fxkl47BF
  1. that looks like a very ambitious undertaking
  2. on my system nand-sata-install is just a link to armbian-install ls -l /usr/bin/nand-sata-install lrwxrwxrwx 1 root root 15 Nov 22 2025 /usr/bin/nand-sata-install -> armbian-install do you mean that the nand-sata-install part of armbian-install is not maintained
  3. if nand-sata-install is not maintained is there a replacement
  4. i used nand-sata-install to move root from sd to ssd. at the end just after "Finalizing file sync ... Please wait" i got "Error while creating U-Boot loader image with mkimage" at the bottom of the screen. i rebooted and all seems to be working as planned. is this error anything to worry about?
  5. i can say that linux-image-6.12.43+deb12-arm64 works
  6. has any progress been made toward fixing this
  7. thanks for all the work you put in to this application. i've done this on most all of my systems and it was a bit tedious and fiddley. with just a few tweeks it ran through with no errors on my hc4 with bookworm. one question, why remove bash-completion and command-not-found packages?
  8. it appears to be a useful application is there a way to use it without a network
  9. Where did you get that info?
  10. i've been using armbian for a whole hour now i figure i've mastered this thing :) i loaded Armbian_25.5.1_Odroidxu4_bookworm_current_6.6.88_minimal.img on a sd and fired up an old xu4 according to the instruction the first thing to do is run armbian-config but it hangs because i don't have an interweb connection is there a way around that
