Marvell BG4CT
Hello everyone, is there a solution to install Armbian on it? Thanks to all the experts.
Marvell BG4CT
Hello, can someone help me with Armbian for this Android box, which seems to have a good configuration for a media center? I would like to know how to flash it and which firmware image I can install on it. Thank you. BBox 4K Specifications: Dimensions: 15x15x3.6cm SoC: Marvell BG4-CT Processor RAM: 2 GB Internal Memory: 16 GB 4K – UHD: Ultra HD, for 4 times better image quality DTS and Dolby sound with S/PDIF and HDMI audio output 128 GB TV recorder, to be completed with the media of your choice Connectivity: SD card reader / 2 USB 2.0 ports Wi-Fi Bluetooth
Okay, I couldn't find a solution to restore it to its original state. Now I want to switch it to Armbian. What files do I need for that? Thank you. hk1 max rk3318 wifi hk6334Q Rockchip RK3318
Thank you for your reply. Could you please direct me to the appropriate section for my problem? @jock
I tried several methods, but when I attempt to flash the firmware, an error message appears stating "Update failed %2". I kindly request assistance from experts to find the appropriate firmware for this device.
Hello everyone, I need help. I have an HK1MAX device with an RK3318 chipset. I need a firmware that can be installed using the loader, as my device is stuck with a red WiFi light (model number: HK6334Q).
samircobra
