Kelvie Wong
  1. The patch doesn't build against rockchip64 6.12 -- and looking at the patch it doesn't affect the RK35XX series at all. To port it, I think I need the max_prate constants for the RK3566 (is this in clk_rk3568.c? or some other file, there isn't a clk_rk3566.c) I think the datasheet (https://www.boardcon.com/download/Rockchip_RK3566_Datasheet_V1.1.pdf) says it's 600MHz for HDMI
  2. After testing it with verbosity=7 on both vendor and current, there's nothing suspicious in the kernel logs -- on vendor, I get: root@radxa-zero3:~# journalctl -k -b 0 | grep -iE 'hdmi|drm|gpu|edid|cec' Apr 08 11:26:19 radxa-zero3 kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB Apr 08 11:26:19 radxa-zero3 kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB Apr 08 11:26:19 radxa-zero3 kernel: platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000 Apr 08 11:26:19 radxa-zero3 kernel: platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000 Apr 08 11:26:19 radxa-zero3 kernel: [drm] all windows should be assigned, full plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], current plane mask: [0x0 Apr 08 11:26:19 radxa-zero3 kernel: [drm] use default plane mask Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], primary plane phy id: Smart0[4] Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: [0x0], primary plane phy id: INVALID[-1] Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: [0x0], primary plane phy id: INVALID[-1] Apr 08 11:26:19 radxa-zero3 kernel: [drm] failed to init overlay plane Cluster0-win1 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff80000939a0c0) Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000093b2958) Apr 08 11:26:19 radxa-zero3 kernel: [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: failed to parse loader memory Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1280x720p60, type: 11(if:HDMI0, flag:0x0) for vp0 dclk: 74250000 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 74250000, get 74250000 Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] run display error_event monitor Apr 08 11:26:19 radxa-zero3 kernel: Registered IR keymap rc-cec Apr 08 11:26:19 radxa-zero3 kernel: rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0 Apr 08 11:26:19 radxa-zero3 kernel: input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0 Apr 08 11:26:19 radxa-zero3 kernel: input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input1 Apr 08 11:26:19 radxa-zero3 kernel: vdd_gpu: supplied by vcc_sys Apr 08 11:26:19 radxa-zero3 kernel: vdd_gpu: 500 <--> 1350 mV at 900 mV, enabled Apr 08 11:26:19 radxa-zero3 kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Kernel DDK version g25p0-00eac0 Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: error -ENXIO: IRQ JOB not found Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: error -ENXIO: IRQ MMU not found Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: error -ENXIO: IRQ GPU not found Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Insufficient register space, will override to the required size Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Register window unavailable Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Failed to map registers Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Register map failed error = -5 Apr 08 11:26:19 radxa-zero3 kernel: mali fde60000.gpu: Device initialization failed Apr 08 11:26:19 radxa-zero3 kernel: mali: probe of fde60000.gpu failed with error -5 Apr 08 11:26:19 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:26:19 radxa-zero3 kernel: #0: rockchip-hdmi0 Apr 08 11:26:19 radxa-zero3 systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... Apr 08 11:26:19 radxa-zero3 systemd[1]: modprobe@drm.service: Deactivated successfully. Apr 08 11:26:19 radxa-zero3 systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: clock rate = 594000000 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: bus_clock rate = 500000000 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: Looking up mali-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7 Apr 08 11:26:19 radxa-zero3 kernel: panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1 Apr 08 11:26:19 radxa-zero3 kernel: [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 1 Apr 08 11:29:48 radxa-zero3 kernel: EDID block 0 is all zeroes Apr 08 11:29:48 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid And on the failing one, just the same old: Apr 09 22:04:32 radxa-zero3 kernel: /vop@fe040000: Fixed dependency cycle(s) with /hdmi@fe0a0000 Apr 09 22:04:32 radxa-zero3 kernel: /hdmi@fe0a0000: Fixed dependency cycle(s) with /vop@fe040000 Apr 09 22:04:32 radxa-zero3 kernel: /hdmi@fe0a0000: Fixed dependency cycle(s) with /hdmi-con Apr 09 22:04:32 radxa-zero3 kernel: /hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000 Apr 09 22:04:32 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) Apr 09 22:04:32 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Apr 09 22:04:32 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Apr 09 22:04:32 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) Apr 09 22:04:32 radxa-zero3 kernel: [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 Apr 09 22:04:32 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes Apr 09 22:04:32 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes So I suspect there's some EDID problem. (I'll try forcing EDID next, but I have a few more boards ordered to see if it's a hardware problem or not (or is this a sneaky way of making me buy more CAD$60 boards...)
  3. Here are the logs on the vendor side (grepping for drm and edid): root@radxa-zero3:~# journalctl -k -b 0 | grep -e hdmi -e drm Apr 08 11:26:19 radxa-zero3 kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB Apr 08 11:26:19 radxa-zero3 kernel: OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB Apr 08 11:26:19 radxa-zero3 kernel: platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000 Apr 08 11:26:19 radxa-zero3 kernel: platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000 Apr 08 11:26:19 radxa-zero3 kernel: [drm] all windows should be assigned, full plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], current plane mask: [0x0 Apr 08 11:26:19 radxa-zero3 kernel: [drm] use default plane mask Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], primary plane phy id: Smart0[4] Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: [0x0], primary plane phy id: INVALID[-1] Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: [0x0], primary plane phy id: INVALID[-1] Apr 08 11:26:19 radxa-zero3 kernel: [drm] failed to init overlay plane Cluster0-win1 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff80000939a0c0) Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000093b2958) Apr 08 11:26:19 radxa-zero3 kernel: [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: failed to parse loader memory Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid Apr 08 11:26:19 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1280x720p60, type: 11(if:HDMI0, flag:0x0) for vp0 dclk: 74250000 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 74250000, get 74250000 Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device Apr 08 11:26:19 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] run display error_event monitor Apr 08 11:26:19 radxa-zero3 kernel: rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0 Apr 08 11:26:19 radxa-zero3 kernel: input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0 Apr 08 11:26:19 radxa-zero3 kernel: input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input1 Apr 08 11:26:19 radxa-zero3 kernel: #0: rockchip-hdmi0 Apr 08 11:26:19 radxa-zero3 systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... Apr 08 11:26:19 radxa-zero3 systemd[1]: modprobe@drm.service: Deactivated successfully. Apr 08 11:26:19 radxa-zero3 systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. Apr 08 11:26:19 radxa-zero3 kernel: [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 1 Apr 08 11:28:40 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: failed to get edid root@radxa-zero3:~# This happens on multiple monitors and cables.
  4. I disassembled my other radxa and swapped the SD cards, and it is just something funny with this hardware. I also just realized I bought a different configuration -- the one that works with `current` is a 2GB RAM version, and the one that has no HDMI (except on `vendor`) is a 4GB RAM version. I wonder if there are hardware differences.
  5. Hm, I found the debs locally and installed them (along with the DTBs), still don't have HDMI. At this point I'd suspect the hardware but the vendor image works.
  6. Digging through my build logs, it seems the last kernel that worked is "linux-image-current-rockchip64_25.05.0-trunk_arm64__6.12.20-Sf491-Da873-Pe64b-C1f18H02eb-HK01ba-Vc222-B9bbb-R448a.deb" -- anyone know how I can rebuild this?
  7. So I have two boards, and two images, both built with armbian-build. I built `current` on March 24th 2025 and HDMI and everything works great I built one this week and there is no HDMI output. Logs of the non-working one: Apr 07 18:36:09 radxa-zero3 kernel: mmc2: new UHS-I speed SDR104 SDIO card at address 390b Apr 07 18:36:09 radxa-zero3 kernel: rk808-rtc rk808-rtc.4.auto: registered as rtc0 Apr 07 18:36:09 radxa-zero3 kernel: rk808-rtc rk808-rtc.4.auto: setting system clock to 2017-08-05T09:00:10 UTC (1501923610) Apr 07 18:36:09 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: Adding to iommu group 0 Apr 07 18:36:09 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) Apr 07 18:36:09 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Apr 07 18:36:09 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Apr 07 18:36:09 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) Apr 07 18:36:09 radxa-zero3 kernel: [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 Apr 07 18:36:09 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes Apr 07 18:36:09 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes Logs of the working one: Mar 24 21:17:04 radxa-zero3 kernel: mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) Mar 24 21:17:04 radxa-zero3 kernel: dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 150 Mar 24 21:17:04 radxa-zero3 kernel: mmc2: new ultra high speed SDR104 SDIO card at address 390b Mar 24 21:17:04 radxa-zero3 kernel: rockchip-vop2 fe040000.vop: Adding to iommu group 0 Mar 24 21:17:04 radxa-zero3 kernel: rk808-rtc rk808-rtc.4.auto: registered as rtc0 Mar 24 21:17:04 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) Mar 24 21:17:04 radxa-zero3 kernel: rk808-rtc rk808-rtc.4.auto: setting system clock to 2017-08-05T09:00:10 UTC (1501923610) Mar 24 21:17:04 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) Mar 24 21:17:04 radxa-zero3 kernel: dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver Mar 24 21:17:04 radxa-zero3 kernel: rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) Mar 24 21:17:04 radxa-zero3 kernel: [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 Mar 24 21:17:04 radxa-zero3 kernel: Console: switching to colour frame buffer device 240x67 Mar 24 21:17:04 radxa-zero3 kernel: rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device On the non-working one, I've tried both the same kernel version (6.12.20) as well as the most recent `current` (6.12.21), and edge (6.14.1). Buildling a vendor image on bookworm works fine. Given I have two systems where one works and one doesn't, what can I check between them (deb package versions maybe? DTB files?) to help debug this?
