Samixa
  1. Hello, i tried "Armbian_community_26.2.0-trunk.606_Radxa-cubie-a5e_trixie_edge_6.19.8_minimal.img" and wlan didn't work, i think the device tree is broken Radxa-cubie-a5e kernel 6.19.x as a quick fix, I copy the kernel 6.18.x "sun55i-a527-cubie-a5e.dtb" file to the /boot/dtb/allwinner directory to get wlan working.
  2. Hi, install SD card -> Armbian_community_26.2.0-trunk.493_Radxa-cubie-a5e_trixie_edge_6.18.13_minimal.img.xz Login armbian and install newer Armbian U-boot "2026.01-S127a-P544c-H560c-Va7f1-B61c5-R448a" to SPI memory. sudo dd if=/usr/lib/linux-u-boot-edge-radxa-cubie-a5e/u-boot-sunxi-with-spl.bin of=/dev/mtdblock0 I hope this helps.
  3. Maybe this -> https://github.com/torvalds/linux/commit/a15f095b590bcc1968fbf2ced8fe87fbd8d012e0
  4. Hello Nob0dy , If you use 25.11.0-trunk.129 after cold reboot you must make soft reboot then second Ethernet port work.
  5. Hi, I tested with the version 25.11.0-trunk.129 and the second network port worked with this. https://paste.armbian.com/hasewoloti
  6. Radxa-cubie-a5e second Ethernet port not work after update Armbian 25.11.0-trunk.259.
