I2S Audio Not Working on Orange Pi Zero 2W (Allwinner H618) with MAX98357A
Hi subhan i don't wait kernel update , i just use a script who create a user-overlay who enable the sound on the OPI zero 2w via HDMI , i2S via the 40 pin hat or jack connector via the expansion board and the µc is a H618 In fact the main board except for HDMI have no output for sound , so i think it's better to stay with a user-overlay ☺️
enable i2s on Orange pi zero 2w
Hello everyone For enable the i2s0 functionnality and pins you need to made an overlay with some declaration and clocks It work perfectly under Dietpi with a Dac PCM5102 I made a script for that, you can find it at the Forum Dietpi under the post "no sound card detected on opi zero 2w" At the end of the post Try it and tell if it works for you
How to turn on souncard in Orange Pi Zero 2W?
Hi all Sound work via expansion board for jack connector and HDMI via main bord and also via I2s work on orangepi zero 2w with the i2s0 pin, pi0, pi1, pi2, pi3 and pi4 for i2S You Need to apply an overlay to activated it on the device tree and choose some clock with a script I succeed to have sound with a Dac PCM5102A, with HDMI and jack connector and USB external device Cordialy
- I2S Audio Not Working on Orange Pi Zero 2W (Allwinner H618) with MAX98357A
Totof le Belge
