cvxx
  1. Cool! Is it possible to build a test image? I tried to download this pull request locally and build it, but I can't find OrangePi 4A in the list of target boards. Any hints how to build it and test?
  2. @JuanEsf in case you need testing - I own both OrangePi 4A and Radxa Cubie A5E. So far I tried to build the image from your repo (https://github.com/juanesf/build) - neither board boots for me.
  3. Hi, is there currently support for NVMe storage in Armbian trunk? I tried to flash the latest build, added nvme ssd storage - but it is not seen in the system. What to check?
  4. Don't know where to report this as Armbian bug reporting form refused to accept community supported board, but it may not necessarily be board-specific. When logging the first time there is a message: sed: -e expression #1, char 0: no previous regular expression Generating locales: en_US.UTF-8 _ _ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, | |___| |__/ v25.8 rolling for radxa cubie a5e running Armbian Linux 6.14.0-rc1-dev-sun55iw3 Packages: Debian stable (bookworm) Updates: Kernel upgrade enabled and 2 packages available for upgrade Support: for advanced users (rolling release) sed: -e expression #1, char 0: no previous regular expression Performance: Load: 6% Uptime: 17 min Memory usage: 7% of 1.93G CPU temp: 54°C Usage of /: 15% of 6.7G Commands: Configuration : armbian-config Upgrade : armbian-upgrade Monitoring : htop The second login does not show this message. Hope this helps
  5. Hi, posting a solution I have found how to boot Armbian on S905x device Scishion V88 Pro My device: * works, boots into an Android (has working u-boot) * has no reset button * contains thirdparty Android ROM that does not allow to enter aml burn mode * cannot use Android update app * does not respond to eMMC pin short (like in this post) The only way to boot Armbian in this case is to solder serial console, interrupt u-boot and run recover from sd card command: 1. solder serial console 2. connect usb-serial adapter 3. insert Armbian prepared SD card for your amlogic CPU version 4. plug power and immediately press and hold Enter 5. you should see interrupted u-boot prompt (ex, gxl_p212_v1#) 6. type command run recovery_from_sdcard and hit Enter 7. the box should now boot in Armbian An example session: gxl_p212_v1#help ? - alias for 'help' aml_sysrecovery- Burning with amlogic format package from partition sysrecovery amlmmc - AMLMMC sub system amlnf - aml nand sub-system amlnf_test- AMLPHYNAND sub-system autoscr - run script from memory base - print or set address offset bmp - manipulate BMP image data booti - boot arm64 Linux Image image from memory bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol cbusreg - cbus register read/write clkmsr - measure PLL clock cmp - memory compare cp - memory copy crc32 - checksum calculation cvbs - CVBS sub-system dcache - enable or disable data cache defenv_reserv- reserve some specified envs after defaulting env dhcp - boot image via network using DHCP/TFTP protocol echo - echo args to console efuse - efuse read/write data commands efuse_user- efuse user space read write ops emmc - EMMC sub system env - environment handling commands exit - exit script false - do nothing, unsuccessfully fatinfo - print information about filesystem fatload - load binary file from a dos filesystem fatls - list files in a directory (default /) fatsize - determine a file's size fdt - flattened device tree utility commands forceupdate- forceupdate get_rebootmode- get reboot mode go - start application at address 'addr' gpio - query and control gpio pins hdmitx - HDMITX sub-system help - print command description/usage i2c - I2C sub-system icache - enable or disable instruction cache imgread - Read the image from internal flash with actual size irkey - irkey key_value1 key_value2 time_value itest - return true/false on integer compare jtagoff - disable jtag jtagon - enable jtag keyman - Unify key ops interfaces based dts cfg keyunify- key unify sub-system loop - infinite loop on address range macreg - ethernet mac register read/write/dump md - memory display mm - memory modify (auto-incrementing address) mmc - MMC sub system mmcinfo - display MMC info mw - memory write (fill) mwm - mw mask function nm - memory modify (constant address) open_scp_log- print SCP messgage osd - osd sub-system phyreg - ethernet phy register read/write/dump ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables rarpboot- boot image via network using RARP/TFTP protocol read_temp- cpu temp-system reboot - set reboot mode and reboot system reset - Perform RESET of the CPU rsvmem - reserve memory run - run commands in an environment variable saradc - saradc sub-system saradc_12bit- saradc sub-system saveenv - save environment variables to persistent storage sdc_burn- Burning with amlogic format package in sdmmc sdc_update- Burning a partition with image file in sdmmc card set_trim_base- cpu temp-system set_usb_boot- set usb boot mode setenv - set environment variables showvar - print local hushshell variables silent - silent sleep - delay execution for some time store - STORE sub-system systemoff- system off temp_triming- cpu temp-system test - minimal test like /bin/sh tftpboot- boot image via network using TFTP protocol true - do nothing, successfully unpackimg- un pack logo image into pictures update - Enter v2 usbburning mode usb - USB sub-system usb_burn- Burning with amlogic format package in usb usb_update- Burning a partition with image file in usb host usbboot - boot from USB device version - print monitor, compiler and linker version vout - VOUT sub-system vpu - vpu sub-system wipeisb - wipeisb write_trim- cpu temp-system write_version- cpu temp-system gxl_p212_v1#printenv EnableSelinux=enforcing aml_dt=gxl_p212_1g baudrate=115200 bootargs=rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permissive androidboot.selinux=enforcing logo=osd1,loaded,0x3d800000,1080p60hz maxcpus=4 vout=1080p60hz,enable hdmimode=1080p60hz cvbsmode=576cvbs hdmitx= cvbsdrv=0 androidboot.firstboot=0 jtag=apee androidboot.hardware=amlogic bootcmd=run storeboot bootdelay=1 bootup_offset=0x1080240 bootup_size=0x3f4c8 cmdline_keys=if keyman init 0x1234; then if keyman read usid ${loadaddr} str; then setenv bootargs ${bootargs} androidboot.serialno=${usid};fi;if keyman read mac ${loadaddr} str; then setenv bootargs ${bootargs} mac=${mac} androidboot.mac=${mac};fi;if keyman read deviceid ${loadaddr} str; then setenv bootargs ${bootargs} androidboot.deviceid=${deviceid};fi;fi; cvbs_drv=0 cvbsmode=576cvbs display_bpp=16 display_color_bg=0 display_color_fg=0xffff display_color_index=16 display_height=1080 display_layer=osd1 display_width=1920 dtb_mem_addr=0x1000000 ethact=dwmac.c9410000 ethaddr=00:15:18:01:81:31 factory_reset_poweroff_protect=echo wipe_data=${wipe_data}; echo wipe_cache=${wipe_cache};if test ${wipe_data} = failed; then run init_display; run storeargs;if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash;fi; if test ${wipe_cache} = failed; then run init_display; run storeargs;if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash;fi; fb_addr=0x3d800000 fb_height=1080 fb_width=1920 fdt_high=0x20000000 firstboot=0 gatewayip=10.18.9.1 hdmimode=1080p60hz hostname=arm_gxbb init_display=osd open;osd clear;imgread pic logo bootup $loadaddr;bmp display $bootup_offset;bmp scale initargs=rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permissive ipaddr=10.18.9.97 jtag=apee loadaddr=1080000 maxcpus=4 netmask=255.255.255.0 outputmode=1080p60hz preboot=run factory_reset_poweroff_protect;run upgrade_check;run init_display;run storeargs;run upgrade_key;run upgrade_sadckey;run switch_bootmode; reboot_mode=normal recovery_from_flash=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if imgread kernel ${recovery_part} ${loadaddr} ${recovery_offset}; then wipeisb; bootm ${loadaddr}; fi recovery_from_sdcard=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if fatload mmc 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;if fatload mmc 0 ${loadaddr} recovery.img; then if fatload mmc 0 ${dtb_mem_addr} dtb.img; then echo sd dtb.img loaded; fi;wipeisb; bootm ${loadaddr};fi; recovery_from_udisk=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if fatload usb 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;if fatload usb 0 ${loadaddr} recovery.img; then if fatload usb 0 ${dtb_mem_addr} dtb.img; then echo udisk dtb.img loaded; fi;wipeisb; bootm ${loadaddr};fi; recovery_offset=0 recovery_part=recovery sdc_burning=sdc_burn ${sdcburncfg} sdcburncfg=aml_sdc_burn.ini serverip=10.18.9.113 stderr=serial stdin=serial stdout=serial storeargs=setenv bootargs ${initargs} androidboot.selinux=${EnableSelinux} logo=${display_layer},loaded,${fb_addr},${outputmode} maxcpus=${maxcpus} vout=${outputmode},enable hdmimode=${hdmimode} cvbsmode=${cvbsmode} hdmitx=${cecconfig} cvbsdrv=${cvbs_drv} androidboot.firstboot=${firstboot} jtag=${jtag}; setenv bootargs ${bootargs} androidboot.hardware=amlogic;run cmdline_keys; storeboot=echo Booting...; if unifykey get usid; then setenv bootargs ${bootargs} androidboot.serialno=${usid};fi;if unifykey get mac; then setenv bootargs ${bootargs} mac=${ethaddr};fi;if imgread kernel boot ${loadaddr}; then bootm ${loadaddr}; fi;run update; switch_bootmode=get_rebootmode;if test ${reboot_mode} = factory_reset; then run recovery_from_flash;else if test ${reboot_mode} = update; then run update;else if test ${reboot_mode} = cold_boot; then fi;fi;fi; try_auto_burn=update 700 750; update=run usb_burning; run sdc_burning; if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash; upgrade_check=echo upgrade_step=${upgrade_step}; if itest ${upgrade_step} == 3; then run init_display; run storeargs; run update;else fi; upgrade_key=if gpio input GPIOAO_2; then echo detect upgrade key; sleep 3;if gpio input GPIOAO_2; then run update; fi;fi; upgrade_sadckey=saradc open 0; echo detect sadckey ....;if saradc get_in_range 0 0x50; then sleep 1; if saradc get_in_range 0 0x50; then echo update by key...; run update; fi;fi; upgrade_step=2 usb_burning=update 1000 wipe_cache=successful wipe_data=successful Environment size: 5164/65532 bytes gxl_p212_v1#run recovery_from_sdcard card in [mmc_init] mmc init success reading aml_autoscript 800 bytes read in 4 ms (195.3 KiB/s) ## Executing script at 01080000 ## Error: "bootfromsd" not defined Saving Environment to aml-storage... mmc env offset: 0x27400000 Writing to MMC(1)... done reboot use default mode: normal INFO: PSCI Affinity Map: INFO: AffInst: Level 0, MPID 0x0, State ON INFO: AffInst: Level 0, MPID 0x1, State OFF INFO: AffInst: Level 0, MPID 0x2, State OFF INFO: AffInst: Level 0, MPID 0x3, State OFF bl31 reboot reason: 0xd bl31 reboot reason: 0x1 system cmd 1. ERROR: gxbb System RGXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 94201 BL2 Built : 19:41:49, Jun 20 2016. gxl ge299011 - xiaobo.gu@droid05 set vcck to 1120 mv set vddee to 1000 mv Board ID = 2 CPU clk: 1200MHz DDR3 chl: Rank0+1 @ 528MHz - FAIL DDR3 chl: Rank0 @ 528MHz - PASS DQS-corr enabled DDR scramble enabled Rank0: 1024MB(auto)-2T-7 DataBus test pass! AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00014400 Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x000a8000 NOTICE: BL3-1: v1.0(debug):c813a61 NOTICE: BL3-1: Built : 14:39:44, Jun 16 2016 aml log : bl31 normal boot ! [Image: gxl_v1.1.3137-2517a7a 2016-06-24 11:31:11 xing.xu@droid05] OPS=0x82 49 fa cb 46 f4 e1 33 33 f1 68 a2 be [0.441838 Inits done] secure task start! high task start! low task start! INFO: BL3-1: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader ERROR: Error initializing runtime service opteed_fast INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01 (Aug 11 2016 - 17:47:33) DRAM: 1 GiB Relocation Offset is: 36ecb000 register usb cfg[0][1] = 0000000037f5faf0 vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: clk_level = 7 vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300) vpp: vpp_init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000033ecb6b0 aml_priv->desc_buf = 0x0000000033ecd9d0 SDIO Port B: 0, SDIO Port 😄 1 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 [mmc_startup] mmc refix success [mmc_init] mmc init success mmc read lba=0x14000, blocks=0x400 Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p212 variant: 1g dtb 0 soc: gxl plat: p212 vari: 1g dtb 1 soc: gxl plat: p212 vari: 2g Find match dtb: 0 start dts,buffer=0000000033ed0270,dt_addr=0000000033ed0a70 parts: 11 00: logo 0000000002000000 1 01: recovery 0000000002000000 1 02: rsv 0000000000800000 1 03: tee 0000000000800000 1 04: crypt 0000000002000000 1 05: misc 0000000002000000 1 06: instaboot 0000000020000000 1 07: boot 0000000002000000 1 08: system 0000000040000000 1 09: cache 0000000020000000 2 10: data ffffffffffffffff 4 get_dtb_struct: Get emmc dtb OK! overide_emmc_partition_table: overide cache [mmc_get_partition_table] skip partition cache. Partition table get from SPL is : name offset size flag =================================================================================== 0: bootloader 0 400000 0 1: reserved 2400000 4000000 0 2: cache 6c00000 20000000 2 3: env 27400000 800000 0 4: logo 28400000 2000000 1 5: recovery 2ac00000 2000000 1 6: rsv 2d400000 800000 1 7: tee 2e400000 800000 1 8: crypt 2f400000 2000000 1 9: misc 31c00000 2000000 1 10: instaboot 34400000 20000000 1 11: boot 54c00000 2000000 1 12: system 57400000 40000000 1 13: data 97c00000 130400000 4 mmc read lba=0x12000, blocks=0x2 mmc read lba=0x12002, blocks=0x2 mmc_read_partition_tbl: mmc read partition OK! eMMC/TSD partition table have been checked OK! mmc env offset: 0x27400000 In: serial Out: serial Err: serial reboot_mode=normal hpd_state=1 [1080p60hz] is invalid for cvbs. set hdmitx VIC = 16 config HPLL = 2970 HPLL: 0xc000027b config HPLL done j = 4 vid_clk_div = 1 hdmitx phy setting done hdmitx: set enc for VIC: 16 enc_vpu_bridge_reset[1183] rx version is 2.0 div=10 [store]To run cmd[emmc dtb_read 0x1000000 0x40000] read emmc dtb Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p212 variant: 1g dtb 0 soc: gxl plat: p212 vari: 1g dtb 1 soc: gxl plat: p212 vari: 2g Find match dtb: 0 Net: dwmac.c9410000 wipe_data=successful wipe_cache=successful upgrade_step=2 [OSD]load fb addr from dts [OSD]failed to get fb addr for logo [OSD]use default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]load fb addr from dts [OSD]failed to get fb addr for logo [OSD]use default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [CANVAS]addr=0x3d800000 width=3840, height=2160 amlkey_init() enter! [EFUSE_MSG]keynum is 4 [KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[mac] not programed yet [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet gpio: pin GPIOAO_2 (gpio 102) value is 1 get_cpu_id flag_12bit=1 detect sadckey .... saradc - saradc sub-system Usage: saradc saradc open <channel> - open a SARADC channel saradc close - close the SARADC saradc getval - get the value in current channel saradc get_in_range <min> <max> - return 0 if current value in the range of current channel Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 card in [mmc_init] mmc init success Device: SDIO Port B Manufacturer ID: 74 OEM: 4a45 Name: SDC Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 15 GiB mmc clock: 40000000 Bus Width: 4-bit reading s905_autoscript 537 bytes read in 4 ms (130.9 KiB/s) ## Executing script at 01020000 start amlogic old u-boot ## Error: "bootfromsd" not defined reading boot_android ** Unable to read file boot_android ** ** Bad device usb 0 ** reading u-boot.ext 646455 bytes read in 48 ms (12.8 MiB/s) ## Starting application at 0x01000000 ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.53-current-meson64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Mon Sep 30 14:25:15 UTC 2024 [ 0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x000000002a800000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000002a800000..0x000000003a7fffff (262144 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x0000000000000000..0x0000000000ffffff (16384 KiB) nomap non-reusable hwrom@0 [ 0.000000] OF: reserved mem: 0x0000000005000000..0x00000000052fffff (3072 KiB) nomap non-reusable secmon@5000000 [ 0.000000] OF: reserved mem: 0x0000000005300000..0x00000000072fffff (32768 KiB) nomap non-reusable secmon@5300000 [ 0.000000] OF: reserved mem: 0x0000000010000000..0x00000000101fffff (2048 KiB) nomap non-reusable secmon@10000000 [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000003f806fff] [ 0.000000] NUMA: NODE_DATA [mem 0x3f5e7940-0x3f5e9fff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000000000-0x000000003f806fff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000000ffffff] [ 0.000000] node 0: [mem 0x0000000001000000-0x0000000004ffffff] [ 0.000000] node 0: [mem 0x0000000005000000-0x00000000072fffff] [ 0.000000] node 0: [mem 0x0000000007300000-0x000000000fffffff] [ 0.000000] node 0: [mem 0x0000000010000000-0x00000000101fffff] [ 0.000000] node 0: [mem 0x0000000010200000-0x000000003f806fff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003f806fff] [ 0.000000] On node 0, zone DMA: 2041 pages in unavailable ranges [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv0.2 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] percpu: Embedded 22 pages/cpu s51304 r8192 d30616 u90112 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=bb7643a4-cf60-4444-9fc3-c565842689c1 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles [ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 256038 [ 0.000000] Policy zone: DMA [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 0MB [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x000000003e280000-0x000000003e380000] (1MB) [ 0.000000] Memory: 653368K/1040412K available (16192K kernel code, 1700K rwdata, 4964K rodata, 3776K init, 606K bss, 124900K reserved, 262144K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000329] Console: colour dummy device 80x25 [ 0.000344] printk: console [tty0] enabled [ 0.000943] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000969] pid_max: default: 32768 minimum: 301 [ 0.001063] LSM: initializing lsm=capability,yama,apparmor,integrity [ 0.001102] Yama: becoming mindful. [ 0.001209] AppArmor: AppArmor initialized [ 0.001325] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.001349] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.003465] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.003582] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.003836] rcu: Hierarchical SRCU implementation. [ 0.003852] rcu: Max phase no-delay instances is 1000. [ 0.005705] EFI services will not be available. [ 0.006241] smp: Bringing up secondary CPUs ... [ 0.006969] Detected VIPT I-cache on CPU1 [ 0.007096] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.007958] Detected VIPT I-cache on CPU2 [ 0.008080] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.008931] Detected VIPT I-cache on CPU3 [ 0.009047] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.009176] smp: Brought up 1 node, 4 CPUs [ 0.009247] SMP: Total of 4 processors activated. [ 0.009259] CPU features: detected: 32-bit EL0 Support [ 0.009269] CPU features: detected: 32-bit EL1 Support [ 0.009282] CPU features: detected: CRC32 instructions [ 0.009375] CPU: All CPU(s) started at EL2 [ 0.009396] alternatives: applying system-wide alternatives [ 0.011402] devtmpfs: initialized [ 0.018489] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.018564] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.026914] pinctrl core: initialized pinctrl subsystem [ 0.027526] DMI not present or invalid. [ 0.028305] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.030314] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 0.030515] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.030690] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.030776] audit: initializing netlink subsys (disabled) [ 0.031078] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1 [ 0.031633] thermal_sys: Registered thermal governor 'fair_share' [ 0.031643] thermal_sys: Registered thermal governor 'bang_bang' [ 0.031659] thermal_sys: Registered thermal governor 'step_wise' [ 0.031671] thermal_sys: Registered thermal governor 'user_space' [ 0.031752] cpuidle: using governor menu [ 0.032151] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.032289] ASID allocator initialised with 65536 entries [ 0.033246] Serial: AMBA PL011 UART driver [ 0.044590] platform d0100000.vpu: Fixed dependency cycle(s) with /soc/hdmi-tx@c883a000 [ 0.044823] platform d0100000.vpu: Fixed dependency cycle(s) with /soc/hdmi-tx@c883a000 [ 0.044896] platform c883a000.hdmi-tx: Fixed dependency cycle(s) with /soc/vpu@d0100000 [ 0.047373] platform d0100000.vpu: Fixed dependency cycle(s) with /cvbs-connector [ 0.047478] platform cvbs-connector: Fixed dependency cycle(s) with /soc/vpu@d0100000 [ 0.047645] platform c883a000.hdmi-tx: Fixed dependency cycle(s) with /hdmi-connector [ 0.047723] platform hdmi-connector: Fixed dependency cycle(s) with /soc/hdmi-tx@c883a000 [ 0.048609] Modules: 25904 pages in range for non-PLT usage [ 0.048621] Modules: 517424 pages in range for PLT usage [ 0.049590] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.049635] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.049649] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.049660] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.049673] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.049685] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.049698] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.049710] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.050757] cryptd: max_cpu_qlen set to 1000 [ 0.116394] raid6: neonx8 gen() 2145 MB/s [ 0.184466] raid6: neonx4 gen() 2193 MB/s [ 0.252548] raid6: neonx2 gen() 2087 MB/s [ 0.320636] raid6: neonx1 gen() 1783 MB/s [ 0.388713] raid6: int64x8 gen() 1366 MB/s [ 0.456793] raid6: int64x4 gen() 1606 MB/s [ 0.524879] raid6: int64x2 gen() 1401 MB/s [ 0.592977] raid6: int64x1 gen() 1036 MB/s [ 0.592989] raid6: using algorithm neonx4 gen() 2193 MB/s [ 0.661030] raid6: .... xor() 1556 MB/s, rmw enabled [ 0.661043] raid6: using neon recovery algorithm [ 0.661698] ACPI: Interpreter disabled. [ 0.662702] iommu: Default domain type: Translated [ 0.662748] iommu: DMA domain TLB invalidation policy: strict mode [ 0.663591] SCSI subsystem initialized [ 0.663886] usbcore: registered new interface driver usbfs [ 0.663932] usbcore: registered new interface driver hub [ 0.663988] usbcore: registered new device driver usb [ 0.664389] pps_core: LinuxPPS API ver. 1 registered [ 0.664403] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.664430] PTP clock support registered [ 0.664717] EDAC MC: Ver: 3.0.0 [ 0.665431] scmi_core: SCMI protocol bus registered [ 0.666858] NetLabel: Initializing [ 0.666895] NetLabel: domain hash size = 128 [ 0.666905] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.666978] NetLabel: unlabeled traffic allowed by default [ 0.666990] mctp: management component transport protocol core [ 0.667002] NET: Registered PF_MCTP protocol family [ 0.667338] vgaarb: loaded [ 0.667944] clocksource: Switched to clocksource arch_sys_counter [ 0.668331] VFS: Disk quotas dquot_6.6.0 [ 0.668386] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.669039] AppArmor: AppArmor Filesystem Enabled [ 0.669231] pnp: PnP ACPI: disabled [ 0.676553] NET: Registered PF_INET protocol family [ 0.676760] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.677912] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) [ 0.678131] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.678187] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.678341] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.678571] TCP: Hash tables configured (established 8192 bind 8192) [ 0.678890] MPTCP token hash table entries: 1024 (order: 2, 24576 bytes, linear) [ 0.678989] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.679031] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.679256] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.679324] PCI: CLS 0 bytes, default 64 [ 0.679655] Trying to unpack rootfs image as initramfs... [ 0.684152] kvm [1]: IPA Size Limit: 40 bits [ 0.685347] kvm [1]: vgic interrupt IRQ9 [ 0.685423] kvm [1]: Hyp mode initialized successfully [ 0.688098] Initialise system trusted keyrings [ 0.688210] Key type blacklist registered [ 0.688445] workingset: timestamp_bits=44 max_order=18 bucket_order=0 [ 0.688527] zbud: loaded [ 0.689160] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.689832] fuse: init (API version 7.39) [ 0.691883] integrity: Platform Keyring initialized [ 0.724112] xor: measuring software checksum speed [ 0.728102] 8regs : 2524 MB/sec [ 0.732077] 32regs : 2523 MB/sec [ 0.736355] arm64_neon : 2335 MB/sec [ 0.736385] xor: using function: 8regs (2524 MB/sec) [ 0.736411] Key type asymmetric registered [ 0.736425] Asymmetric key parser 'x509' registered [ 0.736614] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.736926] io scheduler mq-deadline registered [ 0.736971] io scheduler kyber registered [ 0.737060] io scheduler bfq registered [ 0.737682] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized [ 0.750690] EINJ: ACPI disabled. [ 0.760568] soc soc0: Amlogic Meson GXL (S905X) Revision 21:a (82:2) Detected [ 0.763380] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.771317] Serial: AMBA driver [ 0.772506] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 14, base_baud = 1500000) is a meson_uart [ 0.772995] serial serial0: tty port ttyAML6 registered [ 0.774230] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 15, base_baud = 1500000) is a meson_uart [ 0.774301] printk: console [ttyAML0] enabled [ 1.739205] Freeing initrd memory: 21632K [ 1.998474] loop: module loaded [ 2.006175] tun: Universal TUN/TAP device driver, 1.6 [ 2.007623] thunder_xcv, ver 1.0 [ 2.009026] thunder_bgx, ver 1.0 [ 2.012164] nicpf, ver 1.0 [ 2.015761] e1000e: Intel(R) PRO/1000 Network Driver [ 2.019700] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 2.026670] igb: Intel(R) Gigabit Ethernet Network Driver [ 2.030848] igb: Copyright (c) 2007-2014 Intel Corporation. [ 2.036442] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 2.042562] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 2.048795] sky2: driver version 1.30 [ 2.053285] VFIO - User Level meta-driver version: 0.3 [ 2.060720] usbcore: registered new interface driver usb-storage [ 2.066261] mousedev: PS/2 mouse device common for all mice [ 2.069980] i2c_dev: i2c /dev entries driver [ 2.078109] sdhci: Secure Digital Host Controller Interface driver [ 2.078938] sdhci: Copyright(c) Pierre Ossman [ 2.083836] Synopsys Designware Multimedia Card Interface Driver [ 2.090821] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.091457] meson-gx-mmc d0072000.mmc: Got CD GPIO [ 2.093524] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq [ 2.105155] ledtrig-cpu: registered to indicate activity on CPUs [ 2.112906] meson-sm: secure-monitor enabled [ 2.116872] gxl-crypto c883e000.crypto: will run requests pump with realtime priority [ 2.123234] gxl-crypto c883e000.crypto: will run requests pump with realtime priority [ 2.131222] hid: raw HID events driver (C) Jiri Kosina [ 2.135974] gpio irq setup: hwirq: 0x3A irqfirst: 0x34 irqlast: 0x3A pin[48] [ 2.136066] usbcore: registered new interface driver usbhid [ 2.143432] genirq: Setting trigger mode 3 for irq 20 failed (meson_gpio_irq_set_type+0x0/0x60) [ 2.148374] usbhid: USB HID core driver [ 2.161508] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered [ 2.169300] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 2.178827] NET: Registered PF_INET6 protocol family [ 2.182401] Segment Routing with IPv6 [ 2.184386] In-situ OAM (IOAM) with IPv6 [ 2.187909] mmc0: new high speed SDHC card at address b368 [ 2.188255] NET: Registered PF_PACKET protocol family [ 2.195141] mmcblk0: mmc0:b368 SDC 15.0 GiB [ 2.198860] 8021q: 802.1Q VLAN Support v1.8 [ 2.206533] mmcblk0: p1 p2 [ 2.207428] Key type dns_resolver registered [ 2.234401] registered taskstats version 1 [ 2.234750] Loading compiled-in X.509 certificates [ 2.248234] mmc1: new HS200 MMC card at address 0001 [ 2.252487] mmcblk1: mmc1:0001 T22708 7.13 GiB [ 2.257845] mmcblk1boot0: mmc1:0001 T22708 4.00 MiB [ 2.261435] mmcblk1boot1: mmc1:0001 T22708 4.00 MiB [ 2.265759] mmcblk1rpmb: mmc1:0001 T22708 4.00 MiB, chardev (241:0) [ 2.267623] zswap: loaded using pool zstd/z3fold [ 2.284689] Key type .fscrypt registered [ 2.284746] Key type fscrypt-provisioning registered [ 2.291055] Btrfs loaded, zoned=yes, fsverity=yes [ 2.292881] Key type encrypted registered [ 2.296606] AppArmor: AppArmor sha1 policy hashing enabled [ 2.319775] meson-drm d0100000.vpu: Queued 2 outputs on vpu [ 2.348035] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) [ 2.353046] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver [ 2.360422] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops 0xffff80008110a290) [ 2.368601] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0 [ 3.012446] Console: switching to colour frame buffer device 160x45 [ 3.046669] meson-drm d0100000.vpu: [drm] fb0: mesondrmfb frame buffer device [ 3.056943] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware [ 3.057606] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq [ 3.071375] dwc3-meson-g12a d0078080.usb: USB2 ports: 2 [ 3.071701] dwc3-meson-g12a d0078080.usb: USB3 ports: 0 [ 3.114943] mmc2: new high speed SDIO card at address 0001 [ 3.593479] dwc2 c9100000.usb: supply vusb_d not found, using dummy regulator [ 3.595571] dwc2 c9100000.usb: supply vusb_a not found, using dummy regulator [ 3.604268] dwc2 c9100000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM [ 3.611804] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 3.614923] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 3.622631] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports [ 3.628685] xhci-hcd xhci-hcd.1.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000008002000010 [ 3.637759] xhci-hcd xhci-hcd.1.auto: irq 32, io mem 0xc9000000 [ 3.643950] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06 [ 3.651811] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.659266] usb usb1: Product: xHCI Host Controller [ 3.663792] usb usb1: Manufacturer: Linux 6.6.53-current-meson64 xhci-hcd [ 3.670499] usb usb1: SerialNumber: xhci-hcd.1.auto [ 3.676191] hub 1-0:1.0: USB hub found [ 3.684178] hub 1-0:1.0: 2 ports detected [ 3.694794] clk: Disabling unused clocks [ 3.704673] Freeing unused kernel memory: 3776K [ 3.712598] Run /init as init process [ 3.952047] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 4.109784] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36 [ 4.122655] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.133996] usb 1-1: Product: USB2.0 Hub [ 4.188471] hub 1-1:1.0: USB hub found [ 4.197352] hub 1-1:1.0: 4 ports detected [ 4.378076] meson-vrtc c81000a8.rtc: registered as rtc0 [ 4.386658] meson-vrtc c81000a8.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4) [ 4.408800] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found [ 4.418343] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found [ 4.428065] meson8b-dwmac c9410000.ethernet: PTP uses main clock [ 4.430124] random: crng init done [ 4.437457] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37 [ 4.463473] meson8b-dwmac c9410000.ethernet: DWMAC1000 [ 4.471552] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported [ 4.481659] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported [ 4.492058] meson8b-dwmac c9410000.ethernet: COE Type 2 [ 4.496064] usb 1-1.2: new low-speed USB device number 3 using xhci-hcd [ 4.499990] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported [ 4.500002] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported [ 4.500241] meson8b-dwmac c9410000.ethernet: Normal descriptors [ 4.546035] meson8b-dwmac c9410000.ethernet: Ring mode enabled [ 4.553913] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.612079] usb 1-1.2: New USB device found, idVendor=0e8f, idProduct=2517, bcdDevice= 1.00 [ 4.622732] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 4.711090] input: HID 0e8f:2517 as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:0E8F:2517.0001/input/input0 [ 4.872910] hid-generic 0003:0E8F:2517.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 0e8f:2517] on usb-xhci-hcd.1.auto-1.2/input0 [ 4.889832] input: HID 0e8f:2517 Consumer Control as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:0E8F:2517.0002/input/input1 [ 4.960497] input: HID 0e8f:2517 as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:0E8F:2517.0002/input/input2 [ 4.969600] input: HID 0e8f:2517 Mouse as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:0E8F:2517.0002/input/input3 [ 4.984451] hid-generic 0003:0E8F:2517.0002: input,hidraw1: USB HID v1.10 Mouse [HID 0e8f:2517] on usb-xhci-hcd.1.auto-1.2/input1 [ 7.325871] EXT4-fs (mmcblk0p2): mounted filesystem bb7643a4-cf60-4444-9fc3-c565842689c1 r/w with writeback data mode. Quota mode: none. [ 8.608652] systemd[1]: System time before build time, advancing clock. [ 8.646756] systemd[1]: Inserted module 'autofs4' [ 8.747816] systemd[1]: systemd 255.4-1ubuntu8.4 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 8.774826] systemd[1]: Detected architecture arm64. [ 8.788407] systemd[1]: Hostname set to <aml-s9xx-box>. [ 8.798036] systemd[1]: Initializing machine ID from random generator. [ 13.117643] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway. [ 13.813360] systemd[1]: Queued start job for default target graphical.target. [ 13.879198] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [ 13.885686] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 13.893115] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck. [ 13.900979] systemd[1]: Created slice user.slice - User and Session Slice. [ 13.906566] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [ 13.917664] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [ 13.928909] systemd[1]: Expecting device dev-disk-by\x2duuid-B1CE\x2d0046.device - /dev/disk/by-uuid/B1CE-0046... [ 13.939010] systemd[1]: Expecting device dev-ttyAML0.device - /dev/ttyAML0... [ 13.946174] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes. [ 13.955024] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups. [ 13.963405] systemd[1]: Reached target slices.target - Slice Units. [ 13.969502] systemd[1]: Reached target snapd.mounts-pre.target - Mounting snaps. [ 13.976827] systemd[1]: Reached target snapd.mounts.target - Mounted snaps. [ 13.983770] systemd[1]: Reached target swap.target - Swaps. [ 13.989227] systemd[1]: Reached target time-set.target - System Time Set. [ 13.996178] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes. [ 14.065501] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket. [ 14.069429] systemd[1]: Listening on syslog.socket - Syslog Socket. [ 14.075405] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket. [ 14.083705] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ 14.092756] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [ 14.101587] systemd[1]: Listening on systemd-journald.socket - Journal Socket. [ 14.107987] systemd[1]: systemd-pcrextend.socket - TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 14.127390] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [ 14.131110] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ 14.176427] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System... [ 14.185060] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 14.194982] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System... [ 14.198296] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 14.214047] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab). [ 14.238221] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 14.249699] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout... [ 14.262157] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes... [ 14.274003] (-hwclock)[1174]: fake-hwclock-load.service: Referenced but unset environment variable evaluates to an empty string: FORCE [ 14.278165] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs... [ 14.305340] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod... [ 14.326511] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 14.345426] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 14.365374] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse... [ 14.385715] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop... [ 14.391807] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 14.408189] device-mapper: uevent: version 1.0.3 [ 14.409094] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com [ 14.421548] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 14.425225] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 14.448657] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 14.453238] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 14.474641] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 14.493280] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [ 14.496550] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 14.505204] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 14.513869] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 14.518816] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 14.530682] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 14.541007] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 14.543620] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 14.554554] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 14.558823] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 14.567334] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 14.573773] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 14.581623] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 14.587319] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. Welcome to Armbian_community! Documentation: https://docs.armbian.com | Community support: https://community.armbian.com/ IP address: Network connection timeout! Create root password:
  6. Answering my own question Turned out you have to boot once from SD using the reset button and then reboot from Armbian. S905 will boot from SD now on. Keep the SD in the slot and it will always boot from SD
  7. Hi, I have installed Armbian on an SD card and can successfully boot from SD by holding reset button during power plug. Given that it is not possible to install Armbian to eMMC on S905, is it possible at least to make it always boot from SD?
  8. I don't have a TTL at the moment, but I can confirm too that: Armbian 24.2.1 Jammy CLI - does not boot Armbian 24.2.1 Bookworm CLI - boots tagging the maintainer for visibility @schwar3kat
  9. Hi, Armbian_21.02.3_Odroidc1_focal_current_5.10.21 how do I find out which number do I need to provide to gpio export command? Let's say I have physical pin 16, which is labeled by the manufacturer as `GPIOX.5` or `102`. But that doesn't work with Armbian: echo 102 > /sys/class/gpio/export [ 1602.030617] export_store: invalid GPIO 102 How do I know the value to provide for /sys/class/gpio/export? # cat /sys/kernel/debug/gpio gpiochip1: GPIOs 413-428, parent: platform/c8100084.pinctrl, aobus-banks: gpio-416 ( |TF_IO ) out lo gpio-417 ( |usb-hub-reset ) out hi gpio-426 ( |c1:blue:alive ) out hi ACTIVE LOW gpiochip0: GPIOs 429-511, parent: platform/c1109880.pinctrl, cbus-banks: gpio-456 ( |regulator-tflash_vdd) out lo gpio-470 ( |PHY reset ) out hi ACTIVE LOW gpio-482 ( |cd ) in hi ACTIVE LOW gpio-492 ( |reset ) out hi ACTIVE LOW Thanks
  10. Hi, on latest Armbian 23.11.1 Bookworm with PINE64 board I noticed those warnings in journal: Feb 12 10:00:45 pine64 systemd[1]: /lib/systemd/system/systemd-journal-upload.service:33: Unknown key name 'RestartSteps' in s> Feb 12 10:00:45 pine64 systemd[1]: /lib/systemd/system/systemd-journal-upload.service:34: Unknown key name 'RestartMaxDelaySec> I suspect the `systemd-journal-upload.service` is not in tact with systemd daemon version installed.
