- Raspberry 5 - NVMe in USB-C case not detected
Hi, i have ordered complete new Hardware: - Raspberry 5 with 2GB, - USB-C NVME Case with RTL9201 chip and - NVME M.2 SSD: Kingspec NE-128 2280 with 128GB If I attached the M2 Case the SSD will not be detected (sda1) also not on an other PC. So now I don't know, what is defect (Case or SSD). I checked the Setting of the SSD in the case several times. Is there anything else, that I can do? Here some Logs: dmesg: [ 396.031067] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 396.175568] usb 1-1: New USB device found, idVendor=0bda, idProduct=9201, bcdDevice=f2.00 [ 396.175575] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 396.175579] usb 1-1: Product: RTL9201 [ 396.175583] usb 1-1: Manufacturer: Realtek [ 396.175586] usb 1-1: SerialNumber: 012345678999 [ 396.199296] usb-storage 1-1:1.0: USB Mass Storage device detected [ 396.203540] scsi host0: usb-storage 1-1:1.0 [ 397.222330] scsi 0:0:0:0: Direct-Access Realtek RTL9201 1.02 PQ: 0 ANSI: 6 [ 397.229650] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 397.234647] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x00 driverbyte=DRIVER_OK [ 397.234654] sd 0:0:0:0: [sda] Sense Key : 0x5 [current] [ 397.234659] sd 0:0:0:0: [sda] ASC=0x24 ASCQ=0x0 [ 397.235968] sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B) [ 397.235974] sd 0:0:0:0: [sda] 0-byte physical blocks [ 397.237121] sd 0:0:0:0: [sda] Write Protect is off [ 397.237125] sd 0:0:0:0: [sda] Mode Sense: 37 00 00 08 [ 397.238266] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 397.238589] sd 0:0:0:0: [sda] Attached SCSI disk lsusb -t: /: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/2p, 480M |__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=usb-storage, 480M /: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/2p, 480M |__ Port 002: Dev 002, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M |__ Port 002: Dev 002, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M /: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci-hcd/1p, 5000M lsblk: NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 0B 0 disk mmcblk0 179:0 0 29G 0 disk ├─mmcblk0p1 179:1 0 256M 0 part /boot/firmware └─mmcblk0p2 179:2 0 28,4G 0 part /var/log.hdd / zram0 253:0 0 1,9G 0 disk [SWAP] zram1 253:1 0 50M 0 disk /var/log zram2 253:2 0 0B 0 disk Is there anything else, that I can do? Or should I ship back SSD and USB Case both? Regards Christian
- BananaPi M1 failed boot after armbian-upgrade
Chris007
