digital
  1. It is Dolamee D5 (same as NEXSMART D32). lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub lshw rk322x-box description: ARMv7 Processor rev 5 (v7l) product: Generic RK322x Tv Box board serial: bf9514... width: 32 bits capabilities: smp *-core description: Motherboard physical id: 0 *-cpu:0 description: CPU product: cpu physical id: 0 bus info: cpu@0 size: 1392MHz capacity: 1392MHz capabilities: half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm cpufreq *-cpu:1 description: CPU product: cpu physical id: 1 bus info: cpu@1 size: 1392MHz capacity: 1392MHz capabilities: half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm cpufreq *-cpu:2 description: CPU product: cpu physical id: 2 bus info: cpu@2 size: 1392MHz capacity: 1392MHz capabilities: half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm cpufreq *-cpu:3 description: CPU product: cpu physical id: 3 bus info: cpu@3 size: 1392MHz capacity: 1392MHz capabilities: half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm cpufreq *-memory description: System memory physical id: 4 size: 1984MiB *-usbhost:0 product: EHCI Host Controller vendor: Linux 6.18.25-current-rockchip ehci_hcd physical id: 1 bus info: usb@1 logical name: usb1 version: 6.18 capabilities: usb-2.00 configuration: driver=hub slots=1 speed=480Mbit/s *-usbhost:1 product: Generic Platform OHCI controller vendor: Linux 6.18.25-current-rockchip ohci_hcd physical id: 2 bus info: usb@2 logical name: usb2 version: 6.18 capabilities: usb-1.10 configuration: driver=hub slots=1 speed=12Mbit/s *-usbhost:2 product: EHCI Host Controller vendor: Linux 6.18.25-current-rockchip ehci_hcd physical id: 3 bus info: usb@3 logical name: usb3 version: 6.18 capabilities: usb-2.00 configuration: driver=hub slots=1 speed=480Mbit/s *-usbhost:3 product: EHCI Host Controller vendor: Linux 6.18.25-current-rockchip ehci_hcd physical id: 4 bus info: usb@4 logical name: usb4 version: 6.18 capabilities: usb-2.00 configuration: driver=hub slots=1 speed=480Mbit/s *-usbhost:4 product: Generic Platform OHCI controller vendor: Linux 6.18.25-current-rockchip ohci_hcd physical id: 5 bus info: usb@5 logical name: usb5 version: 6.18 capabilities: usb-1.10 configuration: driver=hub slots=1 speed=12Mbit/s *-usbhost:5 product: Generic Platform OHCI controller vendor: Linux 6.18.25-current-rockchip ohci_hcd physical id: 6 bus info: usb@6 logical name: usb6 version: 6.18 capabilities: usb-1.10 configuration: driver=hub slots=1 speed=12Mbit/s *-mmc0 description: MMC Host physical id: 7 logical name: mmc0 *-mmc1 description: MMC Host physical id: 8 logical name: mmc1 *-device description: SDIO Device physical id: 1 bus info: mmc@1:0001:1 logical name: mmc1:0001:1 serial: 0 capabilities: sdio *-mmc2 description: MMC Host physical id: 9 logical name: mmc2 *-device description: SD/MMC Device product: T52716 vendor: Unknown (112) physical id: 1 bus info: mmc@2:0001 date: 04/2016 serial: 162369974 capabilities: mmc *-interface:0 physical id: 1 logical name: /dev/mmcblk2rpmb *-interface:1 physical id: 2 logical name: /dev/mmcblk2 size: 15300820992 capabilities: partitioned partitioned:dos configuration: logicalsectorsize=512 sectorsize=512 signature=0035f365 *-volume description: EXT4 volume vendor: Linux physical id: 1 logical name: /dev/mmcblk2p1 logical name: / logical name: /var/log.hdd version: 1.0 serial: 5ba1703d-a005-45bd-b77a-552aa2bbc234 size: 14GiB capacity: 14GiB capabilities: primary journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized configuration: created=2026-04-27 20:14:03 filesystem=ext4 label=armbi_root lastmountpoint=/ modified=2026-07-31 13:10:01 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,commit=120 mounted=2026-07-26 18:16:58 state=mounted *-sound:0 description: HDMI physical id: a logical name: card0 logical name: /dev/snd/controlC0 logical name: /dev/snd/pcmC0D0c logical name: /dev/snd/pcmC0D0p *-sound:1 description: analog physical id: b logical name: card1 logical name: /dev/snd/controlC1 logical name: /dev/snd/pcmC1D0p *-sound:2 description: SPDIF physical id: c logical name: card2 logical name: /dev/snd/controlC2 logical name: /dev/snd/pcmC2D0p *-input product: gpio_ir_recv physical id: d logical name: input0 logical name: /dev/input/event0 capabilities: platform *-network:0 description: Ethernet interface physical id: e logical name: end0 serial: 3a:73:b5:e0:e3:ba size: 100Mbit/s capacity: 100Mbit/s capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=st_gmac driverversion=6.18.25-current-rockchip duplex=full ip=192.168.1.33 link=yes multicast=yes port=twisted pair speed=100Mbit/s *-network:1 DISABLED description: Wireless interface physical id: f bus info: mmc@1:0001:1 logical name: wlan0 serial: 00:e0:4c:b7:23:00 capabilities: ethernet physical wireless configuration: broadcast=yes driver=rtl8723bs driverversion=6.18.25-current-rockchip multicast=yes wireless=IEEE 802.11 dmesg | grep -iE 'wlan|wifi|wireless|80211' [ 12.099414] cfg80211: Loading compiled-in X.509 certificates for regulatory database [415434.295809] warning: `lshw' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211 ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 3a:73:b5:e0:xx:xx brd ff:ff:ff:ff:ff:ff altname enx3a73b5e0xxxx inet 192.168.1.33/24 brd 192.168.1.255 scope global dynamic noprefixroute end0 valid_lft 1491sec preferred_lft 1491sec inet6 fe80::4ac1:84da:103f:d1a5/64 scope link noprefixroute valid_lft forever preferred_lft forever 3: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000 link/sit 0.0.0.0 brd 0.0.0.0 4: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1000 link/tunnel6 :: brd :: permaddr f21f:c174:29b1:: 5: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 00:e0:4c:b7:xx:xx brd ff:ff:ff:ff:ff:ff altname wlx00e04cb7xxxx nmcli end0: connected to Wired connection 1 "end0" ... wlan0: unavailable "wlan0" wifi (rtl8723bs), 00:E0:4C:B7:xx:xx, hw, mtu 1500
  2. But wifi does not work, although armbian-config sees my wifi network and saves password for it. rk322x-config shows Wifi device: unknown - Device ID: 024c:b723. dmesg: r8723bs: module is from the staging directory, the quality is unknown... r8723bs: unknown parameter 'rtw_enusbss' ignored lsmod shows module as unused: r8723bs 405504 0 Could changing led-confs help?
  3. Thanks, I ran from sdcard and these options work on Dolamee D5: overlays=cpu-hs emmc emmc-ddr-ph45 led-conf-default
  4. Thanks, but I cannot run rk322x-config (or can I without being fully booted?). I suppose I can try in overlays=... line in /boot/armbianEnv.txt, but what should I write here?
  5. I have Dolamee D5 box. The legacy kernel 4.4.194-rk322x boots ok, but newer images from @jock or my own built image does not see EMMC. Any ideas? dmesgs attached. 4.4.194.txt 6.12.63.txt
