8lall0
  1. NEWS! I got Mali450 on kodi! I compiled my kodi version with the dockerfile attached. About the acceleration, quoting Claude: EDIT: to make KODI working just set Settings → Player → Videos → Render method → Direct to plane Dockerfile.cross
  2. Update on 0.7: Led Display works perfectly Wifi works perfectly after reboot (i would suggest it on screen after the driver is built) Unable to test USB3 at the moment Installed Kodi, unable to get video acceleration (it says llvmpipe with CPU at almost 100%, clearly is running software rendering) @serovan did you reboot after first boot? But yes, probably your revision has different pinout for the peripherals (wifi and PHY)
  3. I tried 0.6, wifi not working, i own one with EA6521. I made it work on 0.5 changing the .dts a little bit (thanks to Claude) Quote: cat /proc/device-tree/seekwcn_boot/gpio_chip_en 2>/dev/null | od -An -tu4 603979776 285212672 0 # Fix seekwcn_boot GPIOs sed -i 's/gpio_host_wake = <0x24 0x06 0x01>/gpio_host_wake = <0x24 0x12 0x00>/' /tmp/x88pro.dts sed -i 's/gpio_chip_wake = <0x24 0x10 0x00>/gpio_chip_wake = <0x24 0x11 0x00>/' /tmp/x88pro.dts sed -i 's/gpio_chip_en = <0x24 0x11 0x00>/gpio_chip_en = <0x24 0x06 0x00>/' /tmp/x88pro.dts # Fix sdio-pwrseq reset-gpios sed -i 's/post-power-on-delay-ms = <0x8c>/reset-gpios = <0x24 0x06 0x01>;\n\t\tpost-power-on-delay-ms = <0x8c>/' /tmp/x88pro.dts # Disable wireless-bluetooth and wireless-wlan nodes sed -i '0,/status = "okay"/{/wireless-bluetooth/{n;n;n;n;n;n;n;n;n;s/status = "okay"/status = "disabled"/}}' /tmp/x88pro.dts # Verify seekwcn_boot node grep -A 12 'seekwcn_boot {' /tmp/x88pro.dts cp /boot/dtb/rockchip/rk3528-x88pro.dtb /boot/dtb/rockchip/rk3528-x88pro.dtb.bak dtc -I dts -O dtb /tmp/x88pro.dts -o /boot/dtb/rockchip/rk3528-x88pro.dtb 2>/dev/null # 3. Fix module loading mv /etc/modules-load.d/aic8800-btlpm.conf /etc/modules-load.d/aic8800-btlpm.conf.disabled echo "blacklist aic8800_bsp" > /etc/modprobe.d/blacklist-aic.conf echo "blacklist aic8800_btlpm" >> /etc/modprobe.d/blacklist-aic.conf echo "blacklist aic8800_btlpm_sdio" >> /etc/modprobe.d/blacklist-aic.conf echo "extraargs=modprobe.blacklist=aic8800_bsp,aic8800_btlpm,aic8800_btlpm_sdio" >> /boot/armbianEnv.txt # 4. Build skw modules dkms add -m ea6621q -v 1.0 2>/dev/null || true dkms build -m ea6621q -v 1.0 dkms install -m ea6621q -v 1.0 # 5. Set module load order cat > /etc/modules-load.d/skw.conf << 'EOF' skw_bootcoms skw_sdio skw skwbt EOF Right now i cannot try it, if someone else wants to try this... EDIT: the if in the wifi section of the provisioning doesn't detect correctly, the searched directory doesn't exists so it won't install the module
  4. Hello everyone! I'm using this patch set from github to run armbian on x88pro13 (which has RK3528 with Mali 450 MP2). Everything seems to work fine (even wifi), but i'm not able to enable hw acceleration on kodi interface (it shows llvmpipe, so it's sw rendering) Do you have any hints on how to do that? Because at the moment i get 80% cpu just for the kodi gui. Thanks!
