Denis Kotlyarov
  1. I used a regular ch340, most likely a fake. Keep in mind that the baud rate is 1500000 in both u-boot and Linux.
  2. Updating via `apt update && apt upgrade` causes Armbian to fail to boot on the single-board computer. I'm attaching the UART logs in the file `failed_log.txt`. Start-Date: 2025-11-13 04:45:12 Commandline: apt -y upgrade Upgrade: armbian-bsp-cli-nanopct4-current:arm64 (25.11.0-trunk.146, 25.11.0-trunk.469), linux-dtb-current-rockchip64:arm64 (25.11.0-trunk.146, 25.11.0-trunk.469), linux-image-current-rockchip64:arm64 (25.11.0-trunk.146, 25.11.0-trunk.469), linux-u-boot-nanopct4-current:arm64 (25.11.0-trunk.146, 25.11.0-trunk.469), armbian-firmware:arm64 (25.11.0-trunk.146, 25.11.0-trunk.469) End-Date: 2025-11-13 04:47:04 out: Starting kernel ... efi_free_pool: illegal free 0x00000000f0f09040 "Synchronous Abort" handler, esr 0x96000004 elr: 00000000002856e4 lr : 00000000002702f0000000f3f9b2f0 x0 : dfb6333a7ba2b4b7 x1 : 00000000f3fba060 x2000000 x5 : dfb6333a7ba2b4b7 x6 : 00000000f0d07000 x7 : 00000000000ef98 x11: 00000000f1f0b5bc x12: 000000000000ef98 x13: 000003f558a4 x17: 00000000d8136251 x18: 00000000f1f22d90 x19: 000000000000001 x23: 00000000f1f303c0 x24: 00000000f3fdcff0 x25: 00000000000000001 x29: 00000000f1f0b470 Code: eb04005f 54000061 5resetting ... To reproduce the issue (~13.11.2025-16.11.2025), simply download and flash the current `Minimal/IOT for Armbian Linux v6.12 [Debian] Debian 12 (Bookworm)` images (`https://www.armbian.com/nanopc-t4/`) and run `apt update & upgrade` on a running system, then reboot. After this, the system, regardless of whether the `SD card` or `EMMC` is used, will enter an infinite boot loop (`out` and file `failed_out.txt`). Thank you. failed_log.txt armbian_release.txt normal_log.txt
