0-rc1-edge-rockchip64 !^ ^^ ": Shell: bash 5.2.15 Itttt?' ~~]rr] `{tttt, Terminal: /dev/pts/0 \tttttt!""I_]r("""~tttttt1 CPU: rk3588 (8) @ 2.40 GHz '_tttttttttttt)ftttttttttttti. GPU: Rockchip rk3588-mali [Integrated] \*ztttttttttttttttttttttttttf**[ Memory: 1.80 GiB / 7.75 GiB (23%) l**c)tttttttttttttttttttttttt(z**, Swap: 0 B / 3.87 GiB (0%) .z*x.`tttttttttttttttttttttttt.`u*n Disk (/): 11.90 GiB / 232.35 GiB (5%) - ext4 >` (tttttttttttttttttttttt] "I Disk (/media/bidone): 44.76 GiB / 3.58 TiB (1%) - ext4 ,tttttttttttttttttttttt` Disk (/var/log): 5.31 MiB / 46.84 MiB (11%) - ext4 ./tttttfttttttttfttttt( Local IP (wlP2p33s0): 192.168.X.X 'I)))(\()(tt))|\()({;' Locale: it_IT.UTF-8 Coming back to the play-music-locally use-case, I've a problem with the sound card because I cannot hear the audio. Here the output from Armbianmonitor: https://paste.armbian.com/apaxoburiz I've both ALSA and PulseAudio. Alsamixer works: Hereunder other outputs, but I'm not expert enough to understand what's going on and why audio is not played by the speakers plugged to the board. No sound with "speaker-test" and "/etc/modprobe.d/sound.conf" doesn't exsist. HDMI audio is not detected, but I can live without for the moment. cat /proc/asound/cards 0 [rk3588es8316 ]: rk3588-es8316 - rk3588-es8316 rk3588-es8316 sudo dmesg | grep 'snd\|audio\|firmware' [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.150543] /i2c@fec90000/audio-codec@11: Fixed dependency cycle(s) with /i2s@fe470000 [ 1.495212] /i2s@fe470000: Fixed dependency cycle(s) with /i2c@fec90000/audio-codec@11 [ 1.495240] /i2c@fec90000/audio-codec@11: Fixed dependency cycle(s) with /i2s@fe470000 [ 15.623287] rtw89_8852be 0002:21:00.0: loaded firmware rtw89/rtw8852b_fw-1.bin inxi -A Audio: Device-1: audio-graph-card driver: asoc_audio_graph_card Device-2: rk3588-dw-hdmi-qp driver: dwhdmiqp_rockchip API: ALSA v: k6.15.0-rc1-edge-rockchip64 status: kernel-api Server-1: PulseAudio v: 16.1 status: active aplay -l **** List of PLAYBACK Hardware Devices **** card 0: rk3588es8316 [rk3588-es8316], device 0: fe470000.i2s-ES8316 HiFi ES8316 HiFi-0 [fe470000.i2s-ES8316 HiFi ES8316 HiFi-0] Subdevices: 0/1 Subdevice #0: subdevice #0 alsactl init alsa-lib parser.c:2783:(load_toplevel_config) Unable to find the top-level configuration file '/usr/share/alsa/ucm2/ucm.conf'. alsa-lib main.c:1541:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2 Found hardware: "rk3588-es8316" "" "" "" "" Hardware is initialized using a generic method Thank you: advices are appreciated.
- Armbian doesnt seem to see sata harddrives.
Unfortunately 6.12 doesn't work for me: whatever flavour I use (official, unofficial current, edge), it boots but stay black, no HDMI output to the monitor. 6.1.99 works, but SATA HDDs are not detected. I had to use a workaround: start with 6.1.99, do the first setup, configure SSH, change the kernel with armbian-config and reboot. The monitor goes black but I can control the system remotely and SATA HDDs are detected. Still investiganting why the HDMI ouput doesn't work with 6.12 (maybe power supply: I've an external 75W power supply plugged directy to the motherboard).
I'm a beginner and I'm new to armbian and linux in general. I have a NVME + SATA HDD plugged on my Rock 5 ITX with the problem of the HDD not detected. I tried different sever images listed here  , but the HDD was not detected. The debian 12/kernel 6.1 based image from Radxa works, the HDD is detected, but it doesn't match my needs of a minimal server image. As a tentative, I built the following custom image based on Ubuntu Jammy and the SATA HDD is detected at every boot (sda 1TB). v25.5 rolling for Rock 5 ITX running Armbian Linux 6.12.19-current-rockchip64 Packages: Ubuntu stable (jammy), possible distro upgrade (noble) Last login: Sun Mar 16 18:46:48 2025 NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 931,5G 0 disk └─sda1 8:1 0 931,5G 0 part mtdblock0 31:0 0 16M 0 disk zram0 253:0 0 3,9G 0 disk [SWAP] zram1 253:1 0 50M 0 disk /var/log zram2 253:2 0 0B 0 disk nvme0n1 259:0 0 238,5G 0 disk └─nvme0n1p1 259:1 0 236,1G 0 part /var/log.hdd / I cannot say if this image has other issues, but till now it's doing its job.
Bobbox
